Skytrax 200 - No Winds / Temps aloft data
URL: https://avidynelive.com/forum_posts.asp?TID=2780
Printed Date: 26 Mar 2026 at 6:43pm
Software Version: Web Wiz Forums 12.07 - https://www.webwizforums.com
Topic: Skytrax 200 - No Winds / Temps aloft data
Posted By: firekat
Subject: Skytrax 200 - No Winds / Temps aloft data
Date Posted: 06 Sep 2025 at 5:21pm
I have a Skytrax 200 installed.  I cannot get ANY winds/temps aloft data at all on the iPad, either on the IFD100 app or ForeFlight.
At work I was flying with a guy that has a Sentry, he could share the data coming in with me on my iPad.  The WX display was fast, could pull up winds & temperature aloft, with streakline representation on ForeFlight.
Why cannot I get this info through the Skytrax?  I was on a trip from San Diego area to the San Francisco Bay Area and could not get this information in either direction.  We were up around 11500' on average and getting all other ADSB data, EXCEPT winds & temps.  It would have been very helpful as I was trying to figure out what would be the winds at lower or higher altitudes.  Very frustrating.  Any help would be greatly appreciated.
Date Posted: 07 Sep 2025 at 4:37pm
- Do you have more than one IFD?
- Which IFD port(s) are connected to the Skytrax?
- Is the iPad connected to the network created by the IFD?
Posted By: firekat
Date Posted: 07 Sep 2025 at 8:45pm
Only one IFD
Will have to check which port - directions to do that would be appreciated
Yes, it is connected to the network created by the IFD as it is getting traffic information on both the IFD 100 program and ForeFlight, and both can send flight plans and other stuff to the IFD 440
Could this be settings need to be set in the SkyTrax 200?
Thank you for your assistance.
Date Posted: 07 Sep 2025 at 8:53pm
Go into Maintenance mode (like you're loading databases).  Then go to the config tab.  Take pictures of the RS232 and ARINC429 config pages.  Send them to slindsley at avidyne dot com.
Posted By: firekat
Date Posted: 11 Sep 2025 at 11:09am
Information was sent.  Here is a duplication of those data screens
Main ARINC 429 Config:
          Speed                Data
In 1    Low                Honeywell EFIS
In 2    Low                    Off
Out 1  Low                    GAMA 429 Graphicsw/int
SDI     LNAV 1
VNAV  Enable Labels
Main RS232 Config:
                  Input                                Output
CHNL 1       Off                                   ADS-B (Avi)
CHNL 2       Icarus-alt                         ADS-B+ (G2)
CHNL 3.      Capstone HS Trfc+Wx.       Capstone HS Trfc+Wx
CHNL 4.      Shadin-fadc                      Aviation
Thanks for your help
Date Posted: 11 Sep 2025 at 3:43pm
I got those and am consulting with colleagues.  Stand by.
Forum Software by Web Wiz Forums® version 12.07 - https://www.webwizforums.com
Copyright ©2001-2024 Web Wiz Ltd. - https://www.webwiz.net
