  New Posts New Posts RSS Feed - TAS600 vs TAS605A
TAS600 vs TAS605A
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Topic: TAS600 vs TAS605A
    Posted: 17 May 2014 at 10:58am
Other than the greater range and altitude on the 605A, neither of which is that important for an aircraft with a service ceiling of 18,000, there doesn't seem to be much difference between the 600 and 605A.
Is that the basic difference, or are there some other advantages to the 605A for a smaller aircraft?
Now the 605A has ADS ready circuitry (or is it working now?), but the 600 is upgradeable to a 600A.
Edited by oskrypuch - 17 May 2014 at 11:39am
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2014 at 8:19pm
{bump}
Leonard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leonard Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2014 at 10:27pm
Originally posted by oskrypuch oskrypuch wrote:
{bump}
<Bump> x 2
Victor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Victor Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2014 at 6:31am
Bump x 3
Edited by Victor - 22 Jun 2014 at 6:31am
wsh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wsh Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2014 at 3:53am
I believe the TAS605 also does something with the exact positioning of the targets .. relative to your position. .. The TAS600 apparently does not do this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2014 at 7:43am
OK, I purchased a 605 (vice 600), here is why ...
1) Double the range. The 605 is rated for 15nm, I expect that will give me dependable targets out to 10nm
2) The 605 uses heading information directly, this allows for near instantaneous display position updates in turns. Important for helicopters, nice for planes.
3) But, the biggest reason is that the 605 comes with a coupon for a "free" ADS-B integration update, which is worth about $2000, the 600 does not. The difference in price between the 605 and 600 is about $2000, so it is really a no-brainer. The ADS-B integration is very nice, it will allow reception of not only ADS-B out from aircraft, but also ADS-R from ground stations, eliminating the need for a ADS-B transceiver, at least for traffic.
Work should be done this week.
Edited by oskrypuch - 23 Jun 2014 at 7:44am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leonard Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2014 at 10:52am
Orest,
Looking forward to Pictures of your Panel and how you have all this stacked.
What month of production is your 540?
LJG
This page was generated in 0.119 seconds.
