  New Posts New Posts RSS Feed - IFD100 not filling screen the new IPAD
rgav8r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rgav8r Quote  Post ReplyReply Direct Link To This Post Topic: IFD100 not filling screen the new IPAD
    Posted: 15 Nov 2025 at 12:09pm
New IPAD Mini, A17 Pro with IOS 18.7.2, doesn't fill the screen with IFD100 running. It leaves about 1 1/2 inch of the screen blank in landscape mode. I have tried everything I have researched but nothing has worked. My previous IPAD, approximately 3 models earlier worked fine. Any suggestions?
Ronnie Gantt
RG
rpostmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rpostmo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2025 at 2:09pm
Must be a setting on the mini.   My A17 works perfectly.
18.6.2
Edited by rpostmo - 15 Nov 2025 at 2:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote rpostmo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2025 at 2:42pm
Ipad mini A17  now upgraded to 18.7.2
Are you referring to the 1" on the R side of the screen?
The other 3 sides go right to the edge on mine.
It is the same on my mini6.
I don't remember my mini4 to be any different.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rgav8r Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2025 at 7:51am
Yes I am referring to the 1 inch on the right hand side of the screen.
RG
RG
Gary Lutchansky View Drop Down
Moderator Group
Moderator Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Lutchansky Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2025 at 4:41pm
The 6th and 7th generation of iPad mini changed screens from the previous 2048 x 1536 resolution to 2266 x 1488. With the change the ppi remains the same.
I have access to the older resolution iPad mini. The borders around the IFD100 display are barely noticeable. That's good.
We'll look into adjustments for the slightly different screen resolution that your iPad mini 7th generation has. Quite possibly we can update the app to use more of your screen.
Edited by Gary Lutchansky - 18 Nov 2025 at 4:42pm
jwellman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jwellman Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2025 at 5:44pm
I have the same issue on my 6th Gen Mini and 4th gen 11 Pro.
Mini -
- Portrait - Black bar on top and bottom.
- Landscape - Black bar on the right side.
11 Pro -
- Landscape - Black bar on right side.
I don't think there is really anything that can be done besides bringing it to Avidyne's attention.
Here are some screen grabs of the 2 devices:
https://photos.app.goo.gl/VuLaE89sDeEoQfneA
Jared
1954 E35 Bonanza
IFD440
GFC500
Moderator Group
Moderator Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Lutchansky Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2025 at 6:35pm
Photos are very helpful, Jared!
Also, due to your response, I realize that my name has no attribution to Avidyne. I'm a developer at Avidyne. I'll be looking into unused space for the IFD100 displays.
Thank you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote rgav8r Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2025 at 7:58am
Thanks Gary!
Ronnie G
RG
This page was generated in 0.121 seconds.
