  New Posts New Posts RSS Feed - Pairing Bluetooth Keyboard
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Topic: Pairing Bluetooth Keyboard
    Posted: 20 Dec 2015 at 7:35pm
Probably the information is somewhere on this board.
How does one pair the keyboard with the IFD so it can be used?  I assume the button on the back is the pairing key.
There are no instructions; are there downloadable instructions somewhere?
thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2015 at 7:46pm
Check out page 6-46 of the PG for the pairing instructions. The button on the back of the keyboard is the pairing button.
Post Options Post Options   Thanks (0) Thanks(0)   Quote brou0040 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2015 at 7:53pm
When did you guys get your keyboards?!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2015 at 7:56pm
Avidyne.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2015 at 8:54pm
I think the question was WHEN.
Gring is flying an experimental, so he can have stuff way ahead. David, are you in an experimental as well?
