Visual approaches missing vertical guidance
URL: http://forums.avidyne.com/forum_posts.asp?TID=2735
Printed Date: 01 Jul 2025 at 1:03pm
Topic: Visual approaches missing vertical guidance
Posted By: jimmyz80
Subject: Visual approaches missing vertical guidance
Date Posted: 02 Apr 2025 at 4:25am
What are the prerequisites for an Entegra PFD to display vertical guidance for an IFD generated visual approach? Mine used to show the guidance and it was a nice secondary reference to have in front of you. Lately I've only been getting lateral guidance on visual approaches.
I did however recently disable VNAV in setup mode, since I know the Entegra is incapable of displaying enroute VNAV guidance, and I wanted to get rid of the annoying VNAV-direct LSK. Did this also blow up my visual approach vertical guidance? I couldn't find anywhere in the pilot guide that indicated the VNAV feature was required for visual approach vertical guidance.
Thanks!
Date Posted: 02 Apr 2025 at 10:42am
Did you disable "Enroute VNAV" or "VNAV Labels"?  Sounds like maybe you did the latter.
Posted By: jimmyz80
Date Posted: 02 Apr 2025 at 3:00pm
It was Enroute VNAV that I disabled in setup mode, on the Main System Config page. Where is that other option for VNAV Labels? I just searched the IFD installation guide rev 25 and don't see that text in there anywhere.
Posted By: Melohn
Date Posted: 02 Apr 2025 at 8:08pm
Thanks!
On some visual approaches I get vertical guidance and others I don’t. I believe there is both a relative altitude, speed, and possibly angle to the final approach course for the vertical guidance to appear. You can play with it in the simulator to get any idea of what’s required.
Date Posted: 07 Apr 2025 at 9:54am
The Main 429 Config page has an entry titled "VNAV" which enables/disables labels for VNAV during approach.
Posted By: jimmyz80
Date Posted: 07 Apr 2025 at 12:29pm
Ahh ok. I just checked and labels are still enabled.
