  New Posts New Posts RSS Feed - SAFO1506
SAFO1506
Dlesh123 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dlesh123 Quote  Post ReplyReply Direct Link To This Post Topic: SAFO1506
    Posted: 06 Jun 2015 at 7:27pm
Now that the FAA has decided that they want the transponder ON for all ground operations at all airports, will there be a SB to disconnect the automatic switch from ground to air that switches the transponder from standby to ON?
Or can that be permanently overridden?
Doug
Gary T View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary T Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2015 at 3:56am
From the AXP340 owner manual: p.4 & 5
If the installation includes an automatic air/ground input, such as a gear squat switch, IFD540 speed-based air/ground discrete, or similar external input, the AXP340 will start in GND mode on the ground and will automatically transition to ALT mode during takeoff roll/liftoff.
GND Mode        The transponder is on, but will not reply to any interrogations.The transponder will respond to Mode S ground interrogations from surface movement radar. This mode is only available in installations that send a ground/air discrete signal to transponder.
I believe we will be in compliance with the FAA.
Gary-T
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2015 at 4:55am
Gary is correct. A ModeS transponder (340 included) uses its GND mode for ASDE-X compliance, on the ground. That is preferable to an ALT mode on the ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dlesh123 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2015 at 5:27am
Thanks for clearing that up
