Gap in approach and break of ils ?
URL: http://forums.avidyne.com/forum_posts.asp?TID=928
Printed Date: 12 May 2024 at 3:00pm Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: Gap in approach and break of ils ?
Posted By: wsh
Subject: Gap in approach and break of ils ?
Date Posted: 10 Jan 2016 at 6:31pm
The other day I was flying from Rotterdam EHRD to Annemasse LFLI .. Right next door to Geneva LSGG.
As we had a lot of headwind I was monitoring the fuel at landing closely along the route. At some point it actually showed -3 at landing.. Fortunately the wind settled down (which was forecasted) and our heading changed for a better angle after a certain waypoint.
Then I started looking closely to the finaly stages of the flightplan. it was going to be DJL folllowed by the DJL1R arrival and ILS23 for LSGG and a breakof to LFLI.
2 things .. Unless I selected vtf rather then SPR it showed a gap in route. Question 1 how do I resolve a gap in route?
Secondly I could only insert LFLI after the missed procedure. This means the whole missed procedure is calculated as well in my fuel at landing field. How do I resolve that??
Date Posted: 10 Jan 2016 at 10:21pm
The FMS always predicts from the active leg forward through the end of the route and it assumes that you intend to fly a missed approach. It assumes one lap around a missed approach hold. There is no way to tell the FMS that you intend to skip the missed. Once a leg after the missed is activated, then the predictions will reflect the flight plan forward starting with the new active leg.
Posted By: wsh
Date Posted: 11 Jan 2016 at 4:58pm
tx ..
and the "gap in route?"
Date Posted: 12 Jan 2016 at 6:37am
Option 1: Scroll the cursor to highlight the gap, then press CLR.
Option 2: With the cursor in the right position (I don't recall exactly), the FMS Butler line-select-key should also offer an option to "connect X with Y" or similar.
