  New Posts New Posts RSS Feed - Aircraft ID - no spaces available
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Topic: Aircraft ID - no spaces available
    Posted: 13 Mar 2016 at 6:06pm
I am trying to edit in my aircraft ID in the User Settings. The field is seven characters long, my tailnumber is five characters long. There is no "space" character. How do you enter just the five character long tailnumber?
For now I've prepended zeros (00CFCPO), but that is not very satisfactory.
Edited by oskrypuch - 13 Mar 2016 at 6:06pm
AzAv8r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AzAv8r Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2016 at 8:31pm
Doesn't "Enter" or changing fields after you entered your tail number work?  I don't recall being unsuccessful in entering ours, which has 6 digits (including the "N").
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2016 at 8:59pm
That may be, but now that I have seven characters in there, not sure how I get rid of them.
warrenc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote warrenc Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2016 at 9:38pm
I had the same problem and can't remember exactly how I fixed it.  I think I put my N number in followed by a 0(zero)  Then I hit clear or delete and it went away.
Warren
PeterC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterC Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2016 at 3:14pm
I used the Clear button, so to do my Canadian tail, I typed CFJPC, then moved the cursor to the end of the field and pressed the clear key so the cursor backspaced over the extra characters.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2016 at 3:30pm
Thanks, will give the CLR key a try.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pburger Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2016 at 5:19pm
Orest,
I just did this yesterday, and as Peter said use the CLR key to blank out the characters at the end.  Don't try to clear the characters at the front end, or to prepend anything.  Just start filling in your ID and then used the CLR key at the end.  You might have to add the 6th and 7th characters and then use the CLR key to backspace over them.  It will shorten the length of the field to whatever you entered.
I put in my 6-char ID and used the CLR key to eliminate the final character.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2016 at 9:09pm
Yep, the CLR key is the answer. Fixed it up today.
