Taxi Charts question
URL: http://forums.avidyne.com/forum_posts.asp?TID=863
Printed Date: 19 Jun 2025 at 2:24am
Topic: Taxi Charts question
Posted By: FlyingCOham
Subject: Taxi Charts question
Date Posted: 30 Oct 2015 at 11:08am
From page 3-30 of the current 540 draft manual:
"Taxi Charts
If a published procedure was used via the Charts tab for the landing airport, the display chart will automatically switch over to the airfield diagram during post-landing roll out. Your ownship position on the airfield diagram chart will be displayed as an aid in surface navigation."
Question: Can anyone think of a reason the 540 shouldn't automatically switch to the airfield diagram (if one is available) ANYTIME the aircraft is below flying speed, whether or not it is at the end of flying a published procedure (at startup and after landing)?  It seem to me that it only makes sense to view ground data when on the ground.  If the user wants the Map then tap the Map button or lift off again.
Thoughts??
Date Posted: 30 Oct 2015 at 11:44am
Agree.
IIRC the Aspen MFDs do that when <30 kts speed.
Date Posted: 30 Oct 2015 at 12:26pm
The same could be said about approach plates.  Anytime an approach is added to the FMS, the Chart tab should display that chart without the user loading it.
Date Posted: 30 Oct 2015 at 12:40pm
Absolutely.
Posted By: roltman
Date Posted: 30 Oct 2015 at 12:45pm
Yes, I wouldn't mind it if ONE of my IFDs would jump to the local chart when on ground during a startup event or an on ground landing event.  Even if a chart was being displayed or not.
I guess provided you have up-to-date charts since some people are not buying charts.
I wouldn't want both to change, as such I'd like to choose which one changed.
Posted By: compasst
Date Posted: 31 Oct 2015 at 8:06am
I agree with both suggestions - automatically load the destination airport in the charts tab - too confusing and frustrating to have to dial in the airport to get the charts. Sure I can load a proc, but why not have the charts page pre-populated. Likewise on the taxi diagram - something my FlyQ does automatically, although it only does this with plated airport diagrams and not all diagrams like are available on the 540.
Posted By: 94S
Date Posted: 31 Oct 2015 at 12:06pm
+1 & +1
Date Posted: 31 Oct 2015 at 12:28pm
Admin Group, your thoughts??
Posted By: AUXAIR
Date Posted: 31 Oct 2015 at 5:01pm
This would be a very cool feature:  When the destination airport was selected, the charts for that airport would be loaded into the selection box automatically, and would be available for selection once the "Charts" feature was activated.  Perhaps the airport chart would be there first...
David E.
Cessna 182 RG II
Date Posted: 31 Oct 2015 at 5:54pm
Aspen's MFD has an option to automagically display the taxi diagram when airspeed drops below 30 KTS.
Posted By: jhbehrens
Date Posted: 02 Nov 2015 at 4:44am
I find the fact that you have to manually change the airport identifier and then select an approach from the Charts tab when you already have a destination and approach loaded in the FMS one of the few non-intuitive elements of the IFD540 UI.
There is a shortcut to the plate from the FMS page I believe though but somehow thats not the workflow I use intuitively.
Date Posted: 02 Nov 2015 at 6:17am
Yep, just press the chart icon on the destination airport waypoint.
Date Posted: 02 Nov 2015 at 9:29am
There is also a PASTE KXXX soft key, which will fill in with the arrival airport name, once enroute.
Date Posted: 02 Nov 2015 at 10:06am
Let's get back to the original question, "Can anyone think of a reason the 540 shouldn't automatically switch to the airfield diagram (if one is available) ANYTIME the aircraft is below flying speed, whether or not it is at the end of flying a published procedure (at startup and after landing)? "
Jim Patton
Date Posted: 02 Nov 2015 at 8:47pm
No, can't think of a reason on arrival, but not necessarily on departure. You may wish to keep a SID as the active chart, even while taxiing.
Posted By: M20Kid
Date Posted: 06 Nov 2015 at 1:31pm
+1 on this entire thread.  I would like to have taxi diagrams show automatically whether I loaded an approach plate or not.  The reality of flying for me is that I rarely need an approach plate but I always have to taxi after landing.
I have also wished that I could load an approach on the FMS screen and have that plate preselected on the Map/Charts page.  At a minimum have the destination airport preloaded on the Charts selection page.
Date Posted: 06 Nov 2015 at 2:52pm
I think it is better the way it happens now, having PASTE KXXX (your destination usually) as a soft key. You may be looking at another airport, perhaps as an alternate. I wouldn't want that work in progress to disappear when you load an approach. With just one extra keystroke, you have a choice.
Date Posted: 06 Nov 2015 at 6:25pm
My vote would be to have a selectable option to have the airport taxi diagram automagically pop up on the runway as you decel through 30 KTS.
Orest's preference could still go forward, as could other options.
