  New Posts New Posts RSS Feed - AXP340 uncommanded switching from ALT to ON
paulr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulr Quote  Post ReplyReply Direct Link To This Post Topic: AXP340 uncommanded switching from ALT to ON
    Posted: 08 Jul 2019 at 2:24am
Posting for my partner, who's had our airplane for the last couple of trips-- I haven't encountered this firsthand yet.
Apparently our AXP340 will sometimes silently switch from ALT mode to ON mode, which makes ATC get shirty. Manually switching it back to ALT causes it to start broadcasting Mode C again, as expected. I am not sure how often this happens or if there are any other indications, but I wanted to start this thread to open the discussion. I'm planning on having him contact support this week while he's got the plane and I'm OCONUS.
tony View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tony Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 4:30am
You are supposed to wire an air ground line to the transponder and leave it on all the time.  This is to ensure that aircraft are visible to ATC surface surveillance systems at the larger airports.  The days of camera, lights action are over.
Edited by tony - 10 Jul 2019 at 8:20am
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulr Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 5:22am
Yes, I know. This AXP has been working flawlessly since it was installed in 2014, so it's not an installation or user error-- it's a new behavior that just started.
Ibraham View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ibraham Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2019 at 4:16am
It could be an issue with the Altitude Encoder, or accidentally pushing Mode instead of Function button on the transponder (guilty of that, while trying to set the timer on the transponder)
dwcason View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dwcason Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2019 at 2:23pm
I updated to the latest SW version a couple weeks ago. Now my 322 won’t stay in ALT. It automatically switches back to STBY mode (on the ground and in the air). It worked in the way to the shop for the SW upgrade, but hasn’t worked properly since. The shop said the SWAT setting may have been reset during the upgrade. I’ll update when I find out how to check it and if that fixes my problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ibraham Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2019 at 5:41pm
AXP340 Installation Manual
7.5.6 Squat Switch Source
This page was generated in 0.289 seconds.
