  New Posts New Posts RSS Feed - Shadin Digiflo for IFD
Toadpilot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toadpilot Quote  Post ReplyReply Direct Link To This Post Topic: Shadin Digiflo for IFD
    Posted: 18 Sep 2023 at 3:48pm
I have a Shadin Digiflo 91052XP feeding fuel information to my IFDs. I noticed in my IFD configuration it is currently set to Single engine aircraft. When I switch the IFD to Twin, I now have a display for fuel flow and fuel consumption for each engine. I have not tested this with the aircraft running yet, but I am wondering if my IFD will show each engine fuel flow like the Shadin Digiflo does? I will not be able to test this out for another week since my airplane is awaiting a new fuel sender that I had to send in for repair, so I thought I would ask the community.
Edited by Toadpilot - 18 Sep 2023 at 6:01pm
Jeff Hullinger
1964 Piper PA-30 N97VP
IFD550/IFD440/EX500/AMX240/
RDR2100/GMX345/GDL69A/
SKY497/STEC60-2/G5 AI/G5 HSI
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toadpilot Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2023 at 3:18am
I was able to confirm that my IFD 550 does display each engines fuel flow and gallons used since last reset when I enabled multi engine in the configuration setup. I powered up the avionics and turned my fuel boost pumps on to confirm the IFD registered the fuel flow. I am not sure how I missed this option previously, but it is a nice addition to my fuel management tab.
Edited by Toadpilot - 19 Sep 2023 at 3:19am
Jeff Hullinger
This page was generated in 0.063 seconds.
