  New Posts New Posts RSS Feed - GPS Intrgty Level
GPS Intrgty Level
sto View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sto Quote  Post ReplyReply Direct Link To This Post Topic: GPS Intrgty Level
    Posted: 01 Jan 2020 at 4:25pm
I received a letter from the FAA, they are unhappy with my Source Integrity Level.
See report: https://www.dropbox.com/s/pre3vd0ptcpfh7s/a442b69d-f3c8-4d9f-a52f-83653fd7a20a_PAPR_20191211_A94C5B_416154420%20%281%29.pdf?dl=0
I did some research and it looks like the GPS SRC on the GTX345 needs to be 17-E. The IFD440 serves as the GPS SRC. Would someone be able to confirm this setting?
Many thanks.
chills42 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chills42 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2020 at 9:59am
I'm seeing a very similar issue with a IFD 440 and GTX345. Were you able to get it figured out?
I was told by support that it was due to the baud rate, and having in/out both on RS232 channel 1.  I've messed around with config a bit but I haven't had a chance to fully verify the changes to see if that solves my issues.
Cruiser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cruiser Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2020 at 1:34pm
Many thanks.
this is correct
Post Options Post Options   Thanks (0) Thanks(0)   Quote chills42 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2020 at 7:57am
Thanks for the confirmation. It looks like my remaining issue was having the GTX345 set to Integrity: Auto instead of 1e-7.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cruiser Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2020 at 9:45am
that will definitely not work
This page was generated in 0.054 seconds.
