  New Posts New Posts RSS Feed - Altitude monitor on AXP340
260SE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 260SE Quote  Post ReplyReply Direct Link To This Post Topic: Altitude monitor on AXP340
    Posted: 14 Mar 2020 at 6:58pm
Does anyone actually wire this up to the audio panel and use it?
It says it’ll alert when more than 200 ft off of the selected (pressure) altitude.  Maybe I’m missing the utility of this function, but 200 seems like a huge deviation, in the IFR world at least.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2020 at 1:01pm
I used it when I had a G* 330ES in the panel.
Once I installed an ASPEN PFD, I never used the 330ES warning again. In any case, the 330ES is long gone.
If you don't have any other altitude warning, I see no reason not to wire it, and use it. Could save your "deviation" bacon some time.
Edited by oskrypuch - 15 Mar 2020 at 6:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2020 at 5:55pm
I have it wired to my audio panel and will occasionally set it.
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote dmtidler Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2020 at 6:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulr Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2020 at 8:04am
Thanks to this post, I finally tried it this past weekend-- worked well, although in IFR cruise on autopilot I didn't need it.
forkauto View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote forkauto Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2020 at 4:59pm
Does the AXP322 have the same option? Thanks in advance
