  New Posts New Posts RSS Feed - Autopilot capabilities
Paul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paul Quote  Post ReplyReply Direct Link To This Post Topic: Autopilot capabilities
    Posted: 31 Oct 2013 at 12:21pm
The autopilot in my aircraft, a KAP 140, does not provide GPSS roll steering.  It sounds like the IFD 540 will not give me this capability (although I would like that confirmed by Avidyne).  I can see four choices, in order from most to least expensive:
  1. Install an Aspen PFD.
  2. Install an Icarus SAM.
  3. Install a DAC GDC31.
  4. Don't have roll steering.
Is roll steering is worthwhile in a Cessna 172 with a single axis autopilot?
Which of these could be installed with the IFD 540 in a certificated 172?
The Icarus has a display and some capabilities that the DAC does not.  It also requires panel space which would be difficult to come by.  Does the IFD 540 have features which make the Icarus' extra capabilities redundant?
If I'm going to add this capability I would prefer to do it when the IFD 540 is installed.  That saves on installation costs.  And the pilot won't have to deal with the panel changing twice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2013 at 2:23pm
Paul,
I expect the IFD 540 to behave like a GNS 430W in this respect, and the key to determining your GPSS options will be the capabilities and input requirements of the AP…. but one never knows what surprise Avidyne might have up their sleeves.
I have a 430W and Sandel HSI feeding an STEC GPSS which in turn feeds an STEC 30 AP. The GPSS is a stand-alone unit with just a square push-button on the panel that toggles between 2 modes: HDG & GPSS and determines the nav source: AC/DC heading error or GPS roll steering data. The STEC 30 has 4 roll modes: Stabilizer (which is controlled by turn left/right knob), Heading, and Lo/Hi Track. The AP is normally set in HD mode as long as the 430W is producing GPS roll steering data (i.e. following a flight plan or approach procedure), and the GPSS should be in GPSS mode. The GPS roll steering output is wonderful and will make lovely smooth DME arcs, intercepts, turn anticipation, etc, following a GPS overlay of a VOR/LOC proc. If the GPSS is in HDG mode, then the HSI/DG heading bug output is used if the AP is in heading mode or 430W VOR/LOC AC/DC heading error if the AP is in Lo/Hi Track mode (Lo for VOR, Hi for LOC/ILS). I'm not sure, but I suppose that in this case the GPSS is in a sort of pass-through mode of the heading error signal to the AP.
I'm certain that once you have seen GPSS performance, you won't want to be without it due to the accuracy and functionality of the GPS roll steering data. If I recall correctly, the STEC GPSS was about $1000 and really gets the most out of a GPS. I'm not familiar with the capabilities of the Icarus or DAC units. I don't know if the STEC GPSS unit will only mate with a rate-based AP like STEC produces, but perhaps the AC/DC heading error signal is standardised and accepted by both rate and attitude based AP's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2013 at 4:00pm
GPSS is amazing.
Paul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paul Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2013 at 4:10pm
Originally posted by ddgates ddgates wrote:
GPSS is amazing.
The IFD 540 is (supposedly) amazing.  The amount of money I'm spending on all of this is really amazing.  For the benefit of those of us who have never flown in a GA aircraft with GPSS, could you please provide a bit more information?
phkmn View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote phkmn Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2013 at 5:38pm
GPSS processing takes advantage of the GPS' knowledge of your current and future course, ground speed and ground track.  Combined with WAAS, precise information is available about current location so that a track can be followed exactly.  Turns are anticipated, so there's no overshoot when course changes with waypoint passage.  GPSS will fly accurate holds with crosswinds and with a capable autopilot will make smooth and seamless transitions from enroute to approach modes right to the runway threshold.  You will have to manage your own altitude unless the a/p has a glideslope capability.
As a 530 replacement, I don't consider it reasonable to expect GPSS built into the 540.
Edited by phkmn - 31 Oct 2013 at 5:39pm
PH
Post Options Post Options   Thanks (0) Thanks(0)   Quote MysticCobra Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2013 at 8:08pm
Here's one common example of what GPSS roll steering offers:
Many small aircraft have a single-axis  autopilot that works with a combination of desired heading (where the bug on the heading indicator is set) and GPS CDI needle deflection.  If HI shows right of course, and the CDI needle shows right of course, the autopilot will input a left roll to try to correct.
This setup allows the aircraft to follow a straight course line, but at the next GPS waypoint with a heading change, the pilot needs to adjust the bug on the HI appropriately for the system to track that next, different, straight course line.  This setup will not allow the aircraft to follow a curved path in the flight plan, at least not without the pilot continually adjusting the HI bug, which is not really practical.
With GPSS, the dependency on the heading indicator bug is removed.  Now, with no action required from the pilot, the autopilot can smoothly fly all the turns in the GPS's flight plan, including course reversals, holding patterns, DME arcs, etc.  Pilot just sits back and watches.
It's a very nice feature.  Just expensive.
Edited by MysticCobra - 31 Oct 2013 at 8:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2013 at 7:34am
The IFD540 sends GPSS Roll Steering commands to an autopilot via Arinc 429 (Label 121). Since the KAP140 doesn’t support GPSS nor does it support Arinc 429, you need an intermediate translator to convert the 429 signal into an analog voltage.
So from an interfacing perspective, the IFD540 has no issues with sending roll steering command data directly to either one of those mentioned interface units (GDC31, SAM).
From our perspective, the DAC GDC31 is basically the same solution the Stec65 used to add GPSS support for an autopilot that didn’t have the necessary interface from a GNS430/530. It takes 429 and directly converts that data into a heading command which in turn, gets sent to the autopilot.
The SAM module is a bit more than a roll steering converter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2013 at 5:18pm
I had a SAM module before I got my Aspens.  Works well, and does other stuff as Steve indicated.
I preferred the SAM to the GDC because you can tweak the adjustments...(not saying I did that).
Paul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paul Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2013 at 8:35am
The SAM has a bunch of additional capabilities but the manual seems to say that it is necessary to enter the barometer reading and the altitude of the destination airport at startup.  I don't know if this can be turned off or if it will be disabled if there is no encoder connected to it.  I also don't know if the IFD will provide altitude warnings and other information which would make these capabilities redundant in the SAM.  I don't want to add more steps to the preflight unless they really add benefit.
The SAM has one GPSS feature that the GDC31 lacks.  There is an input on the SAM which the GPS can use to disable roll steering.  The Garmin 430W with newer firmware will do this, and the SAM will announce that it happened.  There is an input on the GDC which indicates that the ARINC data is good, but if it is tripped apparently it will flash in the way it does when it faults.  I don't know if this is a significant limitation.  I also don't know if the IFD puts out the same signal signal since it depends on which version of the Garmin firmware it is compatible with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2013 at 2:29pm
The SAM needs baro input for altitude alerting en route and gear warnings at destination.
If you don't input the baro pressure - IIRC these features are disabled.
Don View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2015 at 12:00am
On this same issue with GPSS
I have an stec 30 installed. And was going to get the GPSS capability added as well
Supported with the ifd ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2015 at 1:03am
I have an stec 30 installed with G430 & stec GPSS. Works great! Awaiting 440 to replace G430 as plug & play, so expect it to continue to work fine... As should the IFD540.
Edited by chflyer - 15 Mar 2015 at 1:04am
Don View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2015 at 9:12am
Thanks CH!! I was reading about it coupled to the 430 and I am coming from a KLN 94
with the 430 the gpss will fly (an ILS/LOC) the out bound leg to a procedure turn ... then the gpss is switched to hdg mode ... and hd bug is used to fly procedure turn... once inbound and on course switching back to GPSS will keep the plane on track and obviously pilot manages the glideslope.
will this be the same with the 540? or with the 540, will the ap being in gpss mode fly the procedure hold...
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2015 at 10:16am
Yup, it'll work fine.   The IFD540 is outputting roll steering signals so that if you have an autopilot that naturally supports GPSS or you have an intermediate interface unit like you're talking about with the STec 30, then you'll be fine.  The autopilot will stay coupled and will fly whatever magenta line the IFD540 is outputting.  In your example scenario, the system will stay coupled all the way around the procedure turn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2015 at 10:20am
The 540 will take you right along the magenta line, entirely through an approach, or along a custom hold, as long as you have GPSS either as a separate module or integrated such as in an ASPEN, driving the autopilot, or an autopilot that can accept direct 429 roll steering commands.
On ILS/LOC and VOR approaches, it will switch to VLOC (unless you suppress that), you would normally switch to the navaid for guidance once established. Inside of the FAF, of course, you must at least monitor the primary navaid for the approach, but for a VOR or LOC only approach (no vertical guidance) you might wish to continue to use GPS/GPSS for driving the lateral autopilot, it will do a better job. On the third hand, if you do that, you might lose the VSR indication that normally appears on a non-precision navaid driven approach.
Edited by oskrypuch - 15 Mar 2015 at 10:29am
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2015 at 10:32am
STEVE,
Which brings to mind a potential feature. Can you add a third option in the "auto VLOC switch" setting? To ON and OFF, also add an ON PRECISION only?
That is assuming that roll steering output, on a non-RNav approach, is not suppressed past the FAF. On an ILS, you must switch to get your GS. But on a straight LOC or VOR, GPSS commands will be more accurate to follow the lateral course. With the 430W I usually did leave it on GPS on such approaches, while monitoring the primary navaid on the second radio.
Edited by oskrypuch - 15 Mar 2015 at 10:35am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2015 at 10:35am
Orest,
To clarify, are you looking for the option to auto switch to VLOC for an ILS but to stay in GPS for a localizer if you chose that new setting?   I'm not sure the light bulb has turned on for me on this one yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2015 at 11:18am
Correct.
Flying an ILS you will always want to switch to VLOC, so as to get a GS indication.
Flying a VOR or LOC (no GS), you could optionally continue to use GPSS to fly the lateral course, it is generally more accurate than following the ground navaid -- keying on the assumption that 540 does not suppress the GPSS availability FAF inwards on such approaches.
I like having the GPS switch to VLOC automatically,, but to do the above, would need to switch it back for VOR and LOC approaches. Having a "PRECISION ONLY" setting for the auto VLOC switch would eliminate the need to manually switch it back for those.
This is not a critical issue, but it might be a nice little thing to add. On the face of it might not be too hard to do.
ALSO, believe I suggested that there be some sort of aural (preferred) or CAS alert that the auto VLOC switch has taken place. Is that something you can do?
Edited by oskrypuch - 15 Mar 2015 at 11:27am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2015 at 11:19am
Correct.
Flying a VOR or LOC (no GS), you could optionally continue to use GPSS to fly the lateral course, it is generally be more accurate than following the ground navaid -- keying on the assumption that 540 does not suppress the GPSS availability FAF inwards on such approaches.
Okay, understood.  I'll add it to the database.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2015 at 11:20am
Yes, also added to feature candidate database.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2015 at 11:20am
Boy, you're FAST, you reply even before I finish editing my message!
Don View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2015 at 11:29am
that sounds great !! thanks for the insight and info. definitely have the GPSS added to must haves !!!!
Maybe find a good deal at sun n fun on the unit!!
Paul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paul Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2015 at 9:34pm
We now have the IFD 540 and Icarus SAM installed in the stack along with the existing KAP 140 autopilot.  My wife flew an ILS approach today and could not get the autopilot to couple.  Everything else seemed fine and she hand flew the approach using the crossed needles on the indicator.
She had tuned the NAV radio in the IFD to the localizer and put it into VLOC mode.  She hadn't entered the approach, just set the airport as a waypoint.
The SAM was set to HDG mode.
The KAP 140 refused to go to NAV mode (or approach mode).
Any clues as to what we're missing?
cavu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cavu Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2015 at 4:53pm
The STEC-30 has two Tracking modes; LOW is for tracking a VOR enroute and the High is for more precision like an ILS and GPS.  If GPSS is mated to the system and an IFD540, is it still important to select tracking HI or LO?
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2015 at 6:30pm
GPSS mode is just HDGing mode, with the heading bug continually tricked out by the GPS navigator to follow the magenta line, the data fed to the autopilot by the GPSS module. When in GPSS mode, you don't set the A/P to NAV HI or NAV LO or APPR modes, you set it to HDGing mode.
GPSS transforms your navigation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2015 at 6:32pm
Agreed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MysticCobra Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2015 at 7:56am
...but if the HI vs. LOW setting is separate from selecting the nav source (VOR / ILS / HDG), then you could probably select either mode, based on personal preference.  The difference is that the LOW setting "smooths out" a noisy feedback signal; the HI setting tries to track the signal precisely (which can result in "jerky" control inputs if the signal is noisy).
The LOW mode may be a more comfortable ride in bumpy weather; the HI mode may result in sharper control inputs as it fights harder to minimize any deviation from the magenta line.
Edited by MysticCobra - 10 Aug 2015 at 7:58am
cavu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cavu Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2015 at 9:11am
I understand that the STEC GPSS system takes any deviation from the magneta line as +- deviation from the "heading bug" position.  In other words, it magically substitutes the magneta line for the heading bug position regardless of the actual heading bug setting on the DG/HSI.
So a couple of followup questions, would MysticCobra be correct or incorrect then?  As there would be no "noise" on digital output from the IFD540, would the STEC-30 even track the magneta line if in HI or LOW position.
Second, if ATC gives me a "turn 20 degrees to the right for traffic", then the procedure would be what, turn GPSS off and roll the actual heading bug to the new heading?
And when time to resume own navigation, select the next point on the FP, then Direct to, then turn GPSS back on?  Or if I simply turn GPSS back on without the "direct to" step, how would the autopilot respond?  A 45 degree intercept to the active leg?
Edited by cavu - 10 Aug 2015 at 9:16am
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2015 at 9:19am
MysticCobra: Magenta line?
I believe the magenta line is the GPS flight plan, not any VOR/ILS CDI signal which is which is what the a/p HI/LO is tracking. If GPSS is engaged then the autopilot is fed the GPS digital signals to keep on the flight plan track (magenta line), converted by the GPSS to analog so the a/p understands them. Even if the 540 is showing VLOC, I believe the GPSS will be feeding the a/p converted GPS tracking commands received from the 540. As I think Orest mentioned, this is likely as good as the LOC signal. If you want to use HI/LO, then you need to switch from GPSS mode to HDG mode (on the Stec GPSS) so that the VOR/LOC analog CDI deviation signals are passed through to the a/p rather than the digital GPS flight plan correction commands converted to analog.
I don't think the GPSS knows, when it converts the 540 GPS digital commands to analog, whether the a/p is in HI or LO modus and I would expect it to generate the same analog CDI correction signals regardless of the HI/LO setting.
Edited by chflyer - 10 Aug 2015 at 9:40am
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2015 at 9:31am
cavu,
Not if you're talking about the STEC GPSS. From the STEC GPSS manual ...
"Engaging any autopilot roll mode other than HDG (i.e. NAV, APR, REV, STB, LO TRK, HI TRK) will decouple the autopilot from the GPSS mode.
With the GPSS mode engaged, the autopilot will not respond to the Heading Bug or Course Pointer."
For the STEC GPSS, in HDG mode, the GPSS converter will pass through AC/DC HDG error signals from the HDG system (CDI/HSI) to the a/p as DC HDG error. In GPSS mode, the GPSS converter will convert GPS bank angle & ground speed input to DC turn rate output to the a/p.
Perhaps other GPSS units function different, but that is how the STEC GPSS and STEC 30 a/p work together.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2015 at 9:38am
cavu,
Regarding your "second, " question, yes. Regarding your last paragraph, you could do as you suggest or just adjust the HDG bug to bring you back onto the magenta line before re-engaging GPSS. If you just engage GPSS again as you suggest, then the a/p will again be fed the GPS correction signals being received from the 540 to get you back onto the magenta line. I'm not sure if this is always 45 degrees but that is approximately what seems to happen when I re-engage the GPSS after a manual deviation from flight plan track via HDG mode and HDG bug. I think the angle depends on the distance off track.
cavu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cavu Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2015 at 10:18am
When in GPSS mode, the STEC 30 computer is receiving input from the 429 bus as DC +- deviations.  Its the same type of signal that is generated when in Heading mode, the only difference is the actual heading bug is point of reference versus the deviation from the magenta line.  When in Nav mode (HI or LOW) the signal is not over the 429 bus at all, so I agree that the GPSS is decoupled when in HI or LO.  It will track only the CDI setting which is not over the 429 bus (as I understand it).
So you've deviated from the magenta line on a "right 20 degrees" instruction, you have GPSS mode set to HEADING.  Now you want to resume course.  Turning GPSS mode back on will do what?  Intercept the magenta line or go direct to the next waypoint?
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2015 at 10:53am
I'm quite sure that the STEC 30 doesn't have any 429 bus input at all. The 429 bus output from the GPS goes to the GPSS which converts it to DC turn rate output to the STEC 30. In both HDG and GPSS modes, the STEC 30 is receiving its signals from the GPSS converter, not directly from the GPS on the 429 bus. That is why the GPSS is needed. It is a 429/232 converter.
The GPSS unit has 2 settings: GPSS & HDG. The HDG setting means that the signals from the heading source (heading bug on the DG/HSI or CDI deviation for a LOC signal) are being passed through to the STEC 30 as you indicate. The GPSS setting means that the GPS signals are being converted to DC turn rate output to the STEC 30.
Turning GPSS mode back on will convert whatever instructions it is receiving from the GPS. So the answer to the question about magenta line intercept or go direct to the next waypoint will depend on the GPS ... i.e. input from the IFD540 in this case. My understanding is that the IFD540 will give instructions to intercept the magenta line but that is probably some sort of algorithm taking into account distance from the current waypoint. It might even be instruction to intercept the next leg if position is very close to or abeam the current waypoint. Maybe someone from Avidyne can answer the question.
Edited by chflyer - 10 Aug 2015 at 10:54am
cavu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cavu Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2015 at 11:35am
I should have been more precise, the STEC-30 receives the signal from the GPSS module via the 429 bus when in GPSS mode.
I don't think this is correct.  When in the GPSS Heading Mode, the signal does not come from the IFD 540 429 bus but from the DG heading bug directly.
I think the GPSS unit is bypassed entirely when the STEC30 is set to HI or LO track mode.  You can have it set to either GPSS or HEADING mode and it will still track the CDI needle.
I've posed the question to STEC folks.  They have to check on it.  I would like to hear from Avidyne on this.  What would be transmitted over the 429 bus in this scenario?
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2015 at 12:06pm
Here is the very high level block diagram of how it works, directly from the STEC GPSS POH:
cavu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cavu Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2015 at 12:09pm
The diagram does not refute my position.  You don't think it does do you?
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2015 at 12:31pm
You are correct and we agree that when the GPSS is in HDG mode, the data to the STEC 30 is coming from the DG/CDI/HSI source and not the GPS 429 bus. But the diagram does indicate that this passes through the GPSS converter and doesn't go directly from the DG/CDI/HSI to the STEC 30 bypassing the GPSS. The STEC schematics also show the DG/CDI/HSI source data going to the GPSS from where they are relayed to the STEC 30. Let's see what STEC says. In any case, there is no direct connection from the heading sources (CDI/HSI) to the STEC 30 in my implementation. I have the circuit diagrams showing the layout. The installation is over 10 years old, so there may have been changes to the STEC GPSS and/or STEC 30 capabilities in the meantime.
cavu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cavu Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2015 at 1:03pm
I think we are almost there.  You keep sneaking in the CDI source going through the GPSS.  If the STEC30 is in Track mode (HI or LO) it does not go through the GPSS unit.  Its data source is directly from the VOR Nav source (confirmed by STEC).  It's only when the STEC30 is in HEADING mode that the signal comes through the GPSS unit.  When the signal comes through the GPSS unit, it comes over the 429 bus when GPSS is selected and from the DG/HSI heading bug when in Heading mode (not the heading mode on the STEC30 but the heading mode on the GPSS unit).  From the GPSS to the STEC30, the signal (whether from DG or IFD) is the same 43mV per degree.
Surprisingly, STEC states that if diverted off the flight plan by selecting Heading mode on the GPSS and then reselecting GPSS mode, the autopilot will take you to the next waypoint not the original GPS course.  I've asked this to be escalated to another person for clarification but that person is out of the office today.
Edited by cavu - 10 Aug 2015 at 1:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2015 at 3:42am
I agree with all that you've just said.
Regarding the STEC statement, I'm not sure how the a/p would know what it's going to get for instructions from the GPS via GPSS.
I use this quite a lot. That is, I fly my GPS flight plan using the a/p and GPSS. It is the cat's meow. But occasionally the GPS plan takes me through some restricted airspace that I need to circumnavigate. As I approach it, I just set the HDG bug on the HSI to one side of it and swap from GPSS to HDG mode. As I approach the edge, I gradually turn the HDG bug back towards the next wpt or some arbitrary flt pln intercept before it. I usually leave it that way until nearly back on the magenta line before I swap back to GPSS mode. If I'm 5 or 10 miles off flt pln track and still a long ways from the next wpt and swap back to GPSS mode the a/p turns back to intercept the flt pln track in relatively short order (doesn't head to the wpt). I didn't notice the exact intercept angle (30, 45, 60), but it is definitely a close intercept of the magenta line and not dct to the next wpt. This behaviour is the same on the IFD540 as it was on my G430.
cavu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cavu Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2015 at 8:49am
Vince, That makes perfect sense to me.  That why I asked STEC to verify their answer.  Going direct to the next waypoint seems counterintuitive.
BTW, watch out for skirting Special Use Airspace.  Controllers' resolution on their scopes is far less than your GPS.  They will violate you for entering the airspace even though you are technically outside it.  Very common occurrence. Most recommend 2 miles.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2015 at 9:08am
..... But occasionally the GPS plan takes me through some restricted airspace that I need to circumnavigate. As I approach it, I just set the HDG bug on the HSI to one side of it and ...
Don't forget, with 10.1 you now CAN rubberband the active leg. You could create a loop around the restricted airspace, and still fly on GPSS!
Post Options Post Options   Thanks (0) Thanks(0)   Quote n7ifr Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2015 at 9:32am
Amazing, isn't it.  This 540 is really spoiling me too.
Tom W.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2015 at 9:40am
Tom W.
You betcha!
Jrlumpp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jrlumpp Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2015 at 10:35pm
has anyone had any issues with the older Piper century autopilot connected to the Avidyne and a Aspen pro 1000. My autopilot flys the complete approach with course reversal perfectly but from the FAF to the missed approach, it flys slightly left of center. It will take me right to the runway, just left of the HSI centerline. The autopilot is in the heading mode with GPSS on . I will try a centering adjustment on the autopilot next. Oddly, it flys to a VOR, or intersection perfectly , dead on. Is there something I'm missing here? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidBunin Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2015 at 8:05am
You should not be in GPSS mode after the FAF.  You should be in NAV or Approach mode for the final approach segment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jrlumpp Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2015 at 8:46am
Thanks for the info. My older century 3 has five settings. Omni, nav, heading, localizer and localizer reverse.
I will try the nav setting to see if it flys the needle after the FAF.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2015 at 9:00am
What you might be seeing is the difference in enroute scaling vs approach scaling that has higher resolution and will therefore show an off course deviation with a greater deflection of the CDI. The deflection may be there when tracking a VOR but not be noticeable where when you are driving down an ILS, LP, LPV you will see the deflection. Usually the autopilot has a set screw that can be turned to center the autopilot.
Edited by Gring - 18 Aug 2015 at 9:44am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jrlumpp Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2015 at 9:44am
I will adjust if needed. What I found confusing, it flew to a GPS intersection perfectly, but didn't hold the needle centered inbound from the FAF. I had it in the GPSS mode the entire time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2015 at 9:49am
Don't think you need to change modes after the FAF on a GPS/RNAV approach.
You would on an ILS of course where you are required to track the localizer.
Switching modes should not be required on a GPS or GPS overlay approach using GPSS.  GPSS will take you all the way to the MAP, and into the missed should you activate a missed approach.
 Switching to NAV or APPR mode could give you problems should you wish to activate a missed approach, FWIW.
bellanca1730a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bellanca1730a Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2015 at 4:04pm
I suspect Gring is correct on what you're seeing, but re: your Century AP, HDG follows a heading input, e.g., a heading bug, while NAV and OMNI follow a course input, e.g., a GPS leg or VOR radial. The difference between NAV and OMNI is essentially in how tightly the AP brackets the course input; NAV is a little looser, which results in more gentle course corrections, while OMNI is a little tighter, which results in more immediate course corrections. Of course, LOC is even tighter for obvious reasons. I have found that OMNI works quite well for shooting GPS approaches. I do, however, like to be a bit more hands-on during turns along the approach, i.e., I like to switch to HDG mode and manually bug the airplane to the next course, then switch back to OMNI, as I have found this to minimize "hunting" after the turn.
Edited by bellanca1730a - 18 Aug 2015 at 4:06pm
Sean Andrews
Bellanca Super Viking
This page was generated in 0.250 seconds.
