LPV downgrade
URL: http://forums.avidyne.com/forum_posts.asp?TID=2503
Printed Date: 16 May 2025 at 8:33pm
Topic: LPV downgrade
Posted By: Craig767
Subject: LPV downgrade
Date Posted: 23 Apr 2023 at 7:31pm
Was doing practice apps the other day when the IFD540 downgraded the LPV. Got an alert message about the issue and IFD showed GPS-LNAV+V. Except there was no +V.
Does the IFD default to LNAV only, even though it had a +V. I think Garmin does this, not sure about Avidyne.
Craig
Date Posted: 23 Apr 2023 at 9:50pm
The FMS will go to LNAV+V and provide advisory vertical deviations only if there is a descent angle associated with the approach (i.e. specified in the database).
I did get confused by the wording of your question.  What does "Except there was no +V" mean?  Does that mean that the +V didn't appear in the upper right corner or does it mean that you didn't get advisory vertical deviations during the approach?
Posted By: Craig767
Date Posted: 23 Apr 2023 at 10:40pm
There was no advisory vertical deviation although the IFD showed LNAV+V. Though it was curious that although the IFD determined the LPV criteria was not met, it still showed +V. Would have made more sense to have seen just LNAV.
