IFD100 v10.3 Configuration Error
Forum Name: IFD100 Mobile App
URL: http://forums.avidyne.com/forum_posts.asp?TID=2502
Printed Date: 05 Jul 2025 at 3:18am
Topic: IFD100 v10.3 Configuration Error
Subject: IFD100 v10.3 Configuration Error
Date Posted: 23 Apr 2023 at 3:00pm
I have two iPads running IFD100 for AviOS 10.3 connected to my airplane’s IFD540 running AviOS 10.3.1.2. I skipped the AviOS 10.3.0.2 upgrade so I only recently switched to using the IFD100 for AviOS 10.3. With both iPads (a mini 5th gen and Pro 11” both running iOS 16.4.1 and configured as IFD iPad 1 and 2 respectively in the IFD100 app settings) I noticed I was getting a Configuration Error message in the IFD100 app at times. Per the Knowledge Base article regarding this, I uninstalled both the IFD100 and IFD Trainer apps and reinstalled on one of the two iPads with the same results.
At the time, I had two named Users on each IFD100. For both of my IFD100 apps, what appears to trigger the Configuration Error is: either starting the IFD100 already on the user 2 or switching from user 1 to user 2 while WiFi connected to the panel IFD. Essentially, anytime user 2 was selected, the associated IFD100 generates a Configuration Error CAS on the associated IFD100. The message seems to only clear if User 1 is selected and the associated IFD100 is then closed and reopened.
Ultimately, I cleared the name out of user 2 so that only user 1 is named and in use on both IFD100s. This configuration doesn’t generate the Configuration Error message on either IFD100 and the user cannot accidentally be switched because there isn’t a LSK to switch users if only one is named. This configuration also only allows use of one of the ten available users in IFD100 for AviOS 10.3.
I don’t recall ever having this issue with multiple IFD100 users when running IFD100 for AviOS 10.2 or prior. Has anyone else experienced this same anomaly in IFD100 for AviOS 10.3?
