bezel lighting
URL: http://forums.avidyne.com/forum_posts.asp?TID=475
Printed Date: 20 Jul 2025 at 4:04pm
Topic: bezel lighting
Subject: bezel lighting
Date Posted: 04 Dec 2014 at 9:16pm
Oddity about the bezel lights. (Edit: AXP340)
With control set to "normal" ...
"The display brightness/backlighting is controlled from the
ambient light sensor and the bezel is controlled by the
lighting bus."
The panel dimmer runs the bezel buttons up/down OK. But, when the panel dimmer is set to OFF, the bezel lights go to MAX. I would prefer them to just go out. Any way to change that behavior? Can't see anything in the install manual.
Posted By: Gary T
Date Posted: 04 Dec 2014 at 9:43pm
From p. 92 of the IFD540 installation manual ( did your installer try this configuration?):
Page 90 and 91 likely apply as well.
Table 72: Lighting Bus Configuration
To calibrate the dimming bus:
1. Select desired dimBus Type;
2. Select the dimBus Max Voltage field;
3. Push the right bezel knob;
4. Set the dimming bus to the maximum value (e.g. full clockwise position on dimming rheostat);
5. Push the right bezel knob to store;
Repeat the process for the minimum value (use full counter-clockwise position of rheostat)
Gary-T
Date Posted: 04 Dec 2014 at 10:19pm
This is for the AXP340.
Posted By: Gary T
Date Posted: 05 Dec 2014 at 8:50am
Orest,
Which configuration from the AXP340 install manual did your installer program?
Maybe try ambient light sensor only to eliminate effects from your dimming
control(OFF position)?
6.1.16 Lighting Control
The AXP340 has an integrated ambient light sensor in addition to an external input connection from the aircraft lighting bus (if available). This configuration setting selects the way in which the integrated light sensor and the lighting bus input control the brightness of the LCD and the bezel.
Selected Method
Description of lighting control
Normal mode
The display brightness/backlighting is controlled from the ambient light sensor and the bezel is controlled by the lighting bus.
Bus Only
The lighting bus is used to control the bezel and the display brightness/backlighting.
Sensor Only
The ambient light sensor is used to control the bezel and the display brightness/backlighting.
Gary-T
Date Posted: 05 Dec 2014 at 9:28am
Yes, I thought we tried BUS ONLY, but it didn't change the behavior. Will try it again.
I suppose outdoors, the buttons won't seem too bright, even if we can't get them to dim out.
Date Posted: 05 Dec 2014 at 11:03am
Orest,  I played around with the lighting settings on both the IFD540 and the AXP340 and was able to get them to do what I wanted.  I use a combination of the light sensor and the lighting rheostat in the aircraft and it works well.  My AXP340 buttons are lighted in the day on full brightness, as are the AMX240 buttons and then dim at night.
Date Posted: 05 Dec 2014 at 11:25am
If you have a chance, would love to see a screen shot of the service screens of your lighting setup, or if you wrote the values down ...
Date Posted: 05 Dec 2014 at 12:17pm
I'm out of town until Sunday, but will get you them then.
Date Posted: 05 Dec 2014 at 12:59pm
Most appreciated.
