GPS Intrgty Level
URL: http://forums.avidyne.com/forum_posts.asp?TID=1920
Printed Date: 06 Jul 2025 at 4:08am
Topic: GPS Intrgty Level
Posted By: sto
Subject: GPS Intrgty Level
Date Posted: 01 Jan 2020 at 4:25pm
I received a letter from the FAA, they are unhappy with my Source Integrity Level.
See report: https://www.dropbox.com/s/pre3vd0ptcpfh7s/a442b69d-f3c8-4d9f-a52f-83653fd7a20a_PAPR_20191211_A94C5B_416154420%20%281%29.pdf?dl=0" rel="nofollow - https://www.dropbox.com/s/pre3vd0ptcpfh7s/a442b69d-f3c8-4d9f-a52f-83653fd7a20a_PAPR_20191211_A94C5B_416154420%20%281%29.pdf?dl=0
I did some research and it looks like the GPS SRC on the GTX345 needs to be 17-E. The IFD440 serves as the GPS SRC. Would someone be able to confirm this setting?
Many thanks.
Posted By: chills42
Date Posted: 06 Feb 2020 at 9:59am
I'm seeing a very similar issue with a IFD 440 and GTX345. Were you able to get it figured out?
I was told by support that it was due to the baud rate, and having in/out both on RS232 channel 1.  I've messed around with config a bit but I haven't had a chance to fully verify the changes to see if that solves my issues.
Posted By: Cruiser
Date Posted: 06 Feb 2020 at 1:34pm
Many thanks.
this is correct
Posted By: chills42
Date Posted: 07 Feb 2020 at 7:57am
Thanks for the confirmation. It looks like my remaining issue was having the GTX345 set to Integrity: Auto instead of 1e-7.
Posted By: Cruiser
Date Posted: 07 Feb 2020 at 9:45am
that will definitely not work
