IFD100 black map background
Forum Name: IFD100 Mobile App
URL: http://forums.avidyne.com/forum_posts.asp?TID=2489
Printed Date: 13 Jul 2025 at 3:01am Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: IFD100 black map background
Posted By: keithrkoenig
Subject: IFD100 black map background
Date Posted: 25 Mar 2023 at 1:30pm
There must be a setting I am missing???? Deleted and reinstalled both apps. Reinstalled Jepp database. Even when I am connected to IFD440 I can see all other data but the map is a black background and yes all of them are running 10.3
Date Posted: 25 Mar 2023 at 3:39pm
Two items to verify: - Verify that you have downloaded at least the applicable Terrain database(s) through the IFD100 Jeppesen update. In the end, you should have a green checkmark by at least four downloads: NavData, Obstacles, MapData, and at a minimum, the applicable Terrain database. Electronic Charts too if your Jeppesen subscription includes charts for the IFD100. Without the applicable terrain database, the MAP background will be black.
- Verify the Land LSK on the MAP tab of both your IFD100 and IFD Trainer is a completely filled in white triangle. Anything less than a fully white Land LSK will not display background terrain. The level of land detail can be cycled by touching the Land LSK.
Date Posted: 25 Mar 2023 at 7:51pm
There are only 3 on my ipad and ifd440 from Jepp. And yes, the land is all the way.
Date Posted: 25 Mar 2023 at 8:13pm
Maybe deleting the NAmerica Terrain DB, restarting the iPad, then reloading the NAmerica Terrain DB would be worth a try. BTW - what vintage iPad and iOS are you using?
Date Posted: 25 Mar 2023 at 9:31pm
Mini 6 it is running 15.5 the reload might have worked. No gps signal with the ipad in the office but i actually see some fuzzy terrain, thanks
