  New Posts New Posts RSS Feed - Install tip
Install tip
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Topic: Install tip
    Posted: 07 Dec 2014 at 12:04pm
An unanticipated situation, the lower left control knob on the IFD540 blocks the pilot's view of the active frequency on the SL-30 radio. This may be a factor with other avionics. If you are going from a 530 -> 540 in place, then you will probably be OK, but we went from a 430 + spacer -> 540.
To fix this I will swap the SL-30 and AXP340. That is a bit of labor to pull the cage and redo it, so be aware.
This page was generated in 0.046 seconds.
