  New Posts New Posts RSS Feed - Feature Request: select remote transponder input
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Topic: Feature Request: select remote transponder input
    Posted: 30 Apr 2016 at 11:18pm
Ok, here is the scenario. AXP322, plus the BT keyboard.
I hit the knob twice to get to the transponder (OK, with 10.2 it will be one key), and then I need to put in the transponder code. It seems that the only way to get the input dialog up, is by a touch on the touchscreen. Not hard to do, but not very friendly in bumps, and would be much nicer if some key on the BT keyboard could activate that dialog field for me.
Perhaps there already is, in which case I'm all ears, or maybe 10.2 will address this.
But, if not, can you please allow some way of opening the remote transponder code input dialog from the BT keyboard.
PeterC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterC Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2016 at 12:02pm
I agree.  I have the transponder configured in the top left, which is small.  Pressing that block is sometimes tricky.
Perhaps pressing the lower right knob when the transponder block is selected could open the keyboard for input.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2016 at 1:23pm
When using a keyboard, it would be logical to add a SECOND push of the transponder key, when already in the transponder group, to bring up the transponder code dialog.
That steps around the issue of what display group has "focus" for cursor commands.
Edited by oskrypuch - 01 May 2016 at 1:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2016 at 5:17pm
With Rel 10.2, pressing the transponder key on the Bluetooth keyboard pops up the transponder virtual keyboard on the IFD. At that point you can either use the virtual keyboard to type in your code or the remote Bluetooth one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2016 at 5:55pm
With Rel 10.2, pressing the transponder key on the Bluetooth keyboard pops up the transponder virtual keyboard on the IFD.  ...
Wow! That was fast! ;-)
BTW, any additional COOL Avidyne announcements at AEA?
Edited by oskrypuch - 01 May 2016 at 5:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2016 at 5:58pm
And I just use the IFD100 personally to do it.
Edited by AviJake - 01 May 2016 at 6:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2016 at 5:59pm
Nothing for AEA but we should have at least one shortly and some neat ones at Oshkosh.
Looking forward.
This page was generated in 0.301 seconds.
