IFD WiFi discoverability
URL: http://forums.avidyne.com/forum_posts.asp?TID=2717
Printed Date: 07 Jan 2025 at 10:08pm
Topic: IFD WiFi discoverability
Posted By: IanJay
Subject: IFD WiFi discoverability
Date Posted: 04 Jan 2025 at 7:39am
I have been experiencing some issues with my WiFi on my IFD 550. When I purchased it, internet connectivity wasn’t enabled and Avidyne sent over the files to unlock it. All went well and I connected my phone and iPad to it without any issue. I since had to change an ARINC 429 setting for my G5s to talk properly and enable capstone for my stratus. Since making those changes, and only those changes, the IFD WiFi network is no longer discoverable. My iPad automatically connects to it in once I open ForeFlight and hit “cancel” on “turn on ForeFlight mode”. The settings on my iPad only show it connected to the stratus.
Anybody else have this problem? Avidyne is running on 10.3.1.2
Date Posted: 05 Jan 2025 at 8:17pm
Originally posted by IanJay IanJay wrote:
My iPad automatically connects to {the IFD} once I open ForeFlight and hit “cancel” on “turn on ForeFlight mode”. The settings on my iPad only show it connected to the stratus.
I'm confused.  I think you're saying the iPad reports that it's connected to the Stratus, but you believe it's connected to the IFD.  Is that correct?
I don't think I've ever heard of an iPad reporting that it's attached to a different wifi than what it's actually attached to.
Why do you think it is attached differently?  How have you confirmed it's attached to the IFD?
Posted By: IanJay
Date Posted: 05 Jan 2025 at 8:41pm
The WiFi network on my iPad and IFD show that they are both connected to my Stratus reciever. This is reflected under my devices page on the IFD. Only when I open ForeFlight and select “cancel” when asked to turn on ForeFlight mode, will my iPad also show up under the devices tab.
The main problem is that I am not able to physically see the IFD hotspot WiFi network on any device I bring into the cockpit and use to try to pair to my IFD. I wouldn’t say it’s reporting an attachment to a different network.
Date Posted: 06 Jan 2025 at 5:49am
I‘m also confused. I don‘t recall Foreflight ever asking me to turn on „Foreflight mode“ when I open it. Can you show a screenshot?
Also, if the IFD shows itself as being connected to the stratus receiver, then it must be in client mode rather than hotspot mode. In that case the IFD will not show up as a hotspot and as such not be „discoverable“ in the ipad wifi network settings.
I suspect the capstone change is related to your new issue. What are you trying to achieve with that change? What is the ADS-B OUT setting on the IFD?
Posted By: IanJay
Date Posted: 06 Jan 2025 at 6:46am
I believe ForeFlight only shows the message when it’s connected to Avidyne and a capstone device. “Open ADSB mode” is toggled on in the stratus settings and capstone is enabled in the IFD maintenance settings.
On the IFD the Adsb Out setting input is “Icarus Alt” and output is “ADS-B+ (G)”.  My main concern is having new devices be able to connect to the IFD. Somewhere along the way IFD WiFi ID disappeared from my Apple products.
If it’s normal to not see the WiFi ID in this situation, my apologies. I remember talking with tech support about another issue and upon mentioning I could no longer see the Hotspot address on my iPad and iPhone, he thought that was odd. We had bigger fish to fry so we moved on to the bigger issue at hand.
Date Posted: 06 Jan 2025 at 8:28am
On an ipad, the wifi section lists the networks, i.e. hotspots. A wifi device can be client or hotspot (access point). It cannot be both at the same time. The clients will not show in the ipad wifi network list.
In your case, it sounds like the stratus is the hotspot/network. Other devices connecting to that network must all be clients, incl IFD and ipad (FF, but also IFD100 if on ipad). WIFI is not point-to-point. iPad apps and the IFD communicate directly but over the stratus network and via the stratus hotspot.
What do you mean by „Adsb Out setting“ for the RS232 settings (input/output)? In other words, what equipment is wired to these RS232 ports? Is this output port to a Garmin 330 ADS-B OUT transponder? If so, it is not related to you ADS-B In wifi connection.
My ADS-B OUT question was related to the IFD Setup/Connection menu. There is a ADS-B over wifi parameter, but you will only see it if you have a wired ADS-B IN source, which you haven‘t mentioned.
Posted By: IanJay
Date Posted: 06 Jan 2025 at 8:45am
Ok. That makes sense.
I wasn’t sure what you meant by “what is my ADSB Out setting in the IFD”. The RS232 is wired into a stratus ES unit for ADS-B out
Date Posted: 06 Jan 2025 at 9:04am
Sorry, made an update and crossed messages. All clear.
It sounds like you have everything set up right. What exactly is the problem? Or were you just concerned about not seeing an IFD network in the ipad wifi network list?
Can you see the ADSB traffic from the stratus on both FF and the IFD (you should)?
Can you transfer routes between FF and the IFD? That should work too.
Date Posted: 06 Jan 2025 at 11:40am
The latest Pilot's Guide for the IFD series (rev 08 from Sept 2021 corresponding to the 10.3.0.2 software release) has this to say:
"The WiFi system can be configured as a client on an external network (e.g. using a Stratus®) or to host its own Local Area Network (LAN) with a DHCP server. See page 5-31 for instructions on configuring the WiFi system."
Note the "or" in there.  Either it can be connected to the Stratus as a client, OR it can be configured to host its own LAN that other devices can connect to.
Sounds to me like it's currently configured as the former, so you should not be surprised that it's not behaving as the latter.
Posted By: IanJay
Date Posted: 06 Jan 2025 at 12:07pm
That must be the reason why. Cheers, MysticCobra!
