  New Posts New Posts RSS Feed - IFD100 FltPln xSync
IFD100 FltPln xSync
Bonnell65 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bonnell65 Quote  Post ReplyReply Direct Link To This Post Topic: IFD100 FltPln xSync
    Posted: 24 Feb 2023 at 4:24pm
I’ve read and dug for a solution, but can’t seem to get there. IFD440 running 10.2.4
IFD100 running 10.2
All terrain and map data reloaded
Up to date and same navdata loaded to 440 & 100
Same WI-FI
Units will not xSync the flight plan data
Just frustrated I can’t get it to work after a few hours of time
What am I missing??
ricardo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ricardo Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2023 at 6:48pm
there must be an error on the IFD100 app?  ..  if there is an error, it will give you a hint of whats wrong. -- otherwise i would start by debugging in this order
1 - make sure that the ipad can talk to the IFD 440 --  i would use a different app, like foreflight .. and send / receive a FP from the IFD .. if that works then its not the network config.
2 - verify that the IFD100 on the ipad can access the network, (go to settings then scroll down to the IFD100 app, and check its network permissions) ,verify all settings there.
3 - double and triple check that the nav DB is the same, post photos of the DB page in the aux tab of the IFD440 and iFD100 ...
still not working? .. check out the video about connecting the IFD100 to IFD440
https://www.youtube.com/watch?v=94wfTJmLzCo
do other IFD100 features work? .. such as frequency tuning?
Edited by ricardo - 24 Feb 2023 at 6:49pm
