  New Posts New Posts RSS Feed - No GeoReference on KLAS Taxi Diagram
Aerochip View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aerochip Quote  Post ReplyReply Direct Link To This Post Topic: No GeoReference on KLAS Taxi Diagram
    Posted: 08 Feb 2022 at 9:25am
I've flown into KLAS a number of times recently and my georeference aircraft position does not show up on the EX5000 taxi diagram.  This has occurred on multiple chart updates and I am always using a current chart.  I haven't noticed this problem at any other airports and am wondering if the data on the page is simply too large or if there was something else amiss?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aerochip Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2022 at 1:55pm
Same behavior with maps today. No Georeference on the MFD.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2022 at 3:15pm
If the chart isn't georeferencing, that sounds like a Jeppesen thing to me.  What did you mean when you said "Same behavior with maps"?  Are you saying the MFD map isn't showing your aircraft position?
This page was generated in 0.066 seconds.
