  New Posts New Posts RSS Feed - Gap in approach and break of ils ?
wsh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wsh Quote  Post ReplyReply Direct Link To This Post Topic: Gap in approach and break of ils ?
    Posted: 10 Jan 2016 at 6:31pm
The other day I was flying from Rotterdam EHRD to Annemasse LFLI .. Right next door to Geneva LSGG.
As we had a lot of headwind I was monitoring the fuel at landing closely along the route. At some point it actually showed -3 at landing.. Fortunately the wind settled down (which was forecasted) and our heading changed for a better angle after a certain waypoint.
Then I started looking closely to the finaly stages of the flightplan. it was going to be DJL folllowed by the DJL1R arrival and ILS23 for LSGG and a breakof to LFLI.
2 things .. Unless I selected vtf rather then SPR it showed a gap in route. Question 1 how do I resolve a gap in route?
Secondly I could only insert LFLI after the missed procedure. This means the whole missed procedure is calculated as well in my fuel at landing field. How do I resolve that??
Edited by wsh - 10 Jan 2016 at 6:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2016 at 10:21pm
The FMS always predicts from the active leg forward through the end of the route and it assumes that you intend to fly a missed approach. It assumes one lap around a missed approach hold. There is no way to tell the FMS that you intend to skip the missed. Once a leg after the missed is activated, then the predictions will reflect the flight plan forward starting with the new active leg.
wsh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wsh Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2016 at 4:58pm
tx ..
and the "gap in route?"
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidBunin Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2016 at 6:37am
Option 1: Scroll the cursor to highlight the gap, then press CLR.
Option 2: With the cursor in the right position (I don't recall exactly), the FMS Butler line-select-key should also offer an option to "connect X with Y" or similar.
