Delete airway
URL: http://forums.avidyne.com/forum_posts.asp?TID=2581
Printed Date: 10 May 2025 at 9:25pm
Topic: Delete airway
Posted By: frankbell
Subject: Delete airway
Date Posted: 27 Sep 2023 at 8:53am
Once I have entered an airway (with LOTS of waypoints in the list!), then get a different clearance, is there a way to delete the entire airway?   (Other than deleting each waypoint).  Or is it best to simply add on to the bottom of the list, or perhaps start over with a new flight plan.
Date Posted: 27 Sep 2023 at 10:28am
Switch to Compact view, then move the cursor to the airway, then press CLR or Delete Airway.
If one of the legs in the airway that you want to delete happens to be active, the airway will be expanded regardless of the selection.  Therefore, you won't be able to select the entire airway.  In that case, you'll first have to activate a leg that's not on the airway.
Posted By: rolfe_tessem
Date Posted: 27 Sep 2023 at 8:01pm
I usually just add on to the bottom of the leg I'm currently on. I suppose it depends on how much of the old stuff you want to save.
Rolfe
