  New Posts New Posts RSS Feed - Taxi Charts question
FlyingCOham View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FlyingCOham Quote  Post ReplyReply Direct Link To This Post Topic: Taxi Charts question
    Posted: 30 Oct 2015 at 11:08am
From page 3-30 of the current 540 draft manual:
"Taxi Charts
If a published procedure was used via the Charts tab for the landing airport, the display chart will automatically switch over to the airfield diagram during post-landing roll out. Your ownship position on the airfield diagram chart will be displayed as an aid in surface navigation."
Question: Can anyone think of a reason the 540 shouldn't automatically switch to the airfield diagram (if one is available) ANYTIME the aircraft is below flying speed, whether or not it is at the end of flying a published procedure (at startup and after landing)?  It seem to me that it only makes sense to view ground data when on the ground.  If the user wants the Map then tap the Map button or lift off again.
Thoughts??
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2015 at 11:44am
Agree.
IIRC the Aspen MFDs do that when <30 kts speed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2015 at 12:26pm
The same could be said about approach plates.  Anytime an approach is added to the FMS, the Chart tab should display that chart without the user loading it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2015 at 12:40pm
Absolutely.
roltman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roltman Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2015 at 12:45pm
Yes, I wouldn't mind it if ONE of my IFDs would jump to the local chart when on ground during a startup event or an on ground landing event.  Even if a chart was being displayed or not.
I guess provided you have up-to-date charts since some people are not buying charts.
I wouldn't want both to change, as such I'd like to choose which one changed.
compasst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote compasst Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2015 at 8:06am
I agree with both suggestions - automatically load the destination airport in the charts tab - too confusing and frustrating to have to dial in the airport to get the charts. Sure I can load a proc, but why not have the charts page pre-populated. Likewise on the taxi diagram - something my FlyQ does automatically, although it only does this with plated airport diagrams and not all diagrams like are available on the 540.
94S View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 94S Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2015 at 12:06pm
+1 & +1
Post Options Post Options   Thanks (0) Thanks(0)   Quote FlyingCOham Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2015 at 12:28pm
Admin Group, your thoughts??
AUXAIR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AUXAIR Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2015 at 5:01pm
This would be a very cool feature:  When the destination airport was selected, the charts for that airport would be loaded into the selection box automatically, and would be available for selection once the "Charts" feature was activated.  Perhaps the airport chart would be there first...
Edited by AUXAIR - 31 Oct 2015 at 5:04pm
David E.
Cessna 182 RG II
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2015 at 5:54pm
Aspen's MFD has an option to automagically display the taxi diagram when airspeed drops below 30 KTS.
jhbehrens View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhbehrens Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2015 at 4:44am
I find the fact that you have to manually change the airport identifier and then select an approach from the Charts tab when you already have a destination and approach loaded in the FMS one of the few non-intuitive elements of the IFD540 UI.
There is a shortcut to the plate from the FMS page I believe though but somehow thats not the workflow I use intuitively.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2015 at 6:17am
Yep, just press the chart icon on the destination airport waypoint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2015 at 9:29am
There is also a PASTE KXXX soft key, which will fill in with the arrival airport name, once enroute.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FlyingCOham Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2015 at 10:06am
Let's get back to the original question, "Can anyone think of a reason the 540 shouldn't automatically switch to the airfield diagram (if one is available) ANYTIME the aircraft is below flying speed, whether or not it is at the end of flying a published procedure (at startup and after landing)? "
Jim Patton
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2015 at 8:47pm
No, can't think of a reason on arrival, but not necessarily on departure. You may wish to keep a SID as the active chart, even while taxiing.
M20Kid View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M20Kid Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2015 at 1:31pm
+1 on this entire thread.  I would like to have taxi diagrams show automatically whether I loaded an approach plate or not.  The reality of flying for me is that I rarely need an approach plate but I always have to taxi after landing.
I have also wished that I could load an approach on the FMS screen and have that plate preselected on the Map/Charts page.  At a minimum have the destination airport preloaded on the Charts selection page.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2015 at 2:52pm
I think it is better the way it happens now, having PASTE KXXX (your destination usually) as a soft key. You may be looking at another airport, perhaps as an alternate. I wouldn't want that work in progress to disappear when you load an approach. With just one extra keystroke, you have a choice.
Post Options Post Options   Thanks (1) Thanks(1)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2015 at 6:25pm
My vote would be to have a selectable option to have the airport taxi diagram automagically pop up on the runway as you decel through 30 KTS.
Orest's preference could still go forward, as could other options.
This page was generated in 0.045 seconds.
