  New Posts New Posts RSS Feed - Frequency activation Method Problem!
Bill CFI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill CFI Quote  Post ReplyReply Direct Link To This Post Topic: Frequency activation Method Problem!
    Posted: 02 Jan 2018 at 6:04am
Carried over from Garmin.  Once a Frequency was highlighted on the selection list to press Entr to place it into Standby. Yes it works, but it also changes the Maps presentation away from Track-Up at the same time.  Then one must press Entr twice again to return the Maps back to the presentation you had.
A much better method is to double tap the Frequency you want.  This will select it but not change the Maps presentation.  Avidyne logic is interesting!
Bill Schwabenton CFI-I
Beechcraft BE33
Aspen 1000 IFD540 Century 2000
This page was generated in 0.055 seconds.
