No procedure for second airport
URL: http://forums.avidyne.com/forum_posts.asp?TID=2428
Printed Date: 28 Apr 2024 at 12:15am Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: No procedure for second airport
Posted By: Kentucky Captain
Subject: No procedure for second airport
Date Posted: 28 Oct 2022 at 7:35pm
My daughter and I were doing some instrument approaches last week for currency and had something weird happen.
We departed from our home airport, KBRY and did the RNAV 23 approach at KEKX followed by the ILS 5 back to the same airport.
Upon the missed approach we cleared the approach and airport from the IFD540 and entered our home airport (KBRY) and the LPV 21 approach. The Aspen PFD still displayed ILS and a DME as the source. Reentering the approach and airport 2 times did not make any difference.
Thinking we might have an Aspen problem, I powered both Aspens down and back up. Still no change in the info. Wanting to see what would happen, we continued the approach past the IAF. We got no LDI OR VDI at all.
We broke off the approach, circled back around, and while that was happening, I pulled the breaker on the IFD and reset it. When it came back up, I entered the airport and approach. All of the data to the Aspen PFD was correct then. The LDI and VDI worked as advertised.
I have been flying this configuration for almost 5 years and this is the first time I've seen that happen. Could this be a 10.3 issue? Has anyone else seen this?
------------- Woo Hoo!!!
Date Posted: 28 Oct 2022 at 9:29pm
I'm curious what the IFD540 was showing for active nav status after entering the LPV approach. Was it showing VLOC, GPS, or LPV?
Is it possible that the IFD540 didn't revert back to GPS automatically and stayed in VLOC; possibly because the MAP was cleared from the IFD540 before crossing it?
Did you try turning the CDI Nav Source knob to manually change the Nav Source before cycling the IFD540 power?
Date Posted: 28 Oct 2022 at 10:33pm
In the not so recent past, there have been reports of the Aspen not updating in a timely fashion. Reports varied from several seconds to several minutes. I was able to reproduce it one time, but have never been able to do so since. As a result debugging has been next to impossible.
Any chance you can reproduce it?
Date Posted: 31 Oct 2022 at 11:10am
Did you try turning the CDI Nav Source knob to manually change the Nav Source before cycling the IFD540 power? |
Sorry, I didn't think to look at the nav status during the event. I was focused on the Aspen and the lack of a LDI and VDI.
I did not turn the CDI knob either.
Date Posted: 31 Oct 2022 at 11:14am
Any chance you can reproduce it? |
It was at least 10 minutes between the time we entered the new airport and approach til we had to reboot the IFD.
I will see if we can reproduce the error next time we fly. We just brought my daughter's Cherokee 235 back from the avionics shop on Saturday and we have a host of issues to look at there too. A couple dealing with her IFD440. I'll post them over on the 10.3 issue section.
Posted By: JoeIBM
Date Posted: 31 Oct 2022 at 10:56pm
Interesting - I'm glad I'm watching this forum, as I have seen my Aspens very slow to update. When I add or change a flight plan - sometimes it's relatively quick, sometime's it's very slow (2-3 minutes or more). What do you want from a reproduction flight? What do you need to know - happy to assist and dump any logs (although I don't know much about getting log data from the Aspen's - both new Pro Max's).
------------- C310R at KJYO
Date Posted: 01 Nov 2022 at 7:50am
I had forgotten about it until I saw this thread, but when we originally installed the Aspen in my prior plane (a stock EFD 1000 Pro) with 10.2, we had the problem where it could sometimes take 1-2 minutes for flight plan changes to be reflected on the Aspen. The problem seemed to stop when we upgraded the Aspen to a Pro Max 1000. Not sure if that's useful data or not.
Date Posted: 01 Nov 2022 at 9:13am
If you have a scenario that you can reproduce at will, then I would love to know exactly what you entered into the flight plan and how the 232 and 429 ports on your IFD are configured.
Date Posted: 01 Nov 2022 at 9:14am
paulr wrote:
I had forgotten about it until I saw this thread, but when we originally installed the Aspen in my prior plane (a stock EFD 1000 Pro) with 10.2, we had the problem where it could sometimes take 1-2 minutes for flight plan changes to be reflected on the Aspen. The problem seemed to stop when we upgraded the Aspen to a Pro Max 1000. Not sure if that's useful data or not. |
That is helpful, thanks for the update.
Posted By: JoeIBM
Date Posted: 07 Nov 2022 at 12:07am
Ok, I'll go out and try to both record and comment on a reproducible scenario or two. I'll try to grab the 429 and 232 settings as well.
Posted By: JoeIBM
Date Posted: 14 Nov 2022 at 6:24am
Ok Steve,
Finally got out there and ran a couple changes through to the flight plan in-use, and the IFD showed the flight plan change (just a simple direct-to) immediately, but the Aspen takes 11 seconds in one instance and 14 seconds in another instance. I've had the Aspen take much longer at times, but this is a pretty standard amount of time. This is with 10.2.6.3 or so - the last 10.2.6 build whichever that is.
11 second delay: https://vimeo.com/770685930
14 second delay: https://vimeo.com/770685983" rel="nofollow - https://vimeo.com/770685983
Comms config screens: http://www.heistad.com/wp-content/uploads/2022/11/54E4FF51-7AD3-4EC5-9615-9E4650150D45_1_105_c.jpeg" rel="nofollow - http://www.heistad.com/wp-content/uploads/2022/11/54E4FF51-7AD3-4EC5-9615-9E4650150D45_1_105_c.jpeg
http://www.heistad.com/wp-content/uploads/2022/11/DA3D6D9F-8118-44A5-A00E-A120048F8DEA_1_201_a-2048x1502.jpeg" rel="nofollow - http://www.heistad.com/wp-content/uploads/2022/11/DA3D6D9F-8118-44A5-A00E-A120048F8DEA_1_201_a-2048x1502.jpeg
http://www.heistad.com/wp-content/uploads/2022/11/C4B106E2-83ED-4578-9072-84A4C2189569_1_201_a-2048x1566.jpeg" rel="nofollow - http://www.heistad.com/wp-content/uploads/2022/11/C4B106E2-83ED-4578-9072-84A4C2189569_1_201_a-2048x1566.jpeg
http://www.heistad.com/wp-content/uploads/2022/11/65E3D040-FF41-4371-A11B-EDA8CCA252E5_1_201_a-2048x1512.jpeg" rel="nofollow - http://www.heistad.com/wp-content/uploads/2022/11/65E3D040-FF41-4371-A11B-EDA8CCA252E5_1_201_a-2048x1512.jpeg
Date Posted: 14 Nov 2022 at 11:13pm
It looks like the left Aspen responds immediately, but the right one takes forever.
Date Posted: 15 Nov 2022 at 9:22am
JoeIBM wrote:
Ok Steve,
11 second delay: http://https//vimeo.com/770685930" rel="nofollow - https://vimeo.com/770685930
Date Posted: 27 Nov 2022 at 1:54pm
We've been doing some flying, when the weird weather we've been having permits, and have fixed some of our issues. While all don't specifically pertain to the IFD, we thought some one here could shed some insight on our remaining issues after the panel upgrade on my daughter's PA28-235.
We found and fixed: No audio on approaching and minimums - Volume in Aspen was at 6. Range is 0 to 63.
No audio on altitude call outs from IFD - Output from the IFD was set to AUX on the PMA8000 audio panel. Once selected, works fine.
ADS-B is from Garmin GTX330 ES with a GDL88 - Finally have traffic on Aspen PFD & MFD. Also in IFD100. Still get Traffic Fail on Aspen at startup. Changes to Traffic degraded on taxi, and the message finally disappears sometime between the start of takeoff roll and getting airborne. I don't remember seeing that on my plane but I also have the L3 NGT9000+ with TCAS. Might be the difference there. --------------------------------------- Things with issues:
No traffic on any of three iPads. Traffic button not even available. Wifi must be working as we have geo-referencing on Foreflight and the IFD100 works fine and does show traffic. Traffic does show correctly on all iPads in my plane.
Getting a lot of Datalink Data Overdue messages on the IFD44 and 100 app in flight.
Here is the weird one. We take off, enter the first approach. It loads correctly on the IFD. On the Aspen Selected CDI Navigation Source Information Block, it will show GPS1. Next line shows the fix navigating to. In this case, it is the IAF. Next line is bearing and distance. Last line is ETA. After the first approach, we load the next approach. The Selected CDI Navigation Source Information Block shows all of the correct info like the last approach except that the fix navigating to is missing. In the last few approaches, it shows up right around arrival at that fix. Yesterday it showed up about 10 miles from it. Sorry for being so wordy but this is strange and hard to explain.
Switching airplanes, I have a question about mine. My daughter and I have almost the same panel layout except I have the IFD540 instead of her IFD440 and I have a L3 NGT9000+ instead of her GTX330 ES/GDL88. We both have dual Aspens and STEC555X autopilots. I also have the PMA450 instead of her PMA8000B. While her audio from the IFD seems to be routed through the AUX on the PMA8000B, I have no idea where mine is routed through. Could it still be through the PMA450 through an unswitched connection? How can I control the volume from the IFD audio outputs?
Date Posted: 27 Nov 2022 at 3:48pm
A call to your installer should let you know how it is wired.
Go to the AUDIO tab to control all of the volumes on the IFD.
As an aside, I think it is VERY cool that you and your daughter are both flying, in your own planes, contemporaneously. Way cool!
Date Posted: 27 Nov 2022 at 10:01pm
Unfortunately, the first avionics upgrade was done by Gulf Coast
Avionics in 2015. That install incorporated the new powder coated
panel, Single Aspen, IFD540, GNC255, JPI EDM900, STEC30, PMA450, and
AXP340. Andy Smith was the installer and he now works for Aspen. His
wife, Sarah, is in charge of the shop there. Maybe she has records.
I'll see if I can get in touch with her. The second upgrade was done by
Forge Flightworks, formerly Carpenter Avionics. That was where we sent
the Aspen back for the Max upgrade, added the MFD, swapped the AXP340
and SkyTrax 100 for the L3 NGT9000+ /w TCAS, CEIS digital fuel senders,
digital flap gauge, and a few other goodies.
My
daughter said she has chatted with you over on the Piper forum, asking
you about installing an oxygen system in her 235. We have adjacent
hangers with an opening between them. We are always working on one or
the other airplane. Our panels are almost identical now, making it
easier to transition between airplanes. Unfortunately, my C172M is a
lot slower than her PA28-235 so she ends up at 55% power a lot when we
travel as a flight. We went to OSH this year like that and had a
blast. Flew up the ORD skyline at 2500'.
Here
is my current panel in the C172. In addition to the panel work, I
recently redid the interior and got new paint. All exterior lights are
AeroLEDS. Only one more mod coming, an MT, three bladed, electric
constant speed composite prop. Lead time on it is currently 10 months.
Date Posted: 27 Nov 2022 at 10:18pm
Here is Liz's panel. I know this is not an Aspen forum but maybe
someone here can shed some light on it. During the test flight
yesterday, as we finished the run-up and were getting ready to take the
runway, we noticed that the PFD was showing 21 knots in indicated
airpseed even though we were sitting still. We had not taxied that fast,
I'm positive. Pressing the Reversion button on the MFD was saw that
the airspeed was 0 there (actually --). We shut the PFD down and
restarted it, and pulled the breaker to but when it came back up each
time, it showed 21 knots. We taxied back to the ramp and shut down.
The OAT was 59 degrees so it wasn't ice, but we turned on pitot heat
anyway. No change. Cranked the airplane back up and taxied back out to
try it again. The indicated airspeed was 0 sitting at the end this
time. We turned the MFD to reversionary and compared the two airspeeds
as we took off. The PFD jumped to 21 right away and the MFD slowy came
up. by the time they were past 50 knots, they were only 2 knots
different and remained that way for the rest of the flight. They were
working perfectly on all previous flights. I've never seen that before,
even on my airplane. Any ideas? Also, I'm sending you a PM too.
Posted By: JoeIBM
Date Posted: 08 Dec 2022 at 11:07pm
brou0040 wrote:
It looks like the left Aspen responds immediately, but the right one takes forever. |
Actually - they both take the same amount of time, you can see both of them switching 10-15 seconds after hitting the final "enter" button on the IFD...
Date Posted: 08 Dec 2022 at 11:18pm
JoeIBM wrote:
Actually - they both take the same amount of time, you can see both of them switching 10-15 seconds after hitting the final "enter" button on the IFD... |
I'm not sure to what you are referring:
If it is the time it takes the Aspens to finish booting up, the PFD does take a fair amount longer to come up than the MFD. I asked the installer about it and he said that it was proper and they all do that.
If talking about the PFD showing 21 knots while the MFD is at 0, I know that is not right. It is something that just started happening and even after flying airspeed is obtained, the two Aspens are always 2 knots off, the PFD being the higher one. My dual Aspens in my plane do not exhibit any of this behavior.
Posted By: JoeIBM
Date Posted: 11 Dec 2022 at 8:56am
Hi Cap - actually, I think we're talking about two different threads here. I had posted videos showing how long it takes my MFD to "receive" the updated flight plan from the IFD, and I think brou0040 was saying he/she thought the PFD was 'receiving' the updated flight plan immediately but the MFD was delayed. I'm just having a conversation about that particular weirdness, which I hope Avidyne or an installer can provide some insight into clearing up for me.
Hope you get your stuff worked out as well!
Forum Software by Web Wiz Forums® version 12.01 - http://www.webwizforums.com Copyright ©2001-2018 Web Wiz Ltd. - https://www.webwiz.net
