IFD540/440 Software Release 10.1.0.0
URL: http://forums.avidyne.com/forum_posts.asp?TID=573
Printed Date: 20 Aug 2025 at 2:35pm Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: IFD540/440 Software Release 10.1.0.0
Subject: IFD540/440 Software Release 10.1.0.0
Date Posted: 19 Feb 2015 at 8:44am
Now that software release 10.0.3.0 is approved and starting to hit the field, I'll start this thread that defines and provides updates about Rel 10.1.0.0.
Release 10.1.0.0 is a major update to the IFD540 and the initial release of the IFD440. The two products share the identical piece of software.
In the next 10ish days, I'll also post a draft Pilot Guide for your review (and hoped for inputs). We are still on track to have installed, certified units in folks aircraft prior to Sun-n-Fun.
Here is a list of most of the externally visible changes in Release 10.1.0.0:
The list of changes that you can see:
· 1. Standby comm monitor (needs associated HW mod)
· 2. Remote transponder control/display - this allows control and display of the upcoming Avidyne AXP322 remote transponder.
· 3. ARTCC out to 200nm - change in the Freq List and Nearest algorithm to extend the range of ARTCC freqs in the list (think high altitude aircraft flying in the jet airways)
· 4. Bluetooth & Wifi - Bluetooth is 2-way comm with a properly paired external Bluetooth keyboard. WiFi is initially a 1-way, streaming out of the IFD, capability to certain, to-be-named-later, software apps hosted on mobile/tablet devices. The two-way capability will follow in trail. This area will require separate STC approval from the FAA - we split that out of the main STC so as to not hold up the Release 10.1.0.0 STC for both the IFD540 and IFD440. 5.
· 5. Single row FPL - provides the user with an option to collapse the vertical height of flight plan legs on the FPL to a single row. This is especially useful in IFD440s where there is less vertical display space.
· 6. All vertical constraints shown and at proper geo
spot - expands the current capability by now displaying all vertical contraints visually on the moving map, not just for the next waypoint. And, if there is a vertical constraint, say, 5 nm prior to the waypoint, the depiction is at that 5nm point, not on the waypoint itself.
· 7. Option to pull down heading/track box on map - provides moving map setup option to remove that heading box from display. This frees up (i.e. declutters) the map and might be helpful in IFD440 installations and even dual IFD installations where you have plenty of heading indications as is and may elect to turn it off on one of the displays.
· 8. Airspace aural alerting - adds the user option to turn on aural alerts about impending airspace.
· 9. Rubber band active leg - now permits you to rubber band the active leg in the flight plan.
· 10. ADS-B Wx and traffic - adds support for display of ADS-B In weather and traffic data from a MLB100 (new Avidyne box coming out at approximately the same time).
· 11. Helo TA and FLTA changes - improves the altitude and distance triggers for Terrain Awareness and Forward Looking Terrain Alerts in rotary wing aircraft. No changes to fixed wing, just a more operationally useful set of triggers for rotary wing.
· 12. Other helo optimizations - more helo specific changes such as adding an input from the collective to determine air/ground transitions for transponder state changes, and higher gains in the GPS that are operating underneath a spinning set of rotors, etc.
· 13. FLTA Inhibited/Off message now a blue CAS
instead of yellow top strip - moved the FLTA messages off the top strip and into a standard Caution Advisory System message in bottom right corner.
· 14. Volume page is now touch control too - added touch control to the Audio tab on AUX page.
· 15. Headwind component on Air Data calculator - added a specific callout of headwind to that existing calculator page.
· 16. Fuel planner label changes - improved the labeling of the fields on the fuel planning calculator.
· 17. Departure time now takeoff time, not power on
time - this applies consistency across all the calculator computations and displays.
· 18. FLTA alert during GPS re-acquisition bug fix - suppresses a Pull-Up, Pull-Up call that could be issued during GPS re-acquisition.
· 19. Info page realignment - makes some improvements to the map on the FMS INFO tab and to alignment of some of the data windows to be easier to read.
· 20. TOD when Direct-To IAF - changes the implementation to provide Top-of-Descent capability when proceeding direct to an Initial Approach Fix.
· 21. Mx Mode entry improvements - automatically jumps to the desired tab in Mx mode (e.g. Download Datalogs wakes up on that tab, Database updates wakes up on that tab, etc).
· 22. GPS software load better status indications - improves the field loadable software efficiency when updating GPS-related parts of the code in the future.
· 23. Obstacles now included in ESA - improved the Emergency Safe Altitude datablock to now also include obstacles in the calculation.
· 24. Checklists expanded from 30 steps to 50 steps
· 25. Easy way to reset checklists - added easy ways to reset entire checklist.
· 26. Scrollable datablocks - added the ability to touch scroll the right side datablocks which also means you can add a lot more datablocks than what you can see at any time.
· 27. Don't need baro input for Vertical speed required and wind vector datablocks.
· 28. 5 custom users - added ability to have up to 5 different and uniquely nameable user setup configurations. This applies to datablocks, map configurations, checklists, etc.
· 29. Ability to entry in Flight ID and Default VFR
code when have a remote transponder - new entries in User Options page
· 30. 500' callout on instrument final - added user option to turn on/off the aural "500" call out on final approach.
· 31. Sinking tabs option - added user option to allow the bottom strip of tabs to sink down out of view after a designated timeout. This adds more display real estate and may be helpful especially in IFD440s.
· 32. Approach type in Nav Source knob label - added more detail to the Nav Source label in top right corner. For example, when you are on a GPS-based approach, instead of just the generic "GPS" label, it will tell you the exact approach type the system is flying (e.g. "LPV" or "LNAV/VNAV" or "LNAV+V", etc)
· 33. VLOC nav source label stays yellow until morse
code decoded - designed to give you a little more help in knowing if the system has properly Tuned-Identified-Monitored.
· 34. Sharp intercepts inside the FAF allowed - designed to allow one to still grab glideslope, glidepath deviations on a VFR sharp intercept inside the Final Approach Fix.
· 35. Activate approach changes - tries to improve the algorithm for activating approaches - both Vectors-to-Final transitions and entire published approach.
· 36. Activate VTF changes - ditto.
· 37. LP+V capability added - adds both LP+V approach types and allows Advisory Glideslope ("+V") to work even when system has no air data input.
· 38. Enable Missed changes - provides a user option to have the Missed Approach procedure automatically activate when passing the Missed Approach Point.
· 39. Check Navaid Identifier CAS changes - improves the trigger for that CAS message to also prompt you if you don't have proper nav freq in the system.
· 40. Airspace Ahead CAS message reduction - attempt at reducing nuisance alerts
· 41. Save/Restore capability added for Checklists,
User Settings, Waypoints, Routes - allows you to save all that user setting data on a USB fob for use on other IFDs or later on the same/replaced IFD.
· 42. Direct To changes - some subtle improvements to Direct To behavior.
· 43. Nearest top of list behavior changes - changes behavior to Nearest list such that when you've been off the Nearest page for more than a few seconds, the cursor position will pop back up to top of list (i.e. nearest element)
· 44. Right DCK labeling change - adds more intuitive bottom right knob labeling for the 0.4% of you that actually read those labels.
· 45. Shadin Fuel Flows now all work - fixes a software issue in which some types of Shadin Fuel Flow systems did not properly display on the IFD.
· 46. Cursor centered mode on map - adds a new mode where the moving map will auto pan to be centered on whatever leg in the flight plan your cursor is on. This allows for nice long route previewing.
· 47. Track CDI is now factory default - this was a Maintenance Mode setting that was being set wrong on a number of installations by installers in the field.
· 48. Full Nav triangle is now factory default - the Map page Nav declutter setting will default (from the factory) to full on. You can still change the declutter setting yourselves and that user set value will remain across power cycles.
· 49. Able to take synchro input for heading - adds this new source of heading to the IFD.
· 50. All IFD440 changes supported - a lot of pages were reformatted to be better optimized for the IFD440 display real estate. The software knows if its hosted on an IFD540 or an IFD440 at startup and reformats automatically. There are a number of other under-the-hood changes designed to improve performance. One of those is a higher gain GPS receiver that should further improve GPS signal strength in the IFD.
Date Posted: 21 Feb 2015 at 9:28am
Just updated the initial post above to summarize some of the changes included in Rel 10.1.0.0.
Date Posted: 21 Feb 2015 at 9:53am
My, my. That is a lot of stuff.
Happy to see some of my suggestions (17, 21, 46) implemented. There are a few more! ;-)
Some more comments and questions later, hitting the slopes ...
Posted By: Bad1996
Date Posted: 21 Feb 2015 at 10:07am
A lot of nice adds and changes. My favorites are 13 and 26. Regarding #7, has anyone asked about a second heading box, so that dtk and trk could be in that area and large ?
Also as I was setting mine up yesterday I thought it would be nice if some of the single line databoxes could have an option to be made larger. for example the ground speed.
Date Posted: 21 Feb 2015 at 10:28am
If things are working ok, is it reasonable to not install 10.0.3.0 and wait for 10.1, i.e., 10.1 doesn't have to be installed over 10.0.3.0?
------------- David Gates
Date Posted: 21 Feb 2015 at 11:38am
Yes, that is reasonable and will work.
Date Posted: 21 Feb 2015 at 11:43am
Reference Bad1996 questions, no one has asked about that yet on #7. One technique would be to put those datablocks you ask about in the top strip. While not large font, it would put it in close proximity to the heading box.
On your other wish list item about bigger one line data, that capability does not exist at this time. I'll have to think about it - might be a bunch of software cert work to do it but I'll think about it some more.
Posted By: BobsV35B
Date Posted: 21 Feb 2015 at 3:21pm
Good Afternoon AviJake,
Have you spent any brain cells evaluating my request for adding the capability of installing the updated data early so that it could be exchanged on demand the day of effectivity? Sure would be nice, especially with the two week life of the Jeppesen Approach Chart Data.
Happy Skies,
Old Bob
Date Posted: 21 Feb 2015 at 3:25pm
Yes and it fried every brain cell all of us had. We can't find any way that doesn't involve a nearly obscene amount of work to pull that off with the existing architecture.
Date Posted: 21 Feb 2015 at 4:42pm
You gotta admit, though, it is an excellent idea and somewhat of a differentiator WRT innovation.
Date Posted: 21 Feb 2015 at 5:41pm
Departure time now takeoff time, not power on time - this applies consistency across all the calculator computations and displays. |
For the fuel calcs, and fuel tank flip time, and that sort of thing, that is great. Believe I was one of the ones who requested that.
BUT, is there still a power on time included? I was also looking for a block that would show:
OFF BLOCK (approx. power on time) time TAKEOFF time LANDING time ON BLOCK time
... and then the gravy, in digital hours, a block time (off block to on block) and a flight time (takeoff to landing).
I have to record this for every flight, as I'm sure a lot of other pilots, so it would be nice if it were available all in one place.
Date Posted: 21 Feb 2015 at 5:48pm
5 custom users - added ability to have up to 5 different and uniquely nameable user setup configurations. This applies to datablocks, map configurations, checklists, etc. |
Yay! Also good to see the scrollable datablocks. Perhaps soon the datablocks per phase of flight.
Date Posted: 21 Feb 2015 at 5:53pm
500' callout on instrument final - added user option to turn on/off the aural "500" call out on final approach. |
Very good.
Could we also add an "approaching minimums" field. This would obviously have to be custom set for each approach, with the call out, say 50ft above the set value -- time to look up. I expect this could only work if BARO ALT is available.
Date Posted: 21 Feb 2015 at 5:55pm
Sinking tabs option - added user option to allow the bottom strip of tabs to sink down out of view after a designated timeout. This adds more display real estate and may be helpful especially in IFD440s. |
What gets them to pop back up?
Date Posted: 21 Feb 2015 at 6:15pm
I presume you mean automatic per phase of flight, right? With this change as is, you can name one "Departure", another one "Enroute", another one "Arrival", etc and set them up as you prefer for phase of flight. You have to manually select which grouping you want from the User Options page but it totally supports the phase of flight idea now, just not an automatic selection.
Date Posted: 21 Feb 2015 at 6:16pm
Very good.
We could but we were too scared to attempt that right now. A lot of hair associated with that one that we didn't want to try tackling yet.
Date Posted: 21 Feb 2015 at 6:19pm
AviJake wrote:
I presume you mean automatic per phase of flight, right? .... |
Correct.
We could but we were too scared to attempt that right now. A lot of hair associated with that one that we didn't want to try tackling yet. |
Understood.
Date Posted: 21 Feb 2015 at 6:21pm
We leave a sliver of the top of the tab visible as a visual reminder they are down there so you either touch down near the tabs or touch one of the page keys makes them rise back up.
There are several timing options available - Never (page tabs will always be present), 2sec, 5sec, 10sec, 15 sec.
Date Posted: 21 Feb 2015 at 6:35pm
We haven't altered the existing "Trip Timer" and "Departure Time" timers in that you can select if you want those to be from power on or from in-air.
One of the changes made was in the Trip Planner calculator where departure time will track current time, until takeoff, at which time it automatically changes to take off time.
But, your request is an interesting one and not something I explicitly had in the future feature database so I just added it. It would be a datablock that would show 4 times: taxi start, takeoff, land, taxi stop. The taxi start/stop will probably be a little tricky but we might be able to game it a little (i.e. 1st sign of movement of GPS position and return to that same position +/- a few feet with zero ground speed).
Posted By: sikhpilotmd
Date Posted: 21 Feb 2015 at 7:37pm
Any hints to which apps the wifi will work with? FF just announced compatibility with Dynon Skyview.
Date Posted: 21 Feb 2015 at 7:46pm
No hints (at their request).
Date Posted: 21 Feb 2015 at 8:03pm
Awe Steve, come on, we know Garmin patched things up with you and are going to deploy a special version of Pilot just for us!!! Now you're just holding out on us!
Date Posted: 21 Feb 2015 at 8:52pm
But, your request is an interesting one and not something I explicitly had in the future feature database so I just added it. It would be a datablock that would show 4 times: taxi start, takeoff, land, taxi stop. The taxi start/stop will probably be a little tricky but we might be able to game it a little (i.e. 1st sign of movement of GPS position and return to that same position +/- a few feet with zero ground speed). |
Ah, all very good, a couple of notes ...
If you can't game the taxi start time, then the power on time will be a reasonable proxy. The taxi stop time, well that wouldn't very often be the spot where you started, and you can't really tell when the plane is about to park, so I might just fill in the CURRENT TIME there, once a landing occurs. The datablock will not be consulted until the times are about to be reviewed, and then that current time will be a reasonable proxy for the BLOCK ON time.
Some folks are paid by the BLOCK time, they might not mind if it is a minute or two longer. ;-)
I would just suggest one other addition, two additional fields in that datablock, that of a TOTAL BLOCK TIME and TOTAL FLIGHT TIME in decimal hours. A trivial calculation to make, once you have the above four blocks.
Thanks for your consideration.
Date Posted: 21 Feb 2015 at 8:58pm
Oskry is all over the value adds which could be a part of the IFD series.
Here's one from me, actually an extension of what you already have planned.
I spend far too many hours on the silver tube; happily most times 1C, so I hear a lot coming out of the cockpit on the MD-80s I ride.
I commonly hear their radalt audio: 1000, 500, 100, etc.
I know there are issues with using this for a radalt substitute (mostly legal), but if you are going to do a 500 foot annunciation, why not 1000, 500, then minimums? Wouldn't go to 100 etc as GPS derived isn't that accurate...
My Aspens already annunciate minimums, unfortunately through a Sonalert.
Date Posted: 21 Feb 2015 at 9:01pm
Mx Mode entry improvements - automatically jumps to the desired tab in Mx mode (e.g. Download Datalogs wakes up on that tab, Database updates wakes up on that tab, etc). |
That will surely reduce first time confusion (it confused me), and make it a bit more efficient.
Approach type in Nav Source knob label - added more detail to the Nav Source label in top right corner. For example, when you are on a GPS-based approach, instead of just the generic "GPS" label, it will tell you the exact approach type the system is flying (e.g. "LPV" or "LNAV/VNAV" or "LNAV+V", etc) |
VLOC nav source label stays yellow until morse code decoded - designed to give you a little more help in knowing if the system has properly Tuned-Identified-Monitored. |
I like these very much, more like a Big Boy PFD annunciation. Hopefully we will eventually also see a HDG -> VLOC indicator!
Date Posted: 21 Feb 2015 at 9:03pm
Cursor centered mode on map - adds a new mode where the moving map will auto pan to be centered on whatever leg in the flight plan your cursor is on. This allows for nice long route previewing. |
And I love that you added this suggestion.
Posted By: GMSutton
Date Posted: 21 Feb 2015 at 9:10pm
4. Bluetooth & Wifi - Bluetooth is 2-way comm with a properly paired external Bluetooth keyboard. WiFi is initially a 1-way, streaming out of the IFD, capability to certain, to-be-named-later, software apps hosted on mobile/tablet devices. The two-way capability will follow in trail. This area will require separate STC approval from the FAA - we split that out of the main STC so as to not hold up the Release 10.1.0.0 STC for both the IFD540 and IFD440. |
You In ForeFlight Mobile 6.7, released last week, ForeFlight Connect establishes wireless connectivity between ForeFlight Mobile and the Dynon Avionics SkyView system. To quote ForeFlight, "The integration with Dynon Avionics enables Wi-Fi connectivity between your iPad, iPhone, and the SkyView glass panel systems. ForeFlight can send and receive flight plans when connected to SkyView, receive SkyView GPS and AHRS data to feed Synthetic Vision and the moving map display, record flight data, and upload flight data to the cloud."
I hope Avidyne is talking with ForeFlight about similar connectivity between their software and the IFD540!
< ="cosymantecnisbfw" co="cs" id="SILOBFWID" style="width: 0px; height: 0px; display: block;">
Date Posted: 21 Feb 2015 at 9:22pm
Steve, I thought you had said the ability to have the georeferenced aircraft to remain centered on the approach plates would be included in 10.1, however, I didn't see it listed. Am I just not seeing it or didn't it make it into the next release?
Date Posted: 21 Feb 2015 at 10:35pm
And I don't see the much awaited Avidyne Plantain (Boeing Banana) nor a FIX PAGE, but I'm sure they are just in the wings! Right? ;-)
P.S. For those that don't know ...
- The Boeing Banana - distance to climb/descent restriction, drawn on the screen with a 20* circle segment - FIX PAGE - custom user specified radials and circles, dynamically shown on the display, around user specified waypoints
Date Posted: 22 Feb 2015 at 9:41am
I was wondering when orest was going to bring up his banana again. Once that thing gets implemented, it will be forever known as the orest banana..... :)
just teasing Steve, don't you think that would be appropriate to call it the orest banana in the release notes?
Date Posted: 22 Feb 2015 at 9:50am
just teasing |
I would be forever humbled!!
Posted By: bellanca1730a
Date Posted: 23 Feb 2015 at 8:05am
tony wrote:
....Steve, don't you think that would be appropriate to call it the orest banana in the release notes?
+1
------------- Sean Andrews Bellanca Super Viking
Posted By: Leonard
Date Posted: 23 Feb 2015 at 9:47am
bellanca1730a wrote:
+1
+2
Posted By: mkellock
Date Posted: 23 Feb 2015 at 10:18am
Mike |
Me too :)
------------- Piper Archer II PA28-181 Tampa, FL
Date Posted: 23 Feb 2015 at 10:31am
And this one is quite nice, makes rubber banding much more useful.
Date Posted: 23 Feb 2015 at 11:08am
AviJake wrote:
No hints (at their request). |
Can you state how many vendors you are working with for a certain capability and if you are pursuing others or not. Such as:
ADS-B, 1 vendor, no others planned
Flight planning, 1 vendor, 2 additional in discussions
It would be nice to have this now, but it's not really needed until you release the capability. The reason I'm asking for this is because people may buy hardware / software based on connectivity, but may already be set up for something that is in the near future, but not yet announced. Personally, if you said ForeFlight and you were not pursuing anything further, I may consider an iPad. If you said ForeFlight and another in discussions, I'd hold out hoping for an Android solution such as iFly.
Date Posted: 23 Feb 2015 at 5:17pm
No, I'm afraid not. I'd love to spill the beans but our partners are adamant they don't want the info leaking out until it's downloadable and available.
Date Posted: 23 Feb 2015 at 5:18pm
No, I'm afraid that did not make the cut for 10.1 for schedule-driven reasons.
Date Posted: 23 Feb 2015 at 5:20pm
David |
We do have all those aurals recorded and actually in the IFD540 from day 1. We just haven't provided a means for triggering those additional alt-based callouts. The 500' one is the next baby step toward full certified TAWS so that's why I picked that one.
Date Posted: 25 Feb 2015 at 8:50am
(IFD540/440 Release 10.1.0.0 Status Update - 25 Feb 2015)
Bottom line first - we are still on track to be shipping certified 10.1.0.0 software and new IFD440 systems prior to Sun-n-Fun.
We have eaten up about a week of our schedule slack in the past week or so but that still leaves 3-4 weeks for the FAA to process the submission package prior to SnF.
On the hardware side, we ran into a problem on the IFD440 environmental vibration testing where the cam latch that secured the unit in the tray was not robust enough so we had to make a minor mechanical design change to deal with that. All set now.
On the software side, we're a matter of hours away from starting official software test-for-credit which is a good thing.
Flight test is going well - the items it is uncovering are all minor and most are being deferred to later releases.
So far, so good.
Date Posted: 27 Feb 2015 at 9:23am
(IFD540/440 Release 10.1.0.0 Status Update - 27 Feb 2015) I've just published a draft version of the IFD540 Release 10.1.0.0 compatible Pilot Guide. It's available for download at: http://www.avidyne.com/support/downloads/ifd-series.asp" rel="nofollow - http://www.avidyne.com/support/downloads/ifd-series.asp Look for the one titled, "IFD540 Pilot's Guide Release 10.1.0.0 Draft". Every word I changed or added is currently highlighted in yellow for easy finding. I will remove the yellow highlighting and put in change bars only for the final copy. I haven't updated the page numbers in the index yet - I'll do that last. There were a few motivations for posting this draft: 1. Give folks a good sense of exactly what's changing from a user's perspective; 2. Give people a chance to review the changes and provide input before it's locked down and sent to the publishers for printing. We have roughly 2-ish weeks before I hit that point so any input you'd like to send my way would be most appreciated. Since it could end up clogging up this forum easily, I'd ask that if you want to send input, please use my email address ( mailto:sjacobson@avidyne.com" rel="nofollow - sjacobson@avidyne.com ) for that feedback. I expect to post a draft of the IFD440 variant in about a week's time.
Date Posted: 03 Mar 2015 at 2:05pm
I posted this over on the Beechtalk website as my user perspective on the new features.
I loaded up 10.1.0.0 and have had a chance to play with it. This is the first real functional enhancement release for the IFD540 and initial release for the IFD440. The list of feature enhancements on the first page is a good list, but I wanted to take a minute to talk about how these features fit into real world usage.
Standby Comm monitoring - This feature allows you to use 1 IFD and have it act like two flip flop radios where you can hear ATC or Unicom on a primary channel and ATIS or ASOS on the stand by using a single device. Ok, So What? Well, it allows you to take advantage of the freq nominating and with two buttons listen to a second frequency. So, it isn't so much the stand alone feature as it is an integrated package. Those with 2 IFD devices can listen to four frequencies at the same time.
Single Row Flight Plans - The current multi line waypoint in the IFD has a lot of good information, but in an IFD540 you can only see 4-5 waypoints. This is usually sufficient, but if you wanted to see more of the flight plan, you previously could not. The Single Row flight plan option allows you to see 2-3x the number of waypoints in the flight plan, and if you have 2 IFD devices, then you might have one set to normal and the other set to single row. It is a welcome option
Removal of the Track Box and hide tabs options - Its all about the real estate! I use the track information in a datablock and rarely use the large track box at the top center. We can now remove the box and gain back the real estate. Likewise, the tabs at the bottom can now be auto hidden like your windows 7 task bar. I set mine to disappear after 5 seconds, but I think I'll shorten it to 2 seconds. Similarly, The FLTA Inhibited message at the top now goes to a CAS message and frees up that top line for more data blocks. I really like these features because I am a KISS kind of guy and don't really need all that information on the screen and what I really want to see is the MAP.
Updated Air Data Calculator and Fuel Planner - I use these features all the time and they have been reworked for clarity and added function to compute the headwind component. Very good functional enhancement.
Checklist improvement - If you use the checklist function, they have made it significantly easier to reset the checklist and have added more allowable line items. I'd like to see the ability to reorder the checklists, but that is in the feature request database for now.
VSR function now works without a Baro input which is very nice, and now functions like the G430/530 function from that standpoint. Combined with the existing TOD chime, and ability to add constraints on multiple waypoints and have the crossing altitudes display on the map at the proper location, it completes this function.
Multiple user profiles - If you have a flying club, or a partnership, not everyone will want the same options and configuration. You can now define up to 5 profiles which is great. While I am a sole owner an pilot of my airplane, if I were in a partnership, we could have a Geoffrey profile where I go into user settings and change it to my name and I'm off flying with my known setup without worrying about who changed what. Similarly, if I was the airplane officer in a club with 50 members, I could create 5 profiles for users to choose from. Very nice and insightful on how these units might be used.
TAWS component addition - They added the 500ft callout which I like because on a normal pattern, I generally want to be 500ft as I turn final and this is just a mental reminder of where I should be - when. In addition to this callout, there is smart aural airspace alerting available. I've turned this off as I generally know where I am and what airspace I'm in. However, if I were flying in unfamiliar busy territory, I would most likely turn this feature on.
Scrollable Datablocks - I like this one, especially for single IFD installations where you simply want more information than there is space. Now you can scroll the right side. On my dual install, I can now add the traffic thumbnail on the right side which I don't have displayed anywhere now. This is important because it is the only place where I can see what mode the TAS620 is in and change it if required. Previously I had to rely on it autoswitching and then couldn't change the mode if I needed to.
Save user settings/checklists/etc. - This is a tremendous features. When I upgraded to 10.1.0.0 I lost all settings (which makes sense given what is changed in the box software) and it would have been nice to be able to load up my settings. Well, with the new version this is now available. So, if you have your box upgraded from 10.1.0.0 or sent back for repair, you can save and load your personalization to the box. Awesome time saver for both avionics techs and users alike.
Approach changes - I have not flown any approaches with it yet, but there are a number of enhancements here that help provide information about what the unit is doing, or about to do. I'll report back once I have a chance to fly an approach or two.
The rest of the changes not mentioned I'm sure are important, but they didn't strike me the way the ones above did. When I get a chance, I'll post some of the features new compared with the old look, but it probably won't be until after this weekend.
Posted By: sephi
Date Posted: 04 Mar 2015 at 1:19pm
Does anyone know a rough release date for this?
Date Posted: 04 Mar 2015 at 1:21pm
They have said they are targeting before Sun-N-Fun.
They are saying before Sun n Fun in April
Date Posted: 04 Mar 2015 at 1:26pm
Just read up a bit and check the Feb 25 post by AviJake... the part highlighted in bold.
Posted By: Don
Date Posted: 06 Mar 2015 at 11:41pm
Is there any way to have the VSR operable and working in the 10.0.3.0 update? And where can the baro input be located ??? Reading thru the manual i can't seem to find that .
Posted By: Don
Date Posted: 07 Mar 2015 at 1:16am
I found the answer to the question on another thread ... I thought there was a manual entry for baro when setting up an approach (my last GPS had that) and thats what i was looking for .. I will wait patiently for the 10.1...
Date Posted: 07 Mar 2015 at 9:43am
(IFD540/440 Release 10.1.0.0 Status Update - 7 Mar 2015)
Trucking along nicely. Still expecting to be certified and shipping prior to Sun-n-Fun.
We've started and completed for large sections software test-for-credit on the system already which is ahead of internal projections.
If testing goes well this weekend in the environmental chamber, we should be all done with hardware qual testing by Monday which is about a week behind projection but won't have any impact on final cert date.
Trying to bring the FAA test pilots in for an evaluation bench and flight session in the next week or so - they have determined they want to retain cert approval for some elements of the system instead of fully delegating. May not be a big deal presuming their schedule availability has plenty of holes. Expect to have the draft IFD440 Pilot Guide available for review and commenting on this coming week. Sent the updated IFD540 Pilot Guide to the printers after getting helpful input from a number of folks (thanks for that!).
Posted By: SB Jim
Date Posted: 16 Apr 2015 at 9:54am
Hi Jake,
Sun 'n Fun is coming soon.
Any update on 10.1.0.0?
Regards, Jim
Posted By: JBR
Date Posted: 17 Apr 2015 at 1:21pm
Will 10.1.0.0 allow the track box to be displayed in its current position on the map page at all times?
Date Posted: 17 Apr 2015 at 1:22pm
Yes, you will have the option to display it full time or remove it full time from the map.
Posted By: JBR
Date Posted: 17 Apr 2015 at 7:40pm
I just noticed that the draft of the new Pilot Guide omits the "intruder track" in both the text and diagrams. If in fact the intruder track will not be displayed, that is absolutely unacceptable.
The present version of the Pilot Guide shows the intruder track being displayed on the 540. Furthermore, your tech support has repeadedly told me that the intruder track should be displayed although it is not displayed on my very recently installed 540.
It is in Avidyne's interest to resolve this situation immediately.
Date Posted: 17 Apr 2015 at 8:03pm
JBR:
If you are talking about depiction of TIS-B traffic from an ADS-B receiver, Steve posted elsewhere on this board that they went down that road and as they are working on 10.1.0.0 cert through the FAA, an unanticipated objection arose from the Feds, so they are pulling TIS-B out of 10.1.0.0 (disabling it), and are going to work on that as a separate (but vigorously prosecuted) cert.
If you are talking about something else, never mind...
Posted By: roltman
Date Posted: 17 Apr 2015 at 8:28pm
David, I think you meant TIS-B as that was removed. FIS-B is the Wx aspect which will be in 10.1.0.0.
Date Posted: 17 Apr 2015 at 8:46pm
roltman wrote:
David, I think you meant TIS-B as that was removed. FIS-B is the Wx aspect which will be in 10.1.0.0. |
Yessir, you are right. My bad, thanks.
Posted By: JBR
Date Posted: 17 Apr 2015 at 8:53pm
I am talking about TIS traffic from a Garmin 330 transponder. See page 3-26 of the current Pilot Guide.
Posted By: JBR
Date Posted: 17 Apr 2015 at 9:11pm
On February
27, 2015, AviJake
posted "Look for the
one titled, "IFD540 Pilot's Guide Release 10.1.0.0 Draft. Every
finding." (emphasis added) He certainly
changed words describing the intruder track in the traffic display, but he did
not highlight the changes in yellow or otherwise. Furthermore, in his elaborate
description of the changes in Software Release 10.1.0, he never
mentioned the absence of an intruder track.
On my previously installed Garmin 530, I relied heavily on the display of the
intruder track and found it to be essential in the heavily trafficked areas in
which I normally fly.
As stated previously, this situation is unacceptable.
Date Posted: 18 Apr 2015 at 6:52am
The IFD540 does not support the TIS Track Lines. TIS traffic will show up on the display but not the TIS track lines.
Posted By: 310pilot
Date Posted: 18 Apr 2015 at 9:26am
Very disappointed to learn that TIS B traffic is not included in 10.1! Also, note that TIS A traffic (from a Garmin 330) will display on the IFD but the IFD will not display "Traffic Not Avail" when outside TIS-A coverage areas. This sets up a unsafe scenerio where you think there is no traffic but there actually is
Date Posted: 21 Apr 2015 at 9:26am
(Release 10.1.0.0 Certification Status Update - 21 Apr 2015)
It's not done yet. The FAA is actively working the project and there is quite a bit of back-and-forth of data and question answering between us the the FAA reps. Just the usual drill and nothing scary at this point.
Not clear on estimated sign off date/time yet.
Posted By: TomG
Date Posted: 04 May 2015 at 2:39pm
Any updates on 10.1/MLB releases?
Tom Goodwin
------------- Tom G
Date Posted: 04 May 2015 at 2:58pm
Nope. Still waiting.
Posted By: pburger
Date Posted: 05 May 2015 at 9:32am
Steve/Simpson,
I was disappointed to learn that ADS-B traffic support was dropped from 10.1. I currently have XM weather in the cockpit, and was eagerly awaiting the MLB-100/10.1 release to get the ADS-B traffic and weather.
Is there a target for the implementation of traffic? Is it coming this year? Will it be handled as a single item with priority, or will it be lumped with a bunch of other items and pushed to the next rev somewhere down the line?
Date Posted: 05 May 2015 at 5:25pm
Yes, it's coming this year. It is lumped in with a bunch of other features. ADS-B traffic has it's own TSO and to be TSO compliant means creating what the FAA and cert authorities recognize as a "Major" (as opposed to the much lower overhead and company self-certifying "Minor"). The overhead involved with a major is, well, major. It makes much more sense to group several items into one "Major" instead of having multiple "Majors".
Posted By: Bad1996
Date Posted: 06 May 2015 at 12:39am
So the 540 does no traffic (ADSB) at the moment ? What is displaying on the sim ?
Posted By: jhbehrens
Date Posted: 06 May 2015 at 2:34am
It does have traffic: TIS or TAS
Posted By: roltman
Date Posted: 08 May 2015 at 2:18pm
So no feedback from FAA on this 90day stuff?
Based on my math July 5th is the magic date for 10.1.0.0. based on their 90days. Unless it is 90 business days at which point it'd be Aug 12th.
Date Posted: 08 May 2015 at 8:52pm
you can't schedule unbridled regulators.......
July 5th or 90 days doesn't mean anything. They will get to it when they want to.
Date Posted: 08 May 2015 at 9:20pm
Tony's right...it's government...
Reasonable expectations do not apply.
Avidyne should be able to put out ..our software upgrade.
The FAA approval process is for job preservation.
Posted By: SB Jim
Date Posted: 15 May 2015 at 10:16am
Jake,
I can't recall if I posted this previously, but my CNX 80 has a data card large enough to hold 2 sets of data.
When data updates are released one can download them to the datacard and the current data remains. The unit automatically selects the appropriate data on startup based upon date.
Regards, Jim
Posted By: BobsV35B
Date Posted: 15 May 2015 at 12:37pm
Hi Santa Jim, It is amazing that those UPSAT engineers figured out how to do that better than ten yeas ago and Avidyne cannot do it today!
Happy Skies,
Old Bob
Posted By: TomG
Date Posted: 15 May 2015 at 12:59pm
So true, but remember UPS developed this stuff for their aircraft fleet, and then sold it to GA. Then they couldn't make enough money to keep the Corp happy so they sold the Company. UPS has a market value of some 90 BILLION $ and Avidyne is 0.01% of that, MAYBE. Just Sayin. And the software interface is still much better then GARMIN, who also have gobbs more RD money then Avidyne.
In terms of R&D effectiveness I will take Avidyne any day.
I am confident they will get there.
Good stuff,
Tom Goodwin
------------- Tom G
Posted By: TomG
Date Posted: 26 May 2015 at 1:27pm
Any chance we could get some kind of update on the current status of the update? Has the AD changed or had any effect on what was planned for the release? Things looked like they were progressing quite nicely, and now it has gotten very quiet.
Best regards,
Tom Goodwin
------------- Tom G
Posted By: scott
Date Posted: 26 May 2015 at 2:49pm
Yes some news would be great.
Date Posted: 26 May 2015 at 5:26pm
(Release 10.1.0.0 Certification Status Update - 26 May 2015)
The updated documentation package that addresses the AD-related issue was submitted to the FAA today. That wraps up all updated TSO submission data. The last of the updated STC submission data should be in FAA hands on Wed 27 May. A lot of the data had to be updated and reflown when the software was updated to resolve the AD issue.
The FAA is highly motivated to review, and if in their opinion it is warranted, issue approvals very quickly.
Posted By: TomG
Date Posted: 26 May 2015 at 5:44pm
Steve-
Thanks for taking the time to update us. This forum and the communication it fosters, is one of the reasons I made my decision to purchase the IFD 540. And very much looking forward to the MLB100.
Tom
------------- Tom G
Date Posted: 26 May 2015 at 5:46pm
Thanks Tom, we're glad you did.
I do like this forum. We try to keep it no BS and I'm really glad all the rampant speculation and bullying that goes on in other forums does not occur here.
Date Posted: 26 May 2015 at 8:53pm
The FAA is highly motivated to review, and if in their opinion it is warranted, issue approvals very quickly. |
Once this is approved and 10.1 is available, will Avidyne be announcing their selected WiFi Bluetooth partners or will that happen at a later date?
Date Posted: 27 May 2015 at 8:17am
We won't(likely) announce those
until the wireless functionality is approved by the FAA since we don't know how long this will still take, and you can download the apps in the various Apps stores (that part is at the request of the WiFi partners).
Date Posted: 27 May 2015 at 8:50am
OK. I had thought that when the FAA approves 10.1 this included the WiFi. It seems this is a separate approval then. Will it be a separate software upgrade to activate the Wifi when it is approved?
Date Posted: 27 May 2015 at 9:12am
The wireless (Wifi + BT) was originally scheduled for for the 10.1 release I believe. So as not to hold up 10.1, it was broken out of 10.1 when it became evident that the FAA would need more time to get the wireless approvals done.
Posted By: pburger
Date Posted: 27 May 2015 at 11:09am
Wow! That's a new one on me. I must've missed it.
I remember when they delayed the ADS-B traffic display, but now the BT keyboard and WIFI to the mystery vendors is delayed, too?
My recollection was that the wireless was put off from the original certification to get to market quicker, but I sure thought the WIFI and BT were some of the big selling points of 10.1.
To quote Tom Petty, "...the waiting is the hardest part..."
Posted By: KIM
Date Posted: 27 May 2015 at 11:43am
Maybe we can get a actual and final list of changes ? I hope we europ. pilots do not wait in vain!
------------- Klaus
Date Posted: 27 May 2015 at 2:28pm
I think we all had the same expectation.
The run up was that a big reveal would happen at SNF which would include a more robust 10.1, WiFi, BT, and tablet app vendors.
Now it looks like 10.1 is largely GPS fixes, or at least that is my impression.
Date Posted: 27 May 2015 at 2:35pm
David, that is not the case at all. I'm running 10.1.0.0 and there is substantial functionality & usability improvements in this release beyond the expected WIFI and BT capability.
Date Posted: 27 May 2015 at 4:30pm
ddgates wrote:
....Now it looks like 10.1 is largely GPS fixes, or at least that is my impression. |
DD,
Have a look at the first post in this thread. There are 50 change items listed for 10.1
Sure, we'd all love to see the wifi/BT in, but I understand why it was deferred.
Date Posted: 27 May 2015 at 6:15pm
Orest/Gring:
I am aware of the shopping list, which after revision does some interesting things, but doesn't hit it over the fence. The big hitters were new technologies using the embedded BT/WiFi access points.
If you want to correct me, consider:
There were announcements, and announcements, with the "coming soon" banner - all to be done before SNF. WiFi, BT keyboard, apps to drive off the 540, TIS-B traffic, etc.
Better to avoid the "coming soon" rhetoric. Companies get called to task on this. Better to under promise and over deliver, rather than the reverse.
Some of us bought a fair amount of equipment and have limited flying careers temporally.
David G.
Date Posted: 28 May 2015 at 2:36am
The reality I fear is that the 540 is still so buggy that focus has to be on quality first.
Date Posted: 28 May 2015 at 9:32am
jhbehrens wrote:
The reality I fear is that the 540 is still so buggy that focus has to be on quality first. |
Agree, my bigger fear is that if the are STILL GPS problems after 10.1, then people aren't going to trust that they'll be fixed in the next release like we've heard before.
Posted By: cajungene
Date Posted: 28 May 2015 at 10:36am
Just started having issues with my 540. I was doing a IPC and planned to show off my box to my CFI. Well the box went into "Coast Mode" and had to re power it twice. Stayed up for about 15 mins then lost GPS again twice more. Lost lock 5 times in a 1.6 hour flight. Not good. Called tech support and will be sending in logs. Looking at the forum this scares me to death since it appears that this is not an uncommon issue. I had a GX-60 that was rock solid for over 2000 hours and replaced it with the 540. Thank god this happened in VFR and not on an LPV approach in the clag at night. Hope that the logs tell the tail. Not sure I can afford all the AOG time that it appears I will have to go thru to get to the bottom of this.
For you folks that have had to go thru these issues have you got any suggestions on what the issues might be or what the solution was beside swapping boxes?
Gene
Posted By: ksdoc
Date Posted: 28 May 2015 at 11:59am
Gene
Gene, Unfortunately, welcome to the club you never wanted to join! My journey has been long, as recorded in another thread. I finally gave up and swapped back to the G530. Then my installer worked with another plane having the same problem, and came up with the idea to replace the antenna. Seemed to work in his plane, so I flew back up there, replaced with the 540 and got a new antenna. Well, it 'seemed' to work initially, but is now back to the same issue: Will not lock on GPS unless it is repowered at least once. I would not recommend you swap out for a replacement 540, as I did three times, unless the logs or tech identifies a specific problem with your unit. I would send all the logs to tech support and then keep on them for an answer, did they find anything? They are helpful, but you have to keep engaged with them to get answers. You might try replacing the antenna, but there are no guarantees. Make sure the cable is WAAS approved. Sounds obvious but the other plane above did not have the right cable as he expected. I have been told that the new update WILL correct the issue, as it is a pretty widespread problem, from what I gather on this site and others. SO, I'm waiting like everyone else for the release, and expect it to correct the problem. Good luck Larry
------------- kansasdoc
Date Posted: 28 May 2015 at 12:11pm
Larry thanks for the encouragement and guidance. Flew it for over 25 hours with no issue at all and now this pops up. Hope it was an anomoly, but looking at the posts I'm not so sure. As for the cable how do you tell if one is "WAAS Approved"?
Gene
Posted By: ksdoc
Date Posted: 28 May 2015 at 12:19pm
It is what my installer told me, so I would ask yours. I had a WAAS 530 before, and the cable was correct. In the other case, it wasn't, which was a surprise to the owner. Your experience is similar to mine. I only had dropped GPS while flying. Then, in the last month, it would'nt even boot up at all, no signals. It was so bad that I had to reboot 4-5 times before it captured. After replacing the antenna, it now only needs 'one' reboot. I say that with frustration, it should do it first time EVERYTIME, like the 530 always did.
Date Posted: 29 May 2015 at 7:30pm
I'm glad they are motivated to review, but if data had to be resubmitted, does this restart the 90 days? Also, is there a chance/risk that the GPS fix would be separated out of 10.1 to speed up addressing the emergency AD?
Posted By: scott
Date Posted: 30 May 2015 at 1:23am
WAAS GPS cable is RG400. You can tell because it is thicker and has coper shielding like this:
Non WAAS cable is thinner and usually has a black jacket.
Date Posted: 31 May 2015 at 7:08am
I'm glad they are motivated to review, but if data had to be resubmitted, does this restart the 90 days? |
Typically yes. The FAA technically never gives themselves an obligation to approve anything. When a data package is submitted for approval, they have 90 days to review it. By the end of that 90 days they are supposed to have their review complete. From the complete review, they either ask a question, or grant approval. When an applicant answers a question, that is considered a new submittal date, and the FAA's review clock starts again. That (sadly) is the typical STC process. Unless Avidyne was able to negotiate some kind of special deal...
Date Posted: 31 May 2015 at 6:27pm
I guess what I'm hoping is the worst case scenario is that the original 10.1 90 days is unaffected and is still on track, but if there is a second 90 days for the AD - even though it is resolved with 10.1, it would just be a notice stating that we can remove the AD limitations that has to wait for the new 90 days.
I don't really blame the FAA for their stance, I'm familiar with similar policies and although they can be a pain, there is a reason. The reasons I'm aware of (and I'm guessing why the FAA adopted it for their processes) is that people would apply for something prematurely and end up either retracting or modifying their application. That isn't good for anybody and can have a terrible impact on other customers due to wasted resources. To avoid that, you impose restrictions forcing whoever is applying to really have their act together.
The alternative is to have higher fees to incentivize people to get it right the first time, but that puts the little guy at a disadvantage.
Posted By: jwjenks
Date Posted: 03 Jun 2015 at 11:44am
A week before the AD came out I did my first GPS approach in the clouds (to my home airport) on one of the AD identified approaches. Indicator needles were way off but was able to follow the map course to a very safe landing. Lucky I'm in flat NJ with no obstacles nearby and a ceiling of 1000'. I really need 10.1; and in the NYC and Phila area, need the Traffic and ADS-B in.
------------- JWJ
Date Posted: 05 Jun 2015 at 8:21pm
iPad v10.1 downloaded today, very cool. We are all ready for the 540 version!
Tom Wolf
