  New Posts New Posts RSS Feed - IFR installation in experimentals
matt@bunchlaw.com View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote matt@bunchlaw.com Quote  Post ReplyReply Direct Link To This Post Topic: IFR installation in experimentals
    Posted: 21 Apr 2019 at 5:19pm
Can the owner of an experimental airplane perform the IFR installation and logbook entries of the IFD440?
Matt Bunch
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2019 at 10:09am
It depends.  If the owner is unsure, the answer is probably no.  I would advise the owner to contact the local FSDO to be sure he has all of the proper certifications before starting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote matt@bunchlaw.com Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2019 at 3:48pm
Not following you. Can anyone follow the instructions in your installation manual and still properly check/test/and record all logbook entries in the logbook of an experimental airplane without holding an A&P or IA certificates?
Matt Bunch
rolfe_tessem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rolfe_tessem Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2019 at 3:18am
The repairman certificate you can get when you build the majority of an experimental aircraft has limitations. I believe it is limited to the annual condition inspection...
Rolfe
Tommylewis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tommylewis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2019 at 6:06am
YES!!
Tom Lewis
RV7a & RV10
Granbury, TX
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tommylewis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2019 at 6:13am
YES!!
Tom Lewis
RV7a & RV10
Granbury, TX
Post Options Post Options   Thanks (0) Thanks(0)   Quote rolfe_tessem Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2019 at 4:07pm
5. PRIVILEGES AND LIMITATIONS. Holders of repairman certificates (experimental aircraft builder) may perform “condition inspections” on specific aircraft built by the certificate holder. Consistent with § 65.104(b), the aircraft will be identified by make, model, and serial number as shown on the repairman certificate. During the aircraft certification procedure the FAA issues operating limitations, as necessary per § 91.319, to ensure an adequate level of safety. These limitations may require that the subject aircraft be inspected annually by a repairman (experimental aircraft builder), the holder of an FAA mechanic certificate with appropriate ratings (airframe and powerplant), or an appropriately rated FAA repair station. Condition inspections will be performed in accordance with the scope and detail of part 43, appendix D. Operating limitations will also require that an appropriate entry be made in the aircraft maintenance records to show performance of this inspection. NOTE: It should be noted that the privileges and limitations
This page was generated in 0.232 seconds.
