  New Posts New Posts RSS Feed - 14 volt columbia
14 volt columbia
psimpson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote psimpson Quote  Post ReplyReply Direct Link To This Post Topic: 14 volt columbia
    Posted: 24 Oct 2015 at 9:23am
Any 14 volt Columbia drivers out there?  I have had dual 440's for about 30 hours of flight time and have been looking for a voltage loss.  My USB ports have no power until I've been flying quite a while.  We have checked the voltages and the 440's are getting about 1.5 volts less than the rest of the system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2015 at 3:27pm
Corrosion on a breaker?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2015 at 10:38am
Our Tech Support team would like to get more information from you regarding this issue. At your leisure can you contact them at 888-723-7592 or techsupp(at)avidyne.com?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidBunin Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2015 at 12:38pm
Composite airplane.  How good is your grounding path?  Do your avionics use the same ground reference as the rest of the electrical system?
Post Options Post Options   Thanks (0) Thanks(0)   Quote psimpson Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2015 at 2:21pm
I have been in contact with Tj about this.  I
