  New Posts New Posts RSS Feed - TOD Callout from IFD100?
D-EACY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-EACY Quote  Post ReplyReply Direct Link To This Post Topic: TOD Callout from IFD100?
    Posted: 22 Oct 2020 at 11:36pm
I installed my 2 IFD440s as slide-in replacements for the 430Ws so I do not have the optional audio cable. I don't really need it, because i get the "500" call from the EGPWS (KGP560) in my SR22 – but what would be nice to have is the TOD chime.
If the iPad is connected to to the IFD by WIFI and to my audio panel (PMA450B) by Bluetooth, is it possible to get the chime from the IFD100 app?
Edited by D-EACY - 22 Oct 2020 at 11:37pm
2006 SR22-G2 DFC90 IFD440
steve.crimm@stephens View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve.crimm@stephens Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2020 at 5:03am
I also did the plug n play option a couple of years ago.  I recently connected the audio wire to my audio panel.  Besides TOD call out I am also getting terrain warnings.
I would recommend you take the time to connect the audio wire, it's well worth it in my opinion.
Vans RV-10
PMA7000BT
IFD440
Dynon Skyview HDX
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2020 at 6:19am
The audio is definitely worth it, and I expect more of the recorded and embedded thousand or so phrases that are available, will be coming alive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-EACY Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2020 at 7:24am
In the Cirrus I have a $20K EGPWS terrain warning system installed - so you neither WANT nor NEED another terrain system. The KGP560 gives all terrain warnings I will ever need and even has its own page on the MFD.
All I want is the TOD chime :-)
Edited by D-EACY - 23 Oct 2020 at 7:26am
This page was generated in 0.180 seconds.
