Altitude monitor on AXP340
URL: http://forums.avidyne.com/forum_posts.asp?TID=1952
Printed Date: 19 Jul 2025 at 9:03am
Topic: Altitude monitor on AXP340
Posted By: 260SE
Subject: Altitude monitor on AXP340
Date Posted: 14 Mar 2020 at 6:58pm
Does anyone actually wire this up to the audio panel and use it?
It says it’ll alert when more than 200 ft off of the selected (pressure) altitude.  Maybe I’m missing the utility of this function, but 200 seems like a huge deviation, in the IFR world at least.
Date Posted: 15 Mar 2020 at 1:01pm
I used it when I had a G* 330ES in the panel.
Once I installed an ASPEN PFD, I never used the 330ES warning again. In any case, the 330ES is long gone.
If you don't have any other altitude warning, I see no reason not to wire it, and use it. Could save your "deviation" bacon some time.
Date Posted: 15 Mar 2020 at 5:55pm
I have it wired to my audio panel and will occasionally set it.
Date Posted: 15 Mar 2020 at 6:43pm
+1
Date Posted: 23 Mar 2020 at 8:04am
Thanks to this post, I finally tried it this past weekend-- worked well, although in IFR cruise on autopilot I didn't need it.
Posted By: forkauto
Date Posted: 23 Mar 2020 at 4:59pm
Does the AXP322 have the same option? Thanks in advance
