AXP340 pirep?
URL: http://forums.avidyne.com/forum_posts.asp?TID=386
Printed Date: 05 Jun 2025 at 5:53am
Topic: AXP340 pirep?
Subject: AXP340 pirep?
Date Posted: 16 Jun 2014 at 9:13am
Does anyone have one of these installed and running? I don't recall seeing any reviews here or in the normal print-media places but I might've missed one...
Date Posted: 16 Jun 2014 at 2:14pm
I have an AXP340 installed in my aircraft, and it works just fine.  I had a Garmin 327 previously and the 340 works just the same from a user perspective - key in the assigned code and you're all set, press the VFR key when done.  It has a nice timer function and an altitude alert which is nice.
I had an FAA report of the ADS-b output from my setup IFD540/AXP340, and the report came back all green lights.  On another form, it appears that approximately 70% of the Garmin installs noted in the thread failed the FAA test and required further action by the user/avionics installation shop.
Posted By: MikeK
Date Posted: 20 Jun 2014 at 2:43pm
Since the 340 isn't a slide-in replacement for the Garmin, I'd be interested to know how the install went.  I have the same Garmin and this would be my preferred way to get the ADS-B out requirement dealt with.
Date Posted: 20 Jun 2014 at 3:15pm
I speced this out with my shop. They said that it is just a matter of punching down new connections, no need to change harnesses, except perhaps adding a data line between the 540 & 340. I already have one from the 330 install, probably most folks do as well.
So, no need to dismantle the panel, maybe half a day's work, and good trade in value on the 330.
Posted By: MikeK
Date Posted: 14 Jul 2014 at 4:48pm
Thanks for that info!
