  New Posts New Posts RSS Feed - Shutdown Doesn't Shut Down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Topic: Shutdown Doesn't Shut Down.
    Posted: 26 Feb 2017 at 2:29pm
I have two IFD540s.   Occasionally, it becomes desirable to shut down IFD number one for a reset.
It seems like most times, pushing the power button on the upper left-hand corner triggers the countdown, but it doesn't shut down. The only way to shut it down is to recycle the avionics master.
Is this a hardware problem, a software problem, or something else?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MysticCobra Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2017 at 5:51pm
You should have individual circuit breaker(s) powering the IFD.  You could pull the breaker(s) to just the unit, instead of killing all your avionics.
If you're on the ground, you can also go to AUX > SYS tab > Download Logs key to reboot the unit into the maintenance mode (I think that's what it's called), and then press the "Done" key to reboot back into operational mode.
I'm curious about what causes you to want to reset the IFD, though.
Edited by MysticCobra - 26 Feb 2017 at 5:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2017 at 9:24pm
You need to press and hold the volume button until the counter counts down and the unit turns off, about 5 seconds
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2017 at 11:38pm
But this unit counts down to zero and doesn't shut off even if you hold it more?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2017 at 9:07am
If the unit is not shutting down after the countdown expires, then Tech Support will want to know about it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidBunin Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2017 at 9:36am
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2017 at 9:03pm
Troubleshooting isolation
This page was generated in 0.352 seconds.
