configuring for traffic
URL: http://forums.avidyne.com/forum_posts.asp?TID=472
Printed Date: 05 Jun 2025 at 5:52am
Topic: configuring for traffic
Posted By: ksdoc
Subject: configuring for traffic
Date Posted: 03 Dec 2014 at 5:54pm
I am not receiving traffic on foreflight via stratus 2. What settings on the 340 transponder do I need to set to get the traffic?
kansasdoc
Date Posted: 03 Dec 2014 at 5:56pm
You need to configure the 340 to squawk that you are participating IN (TIS-B) on 978.
Posted By: ksdoc
Date Posted: 03 Dec 2014 at 6:38pm
I have that part set for 978 In, and still do have traffic showing up. I thought there might be another step I'm missing. The transponder is displaying the ADS-B, I wonder if it is broadcasting it?
kansasdoc
Date Posted: 03 Dec 2014 at 6:58pm
Send an email to:
9-AWA-AFS-300-ADSB-AvionicsCheck@faa.gov
With your GPS source & transponder type, and aircraft tailnumber.
You'll get a report back on your ADS-B broadcast, and whether it is correctly configured.
Posted By: ksdoc
Date Posted: 04 Dec 2014 at 7:56am
Thanks for the tip.
I sent off a request, and the reply was that it failed:
"Requested report attached.  The report indicates that there may be software issues.  Make sure latest software versions are installed."
I sent the report to my installer, I hope he can make some sense of it and secure a fix.
kansasdoc
Date Posted: 04 Dec 2014 at 8:48am
Rog. That should fix it.
Errors in ADS-B installation/setup are pretty common, and likely will be for a while.
Posted By: Gary T
Date Posted: 04 Dec 2014 at 10:05am
I have a Clarity ADS-B unit with no optional external antenna offered( good internal antenna/reception?).
However the Stratus 2 unit from Sportys does offer an optional external (short whip w/suction cups)
ADS-B antenna :
Improve ADS-B reception with this suction-cup mounted antenna. The Stratus™ relies on ground based ADS-B transmitters for data. If you intend to mount the Stratus in a location that obstructs its view of ground based towers, simply plug this antenna into the back of the unit and mount to a window. Includes a 5 ft cable, antenna and 2 suction cups for mounting. This antenna is for ADS-B only. It does not replace or supplement the GPS antenna in the Stratus.
Gary-T
Posted By: Gary T
Date Posted: 04 Dec 2014 at 10:22am
From IFD540 install manual:
7.5.3 RS-232 Port Configuration (Page 2 of 10)
The RS-232 Configuration Page allows the configuration Inputs and Outputs to match that of the equipment installed in the aircraft. The following selections can be made on the RS-232 Input.
Channel Outputs
Selection
Description
Off
No device(s) connected to output of this channel
ADS-B (Avi)
Serial position data to the following units:
Trig TT31 (V 3.1 or later)
Avidyne AXP340
Gary-T
Posted By: Gary T
Date Posted: 04 Dec 2014 at 9:06pm
KSDOC,
I assume you have an IFD540?    Or some other WAAS GPS (Garmin) that may require
different configuration setup with the AXP340?
Gary-T
Posted By: ksdoc
Date Posted: 09 Dec 2014 at 11:41am
Avionic shop that did my install had to adjust some of the settings on the 340 and now it's broadcasting the ADS-B out correctly, yeah! So finally have the traffic I wanted on ForeFlight.
kansasdoc
