Post Your Upgrade Photos |
Paul
Posted: 10 Aug 2015 at 10:00pm |
Now that we know how to upload images we can post our upgrade photos.
Here's our Cessna 172 before the upgrade. It is stock NAV II package except that the ADF indicator was replaced by the engine monitor. The main purpose of the upgrade was to get rid of the KLN 89B. We decided to go with the IFD 540 because if we removed the KLN 89B, one COM radio, and the INOP ADF we'd have enough space for it. And we liked the features, or at least those we knew about - it was a fairly early pre-order. We eventually decided to replace the audio panel and transponder as well, and to add an Icarus SAM roll steering converter. There's an intermediate stage which perhaps aircraft owners should not see: But the result was worth the wait (and the cost): The Icarus SAM is on top, It has a rather small readout and lots of extra capabilities which we mostly don't use. But it provides roll steering which is very nice. Below it is the AMX 240 audio panel. I wrote about why we chose it elsewhere on this forum. Next is the mighty IFD 540. It looks amazing just sitting there. It is connected to the KI 209a indicator which was left from the previous installation. The old annunciator was replaced with a blank panel. Below that is the KX 155A. This was the original COM 1 radio. We swapped the KI 208 for a KI 209 so that it would still have glide slope. We don't ever expect the IFD to fail but if it does we can still fly to a VOR and follow an ILS. Redundancy is an IFR pilot's friend. The next item is the AXP 340 transponder. The old KT 76C had developed problems twice in the three years we had the plane so I wanted it to be gone. This gives us ADS-B out, and the plane is now 2020 compliant. We currently use Foreflight and a Stratus 2 for ADS-B in. On the bottom is the KAP 140 single-axis autopilot. The displays on the engine monitor and COM 2 radio look chopped in this photograph because it was taken at a high shutter speed, but they actually are fine. |
I have added a few minor things since these shots, but here is my panel.
* Orest Edited by oskrypuch - 10 Aug 2015 at 10:30pm |
DavidBunin
I don't have my "before" image handy, but here is my "after".
So far, I am VERY happy with it! David Bunin |
PA20Pacer
This is a "before" photo of our S35 Bonanza panel.
Bob |
PA20Pacer
Here is the "after" photo of our S35 Bonanza panel.
Bob |
AUXAIR
Interesting sequences, so here is my story: First upgrade in 2008, with Ga***n equipment, and you can see what the wiring entailed - and it took over 3 weeks. On July 27m, 2015, my upgrade to the IFD 540, 440 and transponder went in smoothly within 5 days, including new transponder wiring and check out.
David E.
Cessna 182 RG II |
AUXAIR
Right now it is not letting me post the Avidyne pics....????
David E.
Cessna 182 RG II |
Kentucky Captain
Here is our C172M after the complete panel upgrade. In addition to the IFD 540 we added:
Avidyne AXP 340 Mode S ADS-B transponder PS Engineering PMA 450 Audio panel Garmin GNC 255A Nav/Comm Aspen EFD 1000 Pro EFIS S-Tec System 30 autopilot JPI EDM 900 Primary engine monitor ACK E-08 406mhz elt When the airplane fund gets flush again we will add another Aspen EFD 1000 Pro and an Avidyne MLB 100 datalink computer. We have reserved a new N number and had it put on the new panel but will probably wait until painting the airplane to change it. Edited by Kentucky Captain - 14 Aug 2015 at 4:02am |
DavidBunin
Wow! That is a REALLY nice 172.
sikhpilotmd
Groupie Joined: 08 Oct 2014 Location: KISP Status: Offline Points: 69 |
Here's my A36. The picture is missing the Garmin AOA indicator on the left of glare shield. Edited by sikhpilotmd - 14 Aug 2015 at 6:54am |
brou0040
Before: Edited by brou0040 - 11 Sep 2015 at 3:16pm |
Senior Member Joined: 30 Dec 2011 Location: Kingston, NY Status: Online Points: 722 |
Skihpilotmd, I really like the updated layout of the 84 and later A36 Bonanzas over the center yoke my 85 F33A has. As much as I try to convince myself that the single throwover yoke is a good setup, every time I see a nice panel like yours brings me back to reality. There is no real good way to move the IFDs into the center of the panel without major construction and adding a JPI930 or similar.
sikhpilotmd
Thanks, I like the simple layout
'73 Cherokee Challenger After: |
The new one piece panels really update the aircraft and make it look new again. Nice job.
AUXAIR
My easy Avidyne installation in my 182RG. IFD 540, IFD 440 and AXP 340 transponder - along with MLB 100 ADSB
David E.
Cessna 182 RG II |
AUXAIR
David E.
Cessna 182 RG II |
AUXAIR
My 182RG - awaiting the trip to the Avidyne installation radio shop in Fort Pierce, FL
David E.
Cessna 182 RG II |
scott
Groupie Joined: 21 Aug 2013 Location: Danville, CA Status: Offline Points: 76 |
My Twin Commander 500B with a full Avidyne stack, which just happens to be for sale: www.n222le.weebly.com
drapo
Newbie Joined: 27 Apr 2015 Location: Lachute QC Status: Offline Points: 19 |
AUXAIR
Very cool! Great looking installation.
David E.
Cessna 182 RG II |
comancheguy
Original Panel - comanche 260C
comancheguy
New Panel - Dual 540s:
Edited by comancheguy - 16 Aug 2015 at 1:22pm |
n7ifr
Finally brought a camera on flight - Final Panel (for now)
Tom Wolf |
BobsV35B
Is there somewhere I could find directions as to how to download a picture to this site? Gotta be simple or I will not be able to do it!<NG> Happy Skies, Old Bob |
Old Bob, Ancient Aviator
n7ifr
Bob, lots of thread material on this - Good luck. Tom W.
Edited by n7ifr - 21 Aug 2015 at 6:04pm |
brou0040
I'm back up and flying, here's a picture of the panel now. I've taken out the the Garmin 155XL, a KX155A, KT76A, and inop radar altimeter. I've added a engine monitor, fuel flow, IFD540, AXP340, iFly700, an android tablet running iFly software, antenna splitter, backup vacuum, low vac light, and a fuse panel to run the EI equipment and power a custom center console with power jacks and holders for tablets for the kids. Next up is a new audio panel and removing the inop clock, I've got several other compliant timers so I don't need a dedicated one. |
fritz
Groupie Joined: 18 Jan 2014 Location: SF Bay Area Status: Offline Points: 57 |
The aircraft is a 1980 A36. The panel now consists of: 2 IFD 540s AMX240 Audio Panel AXP340 ADS B transponder MLB100 TAS 605 Evolution 2000 CoGuardian 452 Aerospace Logic Clock CO200K Aerospace Logic Fuel Gauge -FL 204 I did this work in January of 2015 and really like the way it came out! Happy to answer any questions on or off line. And the After: Edited by fritz - 12 Sep 2015 at 11:21am |
12vaitor
Newbie Joined: 16 Jun 2015 Location: Panama City, FL Status: Offline Points: 1 |
Here is my RV-12 with a new IFD540 installed. Dynon Skyview with AP, ADS-B, and 2nd GPS + Garmin GTR200
DavidBunin
What's the yellow thing under the panel at the far right?
