14 volt columbia
URL: http://forums.avidyne.com/forum_posts.asp?TID=853
Printed Date: 31 Oct 2024 at 6:46pm
Topic: 14 volt columbia
Posted By: psimpson
Subject: 14 volt columbia
Date Posted: 24 Oct 2015 at 9:23am
Any 14 volt Columbia drivers out there?  I have had dual 440's for about 30 hours of flight time and have been looking for a voltage loss.  My USB ports have no power until I've been flying quite a while.  We have checked the voltages and the 440's are getting about 1.5 volts less than the rest of the system.
Date Posted: 24 Oct 2015 at 3:27pm
Corrosion on a breaker?
Date Posted: 26 Oct 2015 at 10:38am
Our Tech Support team would like to get more information from you regarding this issue. At your leisure can you contact them at 888-723-7592 or techsupp(at)avidyne.com?
Date Posted: 26 Oct 2015 at 12:38pm
Composite airplane.  How good is your grounding path?  Do your avionics use the same ground reference as the rest of the electrical system?
Posted By: psimpson
Date Posted: 26 Oct 2015 at 2:21pm
I have been in contact with Tj about this.  I
