  New Posts New Posts RSS Feed - Questions from using the sim
Post Options Post Options   Thanks (0) Thanks(0)   Quote brou0040 Quote  Post ReplyReply Direct Link To This Post Topic: Questions from using the sim
    Posted: 28 Mar 2014 at 8:30pm
I've got a question from using the sim so I figured I'd start a new post for usage questions since I'm not sure if it's a limitation from the sim, how I'm using it, or something about the actual software.
I was trying to fly the ILS30R into BFL coming from the east entering at Jupex.  I never noticed the nav frequency auto tune the ILS, when I tuned it on a follow-up approach, I never saw an ID, and although it did switch to GPS->VLOC during the hold, once I passed Jupex inbound on the approach, it switched back to GPS instead of VLOC.
I'm not sure why it didn't auto-tune, but I'm thinking that since that it may be a sim limitation since it is not connected to an actual receiver that it didn't ID the station and wasn't able to transfer to VLOC.  I have Auto-VLOC Tuning and GPS->VLOC capture enabled on the AUX setup user option page.
I was also expecting to see Enable Missed as an LSK on the MAP page once passing the FAF instead of having to switch to the FMS page.
I'm curious to see how Steve and the early adopters have been flying.  I assume you spend most of the time flying on the MAP page and only go to the FMS page to change the flight plan.    That is why I was expecting that although I can go to the FMS page to enable the missed, I figured I'd get an LSK on the MAP page so I wouldn't have to switch back and forth.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2014 at 8:40am
I'll load the sim on my laptop and try to recreate this weekend.
I do fly that type of scenario all the time in-flight with the real gear and it works much differently from what you report.   Auto tuning works fine and if the capture criteria as defined in the pilot guide in Section 5 are met, then the auto switch to VLOC occurs as expected.
As for the Enable Missed LSK, we don't support that on the Map page as you note.   We do think it would be a major improvement to the system overall to have that LSK available on all pages during an approach and that is a candidate for future releases - the problem is what are we willing to give up to create that capability, hence the reason for the deferral.
I do fly predominantly on the Map page and I personally only use the FMS pages to create/alter a flight plan or enable the missed as you suggest.   I make extensive use of the function keys along the right side of the unit (FREQ, PROC) to facilitate standard operations when flying approaches.
Post Options Post Options   Thanks (0) Thanks(0)   Quote brou0040 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2014 at 11:28am
Thanks ahead of time for looking into this and I'll review section 5 to see if I can find what I am missing.
twalterhome3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote twalterhome3 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2014 at 2:14pm
Just another data point
I had the exact same concerns and was going to post, but you beat me to it !
The simulator does not auto tune as far as I can tell.
And not having the "activate missed" on the map page is definitely something that should be changed.
Also I managed to crash the simulator with a null pointed dereference.
Are you interested in bug reports?
Is this actually a simulated unit running production code?
Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2014 at 3:17pm
Sure, please send all bug reports to my email at sjacobson@avidyne.com
glassanza View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote glassanza Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2014 at 6:31pm
Not sure what a null pointed dereference is but I was playing around loading the KDAL departure Tom Harper did the youtube video on and yes it can be done very easily and quickly. The bad news is the sim always crashes (20+ times) before flying all legs in the flight plan so that part sucks. One problem may be the datalink weather not connecting and remaining in the alert box all the time (the WSI live weather box says the client is connecting to www.007guard.com and shows the feed connected) and the fact that I speed up the flight time a little but stay below the "dead reckoning" message speed. Also have the same issues as previously mentioned, I'm sure improvements are coming. That being said, I really, really really like what I have seen so far!!!
GDC25
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2014 at 7:18pm
GDC25,
By "always crashes" do you mean it simulates hitting the ground (that's what mine did when I ran the demo) or do you mean the software app crashes (mine did not have any issues)?
Post Options Post Options   Thanks (0) Thanks(0)   Quote glassanza Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2014 at 3:00pm
Poor choice of words on my part, sorry.The program/app locks down/freezes, basically stops working completely although the screen remains up with no error messages of any kind.
GDC25
KIM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KIM Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2014 at 7:04pm
Unable to start Simulator:
Problemsignatur:
Problemereignisname: APPCRASH
Anwendungsname: FMS500.exe
Anwendungsversion: 0.0.0.0
Anwendungszeitstempel: 533480f0
Fehlermodulname: FMS500.exe
Fehlermodulversion: 0.0.0.0
Fehlermodulzeitstempel: 533480f0
Ausnahmecode: c0000005
Ausnahmeoffset: 004cd48c
Betriebsystemversion: 6.1.7600.2.0.0.256.48
Gebietsschema-ID: 1031
Zusatzinformation 1: c286
Zusatzinformation 2: c286cdc1243b8da652a32767db964d90
Zusatzinformation 3: 0ca2
Zusatzinformation 4: 0ca237d65e5587288b27e61af27b338a
Lesen Sie unsere Datenschutzbestimmungen online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0407
Wenn die Onlinedatenschutzbestimmungen nicht verfügbar sind, lesen Sie unsere Datenschutzbestimmungen offline:
C:\Windows\system32\de-DE\erofflps.txt
Klaus
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2014 at 7:48pm
Hi Klaus,
That sounds frustrating.  My only immediate thought is to ask if your computer meets the specifications defined in the ReadMe file that was part of the download?
Most of us are at Sun-n-Fun for the next week so we're pretty occupied with those activities which I fear may limit our support this coming week.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2014 at 8:22pm
Won't run on my Windoze machine either, which meets specs (dual core/Vista).
Wants an updated QL.  Don't know how to do that.
edanford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote edanford Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2014 at 2:00pm
Looks like the weather enabled version of SIM does not save the data block setups entered.
The original large version would save them.  Am I missing something?
Ed
Ed
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2014 at 2:45pm
I'm seeing the same thing, the custom set blocks are not remembered. That said, I can' t be certain they were before.
FWIW, the blocks shown are different from the original sim (Int'l) version.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2014 at 8:41am
Hhmm.  Will check some of these issues out and report back in the next day or so as I wade through them.
