  New Posts New Posts RSS Feed - Synthetic Vision not working properly
toddsanderson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote toddsanderson Quote  Post ReplyReply Direct Link To This Post Topic: Synthetic Vision not working properly
    Posted: 07 Nov 2024 at 10:34am
I have a "new to me SR22" that has Entegra PFD/MFD along with IFD 550/440/DFC90 installed.  Everything works great other than the Synthetic Vision attitude display on the 550 is always showing a pitch down display and never changes.  It is this way on the ground or in the air.  The heading is properly displayed, but attitude is wrong.  I did not see any information on calibrating the unit or any troubleshooting in the manual.  Sorry for the sideways picture - new to this site.  Any info is appreciated.
MysticCobra View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MysticCobra Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2024 at 3:21am
Section 7.5.22 of the Installation Manual has the calibration instructions that might help with your situation.
Post Options Post Options   Thanks (2) Thanks(2)   Quote toddsanderson Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2024 at 4:11am
Thank you for the manual. The calibration process fixed the issue.  My installation required a -28 degree offset. The TAS was also not set which I assume helps aid in accuracy in cruise flight.
_phm_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _phm_ Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2024 at 11:29am
Same issue here. Just installed an IFD550, but the shop didn't configure this.
This page was generated in 0.051 seconds.
