Wish item for next release... 10.4???
URL: http://forums.avidyne.com/forum_posts.asp?TID=2713
Printed Date: 06 Jul 2025 at 9:48pm Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: Wish item for next release... 10.4???
Posted By: PA23
Subject: Wish item for next release... 10.4???
Date Posted: 29 Dec 2024 at 1:07pm
I appreciate that the IFD will display the TAF and METAR data from an ADS-B input source, but please give me the option to read it as raw or undecoded data. I find it easier and faster to read the encoded weather and pull out the data I need quickly.
On the FMS page under INFO before selecting the METAR I get a single line of the undecoded weather, unfortunately on the IFD440 the line isn't long enough to display the whole METAR and of course when I open the METAR I'm presented with a decoded version.
I understand some people prefer to get their weather decoded and that is a personal choice, but given the option I prefer it encoded, even more so when pulling the weather from a X-C trip, I can get METARs from 50+ stations, takes a lot let room to read it encoded.
If Avidyne really feels is necessary to decode weather than why not decode the remarks section of the METAR, some of them I know and can decode on my own but there are a lot that require a magic decoder ring to decipher.
I'm sure this is one of those hot button items like north up vs track up, or tastes great vs less filling. All I'm asking for is the option.
-PA23
Date Posted: 30 Dec 2024 at 12:43pm
Date Posted: 31 Dec 2024 at 6:23am
Improve enroute frequency list for Europe. FIS frequencies are not listed today. Also some radar frequencies are missing in the UK.
Posted By: b2002
Date Posted: 05 Jan 2025 at 12:28pm
Please go back to the old style yellow and red terrain proximity shading. The new waffle style is a big step backward in my opinion.
VNAV compatibility with the S-TEC 3100 autopilot (along with Garmin G5, 275, TXI PFDs if possible).
Posted By: IanJay
Date Posted: 19 Jan 2025 at 12:20pm
I agree with going back to old style terrain proximity shading.
I'd also like to see a heading for hold entries, legs in the hold, etc. I appreciate the message that tells you how to enter the hold but the added situational awareness with a heading for each part of the hold would be nice. Similar to what Garmin GNS's displayed.
Posted By: PA23
Date Posted: 25 Jan 2025 at 5:13pm
Ran into an interesting problem today, flew into B18 today (Alton Bay's Ice runway) and the airport was not in Jeppesen's database, and yes I had verified that "All Runway Surface types" was set in the user preferences, maybe I missed it elsewhere?
Ok, for problem 1 I sent a message to Jeppesen about the missing identifier.
This brings me to the feature/enhancement request...
I went to create a user waypoint by Lat/Long and looking at the Chart Supplement the position is N43°28.66' W71°12.22' however this is not the format the Avidyne wants, the Avidyne does not want decimal minutes it wants Degrees, Minutes, and Seconds
so N43° 28.66 W71° 14.22 would need to be converted to N43° 28' 39" W71° 14' 13" I guessed at the conversion and got close enough but let me enter in the same format (or choose from multiple formats) the Chart Supplement uses.
Of course the best thing about standards is that there are so many to choose from.
Posted By: Melohn
Date Posted: 26 Jan 2025 at 4:17pm
There is a way to specify the lat/lon format in the setup, units dialog. Does this only refer to how points are displayed, and not how they are entered?
Date Posted: 27 Jan 2025 at 1:58pm
PA23 wrote:
I went to create a user waypoint by Lat/Long and looking at the Chart Supplement the position is N43°28.66' W71°12.22' however this is not the format the Avidyne wants, the Avidyne does not want decimal minutes it wants Degrees, Minutes, and Seconds | Actually, it wants whatever format is selected in the user settings. Reference pp. 5-75 and 5-77 in your IFD500 Series Pilot Guide.
I guessed at the conversion and got close enough but let me enter in the same format (or choose from multiple formats) the Chart Supplement uses. | Done!
Posted By: PA23
Date Posted: 27 Jan 2025 at 2:27pm
MysticCobra wrote:
I guessed at the conversion and got close enough but let me enter in the same format (or choose from multiple formats) the Chart Supplement uses. | Done! |
I'll have to test this, (IFD400 has it on page 4-69 & 4-70) but the manual says this is for display purposes. The example for entering the waypoint only shows degrees, Minutes, & Seconds, it makes no mention of other available formats or referencing the User Profile for the format.
Date Posted: 27 Jan 2025 at 7:04pm
The display format and data entry format are the same thing, because you just place the cursor in the spot to change the data, and then you enter the data. The screen doesn't redraw to show a different data format when you go to change the value. The example shows D/M/S simply because that's the default.
Posted By: PA23
Date Posted: 28 Jan 2025 at 11:53am
You are correct, the manual however doesn't make the distinction, it just calls it "display format"
Date Posted: 29 Jan 2025 at 6:09pm
| I think you're trying to read too much into it. After being introduced to the data entry interface, the paradigm quickly becomes clear that to change the data in an editable field, you just...change the data in the field. This is consistent throughout the interface.
All of the data is presented on a "display". Data is also entered/edited on the "display". The way the data appears on the display and the way the data is entered on the display is defined by the display format.
There's no distinction made in the manual because no distinction exists in the user interface.
Posted By: IanJay
Date Posted: 11 Feb 2025 at 8:39pm
I would like to see audible alerts for timers like switching tanks
Date Posted: 02 Apr 2025 at 11:49am
Regarding lat/long formats, I'm not sure what UTM or MGRS are but the other unit format options in the SETUP menu are ddd°mm.mm' (degrees and decimal minutes) and ddd°mm'ss" (degrees, minutes, seconds). As mentioned above, the setting in SETUP determines the format shown at various locations including user waypoint entry.
However, when the user waypoints are saved to USB in maintenance mode, the lat/long format is ddd.nnnnnn, that is degrees to six places after the decimal. Also, West longitude and South latitude are negative values. That's all fine as far as it goes. However, it does cause extra work when updating the csv file and loading it back up into an IFD since one can't be certain what the result will be in the IFD display.
I have a wish item for a future IFD software (point)release to add the ddd.nnnnnn format of the csv file to the list of options for the Position Units parameter in the Units SETUP and also therefore for the lat/long field data entry when adding user waypoints.
Date Posted: 15 Apr 2025 at 12:47pm
Another wish for the next IFD release is to add support for non-ICAO airfields. These are all LFnnnn in France and XXnn in Italy. Both are supported in the Foreflight Europe coverage, but I don‘t know if the navdata is provided by Jeppesen or is Foreflight‘s own navdata. Are they in the Jeppesen navdata but not specified by Avidyne for inclusion in Avidyne navdata? I suspect not, since the data comes from third parties … BASULM for France and Avioportolano for Italy.
In any case, it would be great to include them, especially since it is not possible to transfer them from Foreflight to the IFD when they are in a FPL/ROUTE.
Examples: LF2432 Pressignac Vicq Rebeyrotte in France NU02 San Teodoreo in Italy
