AXP340 pirep? |
Post Reply ![]() |
paulr ![]() Senior Member ![]() Joined: 24 Jan 2014 Status: Offline Points: 564 |
![]() ![]() ![]() ![]() ![]() Posted: 16 Jun 2014 at 9:13am |
Does anyone have one of these installed and running? I don't recall seeing any reviews here or in the normal print-media places but I might've missed one...
Gring ![]() Senior Member ![]() Joined: 30 Dec 2011 Location: Kingston, NY Status: Offline Points: 740 |
I have an AXP340 installed in my aircraft, and it works just fine. I had a Garmin 327 previously and the 340 works just the same from a user perspective - key in the assigned code and you're all set, press the VFR key when done. It has a nice timer function and an altitude alert which is nice.
I had an FAA report of the ADS-b output from my setup IFD540/AXP340, and the report came back all green lights. On another form, it appears that approximately 70% of the Garmin installs noted in the thread failed the FAA test and required further action by the user/avionics installation shop.
Edited by Gring - 16 Jun 2014 at 2:15pm |
MikeK ![]() Groupie ![]() Joined: 16 Sep 2013 Status: Offline Points: 87 |
Since the 340 isn't a slide-in replacement for the Garmin, I'd be interested to know how the install went. I have the same Garmin and this would be my preferred way to get the ADS-B out requirement dealt with.
I speced this out with my shop. They said that it is just a matter of punching down new connections, no need to change harnesses, except perhaps adding a data line between the 540 & 340. I already have one from the 330 install, probably most folks do as well.
So, no need to dismantle the panel, maybe half a day's work, and good trade in value on the 330.
* Orest Edited by oskrypuch - 20 Jun 2014 at 3:18pm |
Thanks for that info!
Post Reply ![]() |
Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You can vote in polls in this forum |
