Logging on 10.2.3 with Stratus |
Post Reply
| Author | |
allenc3
Joined: 04 Feb 2019 Location: 32043 Status: Offline Points: 126 |
Post Options
Thanks(0)
Quote Reply
Topic: Logging on 10.2.3 with StratusPosted: 26 May 2019 at 12:16pm |
OK, When on the older software, I loaded the Stratus12345 on the aux page, and set to server, I was able to see the IDF100 and Foreflight and move flight plans from foreflight to the IDF440. With the new software update I left the Avidyn derived loggin on Local and added the Stratus12345 to server.
Now however, with the Stratus on, and both ipads selected to Stratus, the IDF 100 does not see the 440, ie the com frequencies are Xed out. However, if I go back to user select and select the Local Wifi with the avidin derived name and password, the IDF 100 logs right on. I can still see Foreflight on the other Ipad, but cannot upload flights from foreflight. What am I missing here? Thanks |
Claude
Ibraham
Joined: 21 May 2016 Location: KHWO Status: Offline Points: 363 |
Post Options
Thanks(0)
Quote Reply
Posted: 26 May 2019 at 3:38pm |
Is the Stratus12345 mode set to "Remote Wi-Fi" in the "Network Configuration" page in the Maintenance mode ,and Stratus selected in the Networking line in the AUX User Options in the flight mode
allenc3
Post Options
Thanks(0)
Quote Reply
Posted: 26 May 2019 at 10:27pm |
Yes,y I did exactly that (Stratus123456) number from the Stratus II device). I did not use a PSK though just like before so where Password is, it is blank. Both Mini's logon without asking for passcode.
Claude
Ibraham
Post Options
Thanks(0)
Quote Reply
Posted: 27 May 2019 at 7:32am |
Make sure the SSID/Name on the Network configuration for the Stratus is exactly the same, mainly low case/upper case characters must match.
allenc3
Post Options
Thanks(0)
Quote Reply
Posted: 02 Jun 2019 at 11:32am |
Well, fixed it. I had Stratus2XXXXX all caps (STRATUS2XXXXX). of course, that did not work, changed to lower case and Working fine now!!
Claude
Post Reply
| Tweet |
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
