  New Posts New Posts RSS Feed - AXP322 Fault
AXP322 Fault
Ham View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ham Quote  Post ReplyReply Direct Link To This Post Topic: AXP322 Fault
    Posted: 26 Feb 2017 at 1:25pm
I have had some AXP322 transponder problems the last three flights.  ATC tells me to reset the transponder as they are not seeing me.  It is showing in either ground (my home airport has ground radar) as well as in the air (it is showing as Altitude).
I have already notified my avionics shop.   Waiting on action plan.
Has anyone else had issues like this with the AXP322?
LANCE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LANCE Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2017 at 4:39am
Have you tried resetting the transponder with the breaker?
Ham View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ham Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 3:17pm
It was a setting that the shop changed and now it's working OK again.  Resetting the CB would get the transponder back on line, but it was the setting that was causing the error.
This page was generated in 0.095 seconds.
