Feature Request: select remote transponder input
URL: http://forums.avidyne.com/forum_posts.asp?TID=1057
Printed Date: 16 Jul 2025 at 7:15am
Topic: Feature Request: select remote transponder input
Subject: Feature Request: select remote transponder input
Date Posted: 30 Apr 2016 at 11:18pm
Ok, here is the scenario. AXP322, plus the BT keyboard.
I hit the knob twice to get to the transponder (OK, with 10.2 it will be one key), and then I need to put in the transponder code. It seems that the only way to get the input dialog up, is by a touch on the touchscreen. Not hard to do, but not very friendly in bumps, and would be much nicer if some key on the BT keyboard could activate that dialog field for me.
Perhaps there already is, in which case I'm all ears, or maybe 10.2 will address this.
But, if not, can you please allow some way of opening the remote transponder code input dialog from the BT keyboard.
Posted By: PeterC
Date Posted: 01 May 2016 at 12:02pm
I agree.  I have the transponder configured in the top left, which is small.  Pressing that block is sometimes tricky.
Perhaps pressing the lower right knob when the transponder block is selected could open the keyboard for input.
Peter - 1977 Cardinal RG C-FJPC - IFD550/540/240/322/605A/Skytrax100, Aspen MAX 2000, Trio A/P
Date Posted: 01 May 2016 at 1:23pm
When using a keyboard, it would be logical to add a SECOND push of the transponder key, when already in the transponder group, to bring up the transponder code dialog.
That steps around the issue of what display group has "focus" for cursor commands.
Date Posted: 01 May 2016 at 5:17pm
With Rel 10.2, pressing the transponder key on the Bluetooth keyboard pops up the transponder virtual keyboard on the IFD. At that point you can either use the virtual keyboard to type in your code or the remote Bluetooth one.
Date Posted: 01 May 2016 at 5:55pm
Originally posted by AviJake AviJake wrote:
With Rel 10.2, pressing the transponder key on the Bluetooth keyboard pops up the transponder virtual keyboard on the IFD.  ...
Wow! That was fast! ;-)
BTW, any additional COOL Avidyne announcements at AEA?
Date Posted: 01 May 2016 at 5:58pm
And I just use the IFD100 personally to do it.
Date Posted: 01 May 2016 at 5:59pm
Nothing for AEA but we should have at least one shortly and some neat ones at Oshkosh.
Looking forward.
