no "+V"
URL: http://forums.avidyne.com/forum_posts.asp?TID=409
Printed Date: 27 Apr 2024 at 10:45am Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: no "+V"
Subject: no "+V"
Date Posted: 28 Aug 2014 at 6:01pm
As a reminder, the initial release of the IFD540 does not support +V approaches but that will be added in the next few months. |
Oh dear, that is a nuisance. Will this firmware update slip into production units as it becomes available, or will we have to purchase it? If the latter, that would be kind of crazy.
Posted By: pburger
Date Posted: 28 Aug 2014 at 6:12pm
Orest,
As far as I'm concerned, we already purchased that functionality!! I've got to think it will just be a simple update with no charge. If that is an add-on purchase, that might be enough for me to drop the whole thing.
I'm trying hard to keep the faith...
Posted By: FORANE
Date Posted: 28 Aug 2014 at 6:52pm
Guys, this is a minor issue. At least the approaches involved are included in the database and selectable. I have a shiny GTN 650 which doesn't even have the approach in the database for an airport I regularly use.
------------- Lancair 235/320 RV-9A
Date Posted: 28 Aug 2014 at 7:14pm
Orest! That is an uncharacteristic leap!
Maybe I should have done better on the original post so let me try now.....
Percentage-wise, there are a tiny number of published LP+V approaches in the world. The initial release of IFD540 didn't support LP+V for reasons that are either too inane to go into here or because I'm not bright enough to fully understand. Suffice it to say we found a way to add LP+V capability in the system which took a code change. We will include that in the next software release. There is no way we'll charge for that. I didn't mean to imply that in any way.
The initial release does support LPV, LNAV/VNAV, LNAV+V, LNAV, and LP approaches.
For reference, we've already released a 2nd software release since the original cert. These kinds of minor releases may happen often as we repair bugs, make minor improvements, or add bits of functionality. I think the standard "past performance does not guarantee future results" kind of disclaimer is worth typing in that you shouldn't assume we'll have one release per month but we'll spit releases out on an as-needed or when-it-makes-sense basis.
We have no intent to ever charge for bug fix releases or minor functionality adds. We do intend to provide mechanisms to "opt-in" for releases that have major functionality adds that warrant a $ charge. In those cases, we intend to provide a mechanism that allows all to get the release if it contains bug fixes and minor improvements at no charge and if you want the $ chargeable function, you can optionally elect to pay for it.
IOUs and functions like +V that you think were part of the original purchase are NOT appropriate to charge $ for.
Keep the faith man! It shouldn't be hard to do so. But, please let me/us know if that gets hard. Seriously.
Date Posted: 28 Aug 2014 at 7:47pm
My mistake, and my apologies, and I thought the comment referenced the very common LNAV+V approaches.
In those cases, we intend to provide a mechanism that allows all to get the release if it contains bug fixes and minor improvements at no charge and if you want the $ chargeable function, you can optionally elect to pay for it. |
Ah very good, excellent construct.
I suppose it was (an uncharacteristic leap!). I'm in a bit of a bad mood at the moment-- nothing to do with Avidyne.
Date Posted: 28 Aug 2014 at 7:54pm
Well..... once again, I wasn't complete in my description of the problem set.
LNAV+V is supported in the initial release IF you have a baro input like and Aspen PFD or G500/600 or air data computer.
Just as we have done with LP+V, we found a way to support LNAV+V for those folks who don't have a baro input source. That too, will be included in the next software release and will be no $ charge.
Date Posted: 28 Aug 2014 at 7:59pm
Just as a suggestion, or rule of thumb.
My thinking on software revisions runs along this line as it relates to early adopters.
The yardstick is to compare the functionality to what a new buyer would get. If you have functionality which would be standard to a new buyer then the early adopters should get those things without up charge as "standard equipment", at least for a reasonable amount of time.
If whatever the bell/whistle is turns out to be an option for a new buyer to purchase or not purchase, then it is fair to approach the same bell/whistle in the same fashion to an early adopter. But of course we early adopters should be treated a tad better <g>.
I am thinking, though, that there is certainly functionality which is going to be the stock machine which didn't make the cut line at time of STC, so I would expect that such things as TWX670 full mode display, the +V, and so forth to be looked at that way.
------------- David Gates
Date Posted: 28 Aug 2014 at 8:18pm
Just as we have done with LP+V, we found a way to support LNAV+V for those folks who don't have a baro input source. That too, will be included in the next software release and will be no $ charge. |
Ah, the old BARO input, which I now have. Oh, and if you can slide the Avidyne Plantain into one of those slipstream firmware updates, you will make me feel much better, heck I've even pay for that one.
Date Posted: 28 Aug 2014 at 8:21pm
Ahh, I forgot about the new nomenclature of "Avidyne Plantain". We'll be sure to put one of our engineers with Central American ancestry on that one.....
Posted By: Paul
Date Posted: 28 Aug 2014 at 8:35pm
Orest has been very patient (and subtle). You should sneak that feature in for him if you can.
Date Posted: 28 Aug 2014 at 9:13pm
Part of the rub is that we were also sold undisclosed new features and those haven't been delivered - potentially wifi counts depending on what comes in the future to enable the hardware. Now we are being told the rest of these features are "new capabilities" and we'll have to pay for them. Not only that, but we'll have to most likely pay the dealer for these bug fixes, so they aren't free.
Date Posted: 28 Aug 2014 at 9:22pm
No, not true. We have never said, nor will we ever say that "the rest of these feature are new capabilities and you'll have to pay for them".
Nor is it fair to assume that the end user has to pay for bug fixes via some dealer bill. The typical scenario for a pure bug fix release is a no charge release to the end user and Avidyne covering the installer's time.
The simple rule is that if it's our mistake, we don't make you pay.
I would encourage all readers to not jump to any conclusions. Judge each release/situation on its own merits. I would fully expect anyone to express their opinion when a release is announced and what it's implementation details are but to speculate on the unknown is not worth the internet bits/bandwidth or your angst. We're not a non-profit company but we surely aren't in the business of screwing over our valued customers.
Posted By: Paul
Date Posted: 29 Aug 2014 at 7:54am
It may be that we're sufficiently used to the way certain other companies treat us that we make incorrect assumptions. Some us assumed we'd be charged through the nose for everything, including Avidyne's mistakes. And we're happy to find out we are wrong.
Perhaps you or someone at Avidyne can write up the update/upgrade policy and publish it here and on the avidyne.com website? An announced customer-friendly policy would show a difference between you and some other companies.
Posted By: Old Bob
Date Posted: 30 Aug 2014 at 9:11am
Good Morning Paul, While my recent messages have shown me to be a "newbie, I ordered my IFD 540 in early August of 2011
I am happy with the way Avidyne has communicated with us all. I also am just as frustrated as you are by all of the delays, but having dealt with the FAA since it was first organized, I realize that, like all bureaucracies, it gets harder and harder to deal with. I think trying to get Avidyne to write a "policy message" would be a waste of time and would likely be a step in the wrong direction. Just be happy! Happy Skies, Old Bob PS Avidyne has responded to the desire of a few of us who think the +V function is a bad idea by making provisions to individually remove that function. Great deal for those of us who feel that way.
Date Posted: 30 Aug 2014 at 9:55am
With all due respect, and not wishing to bash anybody, the current delays appear to have nothing to do with the FAA.
Posted By: Paul
Date Posted: 30 Aug 2014 at 11:33am
Hi Bob,
Steve's communications are great. But communications from other parts of Avidyne have not been so good. I'm still waiting for the salesman I talked to in March to call me back - he could have probably sold me an Avidyne audio panel if he had done so.
The IFD looks like it has great engineering but I shouldn't get important information (even if it is good news) about policies in a forum note titled "no +V". It should be on the Avidyne website. And their salespeople should be using it to beat up on the competition. Then they will sell more IFDs and make enough money that they can hire an engineer to implement Musa acuminata.
Date Posted: 30 Aug 2014 at 12:21pm
Musa acuminata |
Yes, yes, please!
Date Posted: 30 Dec 2014 at 12:08pm
You made the following comment around the end of August:
Pending receipt and installation of my IFD540/AXP340 combo, I have a couple questions to be sure I am clear on the meaning of your comment and the term "baro input": 1) By "baro input" do you mean only baro-corrected altitude sources per 6.8.1.2 of IFD540 IM p70, to the exclusion of the uncorrected sources in 6.8.1.1? 2) I currently have a Sandia 5-35 with G330 (not ES). So if my new installation feeds alt info via RS232 from the Sandia to the AXP340 which then relays it via RS232 to the IFD540, this DOES NOT qualify as baro input. Correct? 3) What config is anticipated under 6.8.1.2(3) "ARINC from Transponder"? Is there a specific transponder that provides this? (vs 6.8.1.1(5) "RS232 altitude encoder" ... i.e. relayed via AXP340). Why does ARINC data qualify while RS232 data does not?
I do not have an Aspen, G500/600, or Shadin ADC.
Assuming that my installation does not meet the "baro input" requirement, do you know yet which release will support LP+V & LNAV+V without it?
Date Posted: 01 Jan 2015 at 11:11am
Vince,
1. Yes. 2. Correct (but I am going to double check something on 5 Jan so standby for a possible update). 3. I need to do some homework on this to refresh my memory. I should have that done by about 5 Jan and will repost when I do.
As for the question about what release supplies +V for everybody, that will be Release 10.1 which will be shipping in the spring time. I will start a Release 10.1.0.0 thread (release content and schedule updates) as soon as Rel 10.0.3.0 is certified.
Date Posted: 05 Jan 2015 at 3:57pm
Homework complete. Here are some more in-depth answers:
Regarding #1, if a device sends
ARINC 429 label 204 (baro-corrected altitude) and the input is configured for
the following priority-sorted list, it will be used for the system-wide
baro-corrected altitude value. We are not performing any exclusion of 6.8.1.1
sources. 6.8.1.1 & 6.8.1.2 both include ARINC 429 EFIS as an option. The
full list of ARINC 429 selections that allow altitude data is as follows:
1.
Airdata
2.
Airdata/AHRS
3.
Garmin GDU
4.
EFIS/Airdata
5.
Honeywell EFIS
6.
Garmin GAD42
7.
GTX330
8.
GTX330 w/ Traffic
9.
Traffic Advisory
Regarding #2, the AXP340 will support the
Icarus/Trimble/Garmin format, or RMS format. The AXP340 will always relay out
the Icarus/Trimble/Garmin format. The Sandia 5-35 supports the Trimble/Garmin
format (and an MX20 format) so the Trimble/Garmin format is the likely
configuration & connection between the Sandia and the AXP340. The installer
should know that the parallel encoder output of the Sandia should not be
connected to the AXP340 if he elects to use the RS232 format.
The RS232 data is uncorrected
pressure altitude, not baro-corrected altitude.
Starting in Release 10.1.0.0 (spring 2015) the IFD540 will use baro-corrected altitude when available, and fall
back to GPS-derived MSL altitude when baro-altitude is not available.
Regarding #3, ARINC from
Transponder:
This is the ARINC 429 input from the GTX330, which can serve as a data
aggregator and pass through 429 data to the IFD.
Summary:
1.
Baro input means baro-corrected
altitude, regardless of the source. No exclusions were implied.
2.
Sandia does not
3.
GTX330 data
aggregation of ARINC 429 data, still requires label 204 for the GTX to
pass-through label 204.
Date Posted: 05 Jan 2015 at 4:04pm
Thanks for the detailed clarification, Steve. It helps me to ask the right questions of my installer to make sure that the installation works as desired including +V without further intervention once 10.1.0.0 becomes available.
Posted By: mfb
Date Posted: 05 Jan 2015 at 8:20pm
The IFD540 installation manual states that the unit can be connected to an encoding altimeter so that it relieves uncorrected pressure altitude.
Is there any reason to do this? It sounds like the IFD540 uses GPS altitude if baro-corrected altitude is not available. What is raw pressure altitude used for? What goes away if pressure altitude is not available?
Posted By: pburger
Date Posted: 27 Mar 2015 at 3:48pm
Mike |
Was this ever answered? I realize my shop did not connect the AXP-340 pressure altitude to the IFD-540. I just included that in a long squawk list to them. I'm wondering now if it is needed at all. Can anyone shed any light on this?
Posted By: Leonard
Date Posted: 27 Mar 2015 at 9:13pm
But don't let him know and see how long it takes for him to find it. I bet it won't take him long. Just hope he's on the ground. Wouldn't want him to go in banana shock while he's up in the air. Lol
Date Posted: 27 Mar 2015 at 10:35pm
Ho, ho, ho, I'm keeping a careful eye out!
Date Posted: 28 Mar 2015 at 8:15am
Mike |
I need to check on a few things on Monday but here's a snippet from the pending AXP340 Installation Manual. See the two statements I put in bold red. This is obviously focused on the AXP340 but the thing I need to check on is my memory that this was the motivation behind the IFD540 IM note you reference.
++++++++++++ From Pending AXP340 IM ++++++++++++++++++
The AXP340 must be
connected to an approved altitude encoding source. The AXP340 can use either a
parallel Gillham code altitude input, or serial RS232 altitude input. Both of
these interfaces are on the 24 way connector.
If the altitude encoder you are using offers both, we recommend using
the RS232 serial input. Serial formats
allow a higher resolution altitude representation that can be used by Mode S
interrogations, whereas parallel Gillham (gray) code format can only represent
altitude to the nearest 100 feet. You
must choose between serial or parallel Gillham formats – you should NOT connect
both. If a parallel Gillham encoder is connected the AXP340 will always use
that as the altitude source even if a serial encoder is also connected.
The parallel Gillham encoder
inputs are active when the voltage to ground is pulled below approximately 4
Volts. The AXP340 includes internal
isolation diodes which prevent the unit from pulling the encoder lines to
ground when the transponder is switched off.
The AXP340 can therefore share the altitude inputs with other devices
without needing external isolation.
Parallel Gillham output
altitude encoders intended for operation below 30,000 feet may not have a
signal connection for D4. In an aircraft
with a service ceiling below 30,000 feet input D4 will never be active, and can
safely be left unconnected.
The serial encoder input
uses RS232 input levels. The
communication should be 9600 bps, no parity.
The AXP340 will correctly recognise either “Icarus/Trimble/Garmin”
format altitude data, or “RMS” format altitude data. Refer to the encoder documentation to
determine jumper settings as appropriate.
The AXP340 can also accept Shadin
family Format G, Format S and Format Z air data protocols which supply both
altitude and airspeed information. The
airspeed information can be used to provide an automatic air/ground
determination for an ADS-B installation.
The AXP340 includes a
serial altitude output which repeats the altitude received on the encoded input
(either parallel Gillham or serial) for connection to a GPS or other
equipment. The serial output supplies
RS232 output levels, and runs at 9600 bps, no parity. The output format is always “Icarus/Trimble/Garmin”
format. If the altitude source is a
parallel Gillham encoder, the serial output is reported every 0.5 seconds; if
the source is a serial encoder, the output simply repeats the input reports,
each report delayed by up to 10 milliseconds from the corresponding input
report.
The AXP340 transponder can
accept altitude from multiple sources, the AXP340 will prioritize the altitude inputs
in the following order:
- Parallel Gillham code input (Gray code input)
- GPS RS232 Input with Airdata information (e.g.
Avidyne R9 IFD)
- ADC/Serial Input
All the altitude sources
above must meet either TSO-C10( ) or TSO-C88( ) per 14 CFR 91.217.
The ADS-B output does not
alter any existing regulatory guidance regarding the barometric altitude
accuracy or resolution. Aircraft operating in Reduced Vertical Separation
Minimum (RVSM) airspace must have the same accuracy and resolution for the
ADS-B airdata transmission.
