Jep Chart update 18-2021 gives an Error |
rjevansuk
Newbie Joined: 20 May 2018 Location: UK Status: Offline Points: 38 |
Posted: 09 Sep 2021 at 11:25am |
Hi,
I downloaded the latest Jep Chart updates last week via usb stick to an IFD 540, but the chart database is completely empty. I have tried to upload the data again and I keep getting an Error. Not Sure if this is a problem with Jeppesen or the IFD. are there any diagnostics I can try to check the update was successful and is it possible to roll back to the previous data? Thanks Roger Evans
Is it the IFD giving you an error? What is the error?
rjevansuk
Hi Steve, thanks for the prompt reply. I can't remember the exact error message, I'll get a screen shot over the weekend.
You can only load data from the usb to the IFD once. If you have any problem following the first load (as in your case of the empty chart database), you can‘t try again with the same usb. The load process changes something on the usb which prevents subsequent attempts. You‘ll need to recreate the usb before attempting again…. that probably means contacting Jepp to reset the download so you can rewrite the usb.
Edited by chflyer - 10 Sep 2021 at 5:08am |
rjevansuk
Ok So today I downloaded the latest Charts using JDM. these charts superseded the pervious charts I tried to upload. I downloaded to a different usb stick. I got this error. No other details.
Edited by rjevansuk - 23 Sep 2021 at 12:20pm |
Looks like a compact flash problem to me. I would contact tech support and have them walk through it with you. It might require a trip to the dealer.
rjevansuk
Do you mean the usb stick? I deliberately used a different usb stick just in case the original stick was the problem. BTW the Latest nav data and obstacle data both downloaded ok.
So it cant be the usb drive. |
No I mean IFD internal memory. Best to check with tech support. They may have a trick up their sleeve. Your event log may show something. Feel free to download it and send it to me if you like.
jdojr
Newbie Joined: 19 Oct 2019 Location: Texas Status: Offline Points: 24 |
I'm having the same problem. Tech support didn't help too much. Possibly reload the software or ? Hopefully this doesn't require a trip to a dealer.
rjevansuk
My colleague had the plane at our maintainance engineer's yesterday and the avionics specialist downloaded the error and passed on to Avidyne. Hopefully I'll find out the solution next week.
Edited by rjevansuk - 25 Sep 2021 at 8:35am |
I asked tech support and they didn't have any open tickets from you. Did you download the event log and send it to them? If not, please email that directly to me and I'll look through it.
rjevansuk
Hopefully Ill download the log tomorrow if the weather is ok.
Roger
rjevansuk
Hi Steve,
Cycle 20-2021 is available today but I don't want to upload until I have a fix. Roger
rjevansuk
Update. Good news and some Bad.
Took the plane into the dealer today for them to do a reformat of the flash drive: Jep Charts updated to the latest 21-2021. However, when loading the other data they got an error "Data License count exceeded" So the Navdata and Obstacles rolled back to sept 2021. so out of date. I was told to contact Jep to get them to enable me to download again or wait for the November cycle. The system was on the latest version 10.2.6, now rolled back to 10.2.4. Update will be done when we take the plane in for its 100 hr service. Hopefully 10.3 will be out soon. I forgot to backup the user waypoints, so will not be popular with the other pilots. Fortunately I have a backup from a couple of years ago, so all is not lost. finally, I no longer get the option to connect to wi-fi, so can't use the IFD 100, Is this something I can do? or do I need to take the plane in again? |
MikeS
It sounds like the reformat files the dealer used were outdated if they did the CF reformat and it rolled you back to 10.2.4.1. There is a specific folder that includes the latest software as well as the reformat utility files and terrain database.
The reformat completely wipes the IFD, including the tail number-specific options file that includes the Wi-Fi, Bluetooth, and 500-foot callout enablements, plus any other enablements that you may have purchased such as SAR, Radar, 16W radio, etc. The Service Bulletin included in the reformat folder specifically states that these files must be reloaded as part of the reformat process. It sounds like the CF reformat was successful, however the person(s) performing the reformat missed a few important parts of the service bulletin. Email me at pilotsupport@avidyne.com with your tail number and IFD serial numbers and I can create the enablement file needed to get these enablements back on your IFD. Now all it needs is the software update to 10.2.6.1 if you choose to do so.
MarkZ
What about a deal like this?
That means that the nav data update wasn't successful the last time you tried it. What was the failure message when it was unsuccessful (i.e. before the power was cycled and you got the message in the picture)?
MarkZ
Jepp gave me two more downloads to try. It’s the first time I’ve seen it. They said it if it doesn’t go, then try another stick.
MarkZ
Jeppesen gave me two more tries and it worked flawlessly on the first attempt. You do have to deal with logging into their support system once to get the support account. Everything happens between that and emails that tell you to log into the support system. They’re the only game in town and we have to play by their rules.
dmtidler
Senior Member Joined: 12 Feb 2016 Location: USA Status: Online Points: 616 |
I've had Jeppesen Tech Support reset the downloads several times in the past due to errors reported by JDM in transferring the data to a USB flash drive. Each reset was really easy and quick.
I just called the Jeppesen Tech Support at (800) 732-2800 or (303) 328-4587, told them the issue, and they would reset the requested download on their end and have me clear the JDM cache on my end. Those phone numbers are found in the Contact Jeppesen section of JDM help. With JDM already opened and logged into, my customer number is conveniently prominent at the top of the JDM window. |
JoeIBM
Newbie Joined: 04 Dec 2021 Location: Virginia Status: Offline Points: 10 |
Hmm - I'm having a similar problem, although mine is the Charts only, and Navdata and Charts had successfully downloaded from JDM and successfully uploaded to the IFD540 via the Avidyne-supplied USB stick. But yesterday the IFD error'd out after 99% loaded. I tried just re-uploading today and got this pic. Given it's Sunday, I've submitted a customer support case to Jepp, but figure I'll have to wait until tomorrow. In the meantime - I've downloaded all the 540 logs, and wondering if there's anything I can/should do with those to determine anything on my own? Is there a parser or log analysis service I can use?
C310R at KJYO
Lautensack
Newbie Joined: 28 Feb 2019 Location: KFZY Status: Offline Points: 6 |
I missed this and started a similar post.
I have had this occur since the Nov 12, 2021 Chart update failed with an error. I thought nothing of it until it has happened again the past 2 cycles. Here's my post Sure would like a fix before I fly into NYC B airspace this week.
rjevansuk
The fix for my problem was to re-format the flash drive and re-install. This was done by our local dealer. Unfortunately they rolled us back to a previous version 10.2.4 from 10.2.6!
Make sure you backup all of your personal data way points etc.
Lautensack
Did you mean you reformatted the thumb drives or did you reformat the IFD drive?
Pete
nrproces
Senior Member Joined: 19 Sep 2016 Location: Marion, MT Status: Offline Points: 140 |
Ah, me too.....I dont think that this is an isolated incident... I have a 540, and it is happening to me too. |
Sauce
rjevansuk
The dealer reformatted the IFD internal "drive" and re-installed the software. As long as you back up way points, user settings etc. it should be ok.
tonyb@brightszoo.com
Newbie Joined: 26 May 2022 Location: Usa Status: Offline Points: 1 |
I got this error today when trying to update my IFD550, was able to update IFD540. Called Avidyne support and was told to format the navdata usb and reload. It didn’t fix the problem.
Avidyne support said that I need to take to a dealer for a CE Reset. Don’t understand why there is no way to do myself. Now have to fly hour to avionics. I’ve flown with Garmin’s for 20 plus years with zero issues. Rethinking I should do went with Garmin 750. Aggravating
