  New Posts New Posts RSS Feed - 340/540 Air on Ground Fail
35B33 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 35B33 Quote  Post ReplyReply Direct Link To This Post Topic: 340/540 Air on Ground Fail
    Posted: 12 Jun 2017 at 5:52am
New installation, set up for the 540 pin 8 to the 340 pin 5 and 340 told to use the 540 for pseudo weight on wheels.  Still 10.1.
Air results were fine but Air on Ground got 7.92% Fail, 2.58 Max dT, and 157 MCF.  Home base has a 36' wide runway which means almost a complete stop to make a 180.  Installer has queried tech support but hadn't heard back as of yesterday.
Next steps?  Do I try standby while taxiing and immediately after landing?
Cal Young
AviSimpson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2017 at 10:36am
Can you PM me your tail number and what dealer you are working with so I can ping our tech support team to respond to the dealer?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 35B33 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2017 at 11:48am
Thank you but just got off the phone with the change to make.  Now a test flight.
Cal Young
This page was generated in 0.088 seconds.
