Jep Chart update 18-2021 gives an Error
URL: http://forums.avidyne.com/forum_posts.asp?TID=2249
Printed Date: 06 Jul 2025 at 7:07pm
Topic: Jep Chart update 18-2021 gives an Error
Posted By: rjevansuk
Subject: Jep Chart update 18-2021 gives an Error
Date Posted: 09 Sep 2021 at 11:25am
Hi,
I downloaded the latest Jep Chart updates last week via usb stick to  an IFD 540, but the chart database is completely empty. I have tried to upload the data again and I keep getting an Error. Not Sure if this is a problem with Jeppesen or the IFD. are there any diagnostics I can try to check the update was successful and is it possible to roll back to the previous data?
Roger Evans
Date Posted: 09 Sep 2021 at 11:42am
Is it the IFD giving you an error?  What is the error?
Date Posted: 09 Sep 2021 at 11:45am
Hi Steve, thanks for the prompt reply. I can't remember the exact error message, I'll get a screen shot over the weekend.
Date Posted: 10 Sep 2021 at 5:07am
You can only load data from the usb to the IFD once. If you have any problem following the first load (as in your case of the empty chart database), you can‘t try again with the same usb. The load process changes something on the usb which prevents subsequent attempts. You‘ll need to recreate the usb before attempting again…. that probably means contacting Jepp to reset the download so you can rewrite the usb.
Date Posted: 23 Sep 2021 at 12:19pm
Ok So today I downloaded the latest Charts using JDM. these charts superseded the pervious charts I tried to upload. I downloaded to a different usb stick. I got this error. No other details.
Date Posted: 23 Sep 2021 at 1:29pm
Looks like a compact flash problem to me.  I would contact tech support and have them walk through it with you.  It might require a trip to the dealer.
Date Posted: 23 Sep 2021 at 1:41pm
Do you mean the usb stick? I deliberately used a different usb stick just in case the original stick was the problem. BTW the Latest nav data and obstacle data both downloaded ok.
So it cant be the usb drive.
Date Posted: 23 Sep 2021 at 2:38pm
No I mean IFD internal memory.  Best to check with tech support.  They may have a trick up their sleeve.  Your event log may show something.  Feel free to download it and send it to me if you like.
Posted By: jdojr
Date Posted: 24 Sep 2021 at 8:12pm
I'm having the same problem.  Tech support didn't help too much.  Possibly reload the software or ?  Hopefully this doesn't require a trip to a dealer.
Date Posted: 25 Sep 2021 at 8:34am
My colleague had the plane at our maintainance engineer's yesterday and the avionics specialist downloaded the error and passed on to Avidyne. Hopefully I'll find out the solution next week.
Date Posted: 28 Sep 2021 at 2:21pm
I asked tech support and they didn't have any open tickets from you.  Did you download the event log and send it to them?  If not, please email that directly to me and I'll look through it.
Date Posted: 28 Sep 2021 at 3:49pm
Hopefully Ill download the log tomorrow if the weather is ok.
Roger
Date Posted: 01 Oct 2021 at 5:46am
Hi Steve,
Cycle 20-2021 is available today but I don't want to upload until I have a fix.
Roger
Date Posted: 21 Oct 2021 at 12:17pm
Update. Good news and some Bad.
Took the plane into the dealer today for them to do a reformat of the flash drive:
Jep Charts updated to the latest 21-2021.
However, when loading the other data they got an error "Data License count exceeded"
So the Navdata and Obstacles rolled back to sept 2021. so out of date. I was told to contact Jep to get them to enable me to download again or wait for the November cycle.
The system was on the latest version 10.2.6, now rolled back to 10.2.4. Update will be done when we take the plane in for its 100 hr service. Hopefully 10.3 will be out soon.
I forgot to backup the user waypoints, so will not be popular with the other pilots. Fortunately I have a backup from a couple of years ago, so all is not lost.
finally,  I no longer get the option to connect to wi-fi, so can't use the IFD 100, Is this something I can do? or do I need to take the plane in again?
Posted By: MikeS
Date Posted: 21 Oct 2021 at 12:55pm
It sounds like the reformat files the dealer used were outdated if they did the CF reformat and it rolled you back to 10.2.4.1. There is a specific folder that includes the latest software as well as the reformat utility files and terrain database.
The reformat completely wipes the IFD, including the tail number-specific options file that includes the Wi-Fi, Bluetooth, and 500-foot callout enablements, plus any other enablements that you may have purchased such as SAR, Radar, 16W radio, etc. The Service Bulletin included in the reformat folder specifically states that these files must be reloaded as part of the reformat process.
It sounds like the CF reformat was successful, however the person(s) performing the reformat missed a few important parts of the service bulletin. Email me at pilotsupport@avidyne.com with your tail number and IFD serial numbers and I can create the enablement file needed to get these enablements back on your IFD.
Now all it needs is the software update to 10.2.6.1 if you choose to do so.
Posted By: MarkZ
Date Posted: 21 Oct 2021 at 5:51pm
What about a deal like this?
Date Posted: 22 Oct 2021 at 9:22am
That means that the nav data update wasn't successful the last time you tried it.  What was the failure message when it was unsuccessful (i.e. before the power was cycled and you got the message in the picture)?
Posted By: MarkZ
Date Posted: 22 Oct 2021 at 1:32pm
Jepp gave me two more downloads to try. It’s the first time I’ve seen it. They said it if it doesn’t go, then try another stick.
Posted By: MarkZ
Date Posted: 22 Oct 2021 at 8:10pm
Jeppesen gave me two more tries and it worked flawlessly on the first attempt. You do have to deal with logging into their support system once to get the support account. Everything happens between that and emails that tell you to log into the support system. They’re the only game in town and we have to play by their rules.
Date Posted: 23 Oct 2021 at 8:46am
I've had Jeppesen Tech Support reset the downloads several times in the past due to errors reported by JDM in transferring the data to a USB flash drive. Each reset was really easy and quick.
I just called the Jeppesen Tech Support at (800) 732-2800 or (303) 328-4587, told them the issue, and they would reset the requested download on their end and have me clear the JDM cache on my end. Those phone numbers are found in the Contact Jeppesen section of JDM help. With JDM already opened and logged into, my customer number is conveniently prominent at the top of the JDM window.
Posted By: JoeIBM
Date Posted: 19 Dec 2021 at 3:57pm
Hmm - I'm having a similar problem, although mine is the Charts only, and Navdata and Charts had successfully downloaded from JDM and successfully uploaded to the IFD540 via the Avidyne-supplied USB stick.  But yesterday the IFD error'd out after 99% loaded.  I tried just re-uploading today and got this pic.  Given it's Sunday, I've submitted a customer support case to Jepp, but figure I'll have to wait until tomorrow.  In the meantime - I've downloaded all the 540 logs, and wondering if there's anything I can/should do with those to determine anything on my own?  Is there a parser or log analysis service I can use?
Chart upload in progress
C310R at KJYO
Posted By: Lautensack
Date Posted: 19 Dec 2021 at 8:59pm
I missed this and started a similar post.
I have had this occur since the Nov 12, 2021 Chart update failed with an error.
I thought nothing of it until it has happened again the past 2 cycles.
Here's my post
Sure would like a fix before I fly into NYC B airspace this week.
Has anyone had trouble uploading Jep Charts to their IFD 540?
For the past 2 cycles when I upload the charts the upload gets to 30% installed and receive then it quits and I recieve an ERROR message.
I have tried with 2 different thumb drives, both formatted as FAT32.
Both with JDM reinstalled on my Mac.
The other files uploaded correctly.
I have talked with Jepp and done what they suggested (uninstall and reinstall JDM, use a different thumb drive).
I have used my Mac to download files successfully onto the thumb drives and then into the IFD 540 for a couple of years.
Looking for suggestions to fix the upload issue.
Pete
Date Posted: 20 Dec 2021 at 6:46am
The fix for my problem was to re-format the flash drive and re-install. This was done by our local dealer. Unfortunately they rolled us back to a previous version 10.2.4 from 10.2.6!
Make sure you backup all of your personal data way points etc.
Date Posted: 20 Dec 2021 at 7:18am
Did you mean you reformatted the thumb drives or did you reformat the IFD drive?
Pete
Posted By: nrproces
Date Posted: 20 Dec 2021 at 8:13am
Ah,  me too.....I dont think that this is an isolated incident...
I have a 540, and it is happening to me too.
Sauce
Date Posted: 21 Dec 2021 at 3:13am
Pete
The dealer reformatted the IFD internal "drive" and re-installed the software.
As long as you back up way points, user settings etc. it should be ok.
Posted By: tonyb@brightszoo.com
Date Posted: 28 May 2022 at 11:17am
I got this error today when trying to update my IFD550, was able to update IFD540.  Called Avidyne support and was told to format the navdata usb and reload. It didn’t fix the problem.
Avidyne support said that I need to take to a dealer for a CE Reset.
Don’t understand why there is no way to do myself. Now have to fly hour to avionics.
I’ve flown with Garmin’s for 20 plus years with zero issues.  Rethinking I should do went with Garmin 750.
Aggravating
